General Category => Engine Management => Topic started by: speedjunky01 on September 02, 2010, 02:44:21 AM
well the d15b motor is done and just about in, just final touches to go and we have some real power but ive never really tuned anything high boost on 93, just my tired old z6 at 12ish psi
setup
d15b 75mm vitaras STD rods 8.3:1
delta 272, PBT special :noel:
RC 750
walbro 255
speedfactory 4bar(same as fagdata but lifetime warranty)
need some advice on how to setup the higher boost timing, right now i just did a step retard like so
0-3 .5
3-5 .75
5-7 1
7-13 1.35
13-22 1.5
the issue im running into is it pulls a TON of timing its al at -6 in the high boost :P
not really sure what acceptable base numbers to start with so any advice would be awesome ill get a screen cap of the map in one minute.
also some target AFR's that most would reccomend like between x and x boost x afr is good know what i mean?
photobucket is down will have pics in a sec
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi5.photobucket.com%2Falbums%2Fy155%2Fspeedjunky01%2Fhighign.png&hash=ccd13902c09ae6b7b42e18a42fc4155dd9bc59ef)
high cam
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi5.photobucket.com%2Falbums%2Fy155%2Fspeedjunky01%2Flowign.png&hash=d3db8ab528c84f262cc932d50e45cccf5afb9d6b)
low cam
nada?
im interested in the answer to your post aswell :noel:
I think we need porn sir
Lots and lots of porn I'm on my phone so you will have to do the honors
I'm running nearly an identical setup on a z6, same cam and all. Running about 30psi, just left the ign retard at like 1deg/lb and its been running strong all summer. Made 373whp, 337tq at 28psi, the clutch started slipping on the dyno.
So just 1/psi and set the boost to nog?
What afr's in what ranges? I think I would be happy with 370whp LOL
Just do .75 degrees retard building the base and target 12.5 afr up until 10psi then go to 12 from 10-15psi from 15-29psi target 11.5
peak torque should be between 5000 and 6000 rpms add about 3degrees timing back in that area. turn up the boost a few psi at a time and check it out don't just try to tune for high boost right away.
That sounds like way to much timing for a d and not rich enough at all to me
But yeah I'm not just gonna go for 20+psi first pull lmao start wg spring and work it up
From reading jd's posts the d doesn't like a ton of timing and he starts by pulling as much as 1.5/psi but that ends up being way to much up top, on my z6 tune at 13psi 1.3/psi and 11.8:1 workedwell on 13psi but that is pretty conservative
I think I'll do 1.35 up to 12psi then above that pull 1/psi and target 11.8 up to 12psi and 114 above that tapering slow not justo e column dump to 11.4 lol
OK sounds good to me.
any better?
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi5.photobucket.com%2Falbums%2Fy155%2Fspeedjunky01%2Flowign-1.png&hash=54dca2af68ed6b2331b50d132049e39796c1ff6b)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi5.photobucket.com%2Falbums%2Fy155%2Fspeedjunky01%2Fhighign-1.png&hash=113832899512cb0a665eceffba4cde316845b06a)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi5.photobucket.com%2Falbums%2Fy155%2Fspeedjunky01%2FTargetfuel.png&hash=26a81fe8bf52339c28a53bcc24f1e7030b336698)
generally you want to ramp up timing as rpm increase to hold the tq flat.
start with mild timing and add timing slowly until it stops making more power or until u hear it knock.
its pretty straight forward.
11.5-12:0 is a good place to aim for AFR
Yeah, I shoot for 11.5 afr's across the board, maybe 12:1 under 5-7psi
Good info here think I'll just street tune the afr's to where I want and use some Det cans to get timing down
This is gonna be a loooot of pulls haha 2psi increments a good way to get it dialed in? I want it to street drive down low well too not just be a strong wot/high rpm tune
Will be a lot of time hope the Motor holds
spent some time looking at other peoples maps and i think this should be a good base
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi5.photobucket.com%2Falbums%2Fy155%2Fspeedjunky01%2Fhighign-2.png&hash=c27b91f8d6133e854628d0408e4d13d963053410)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi5.photobucket.com%2Falbums%2Fy155%2Fspeedjunky01%2Flowign-2.png&hash=da7f70b8903326be22646aa4b0bdc1f2d194a274)
this with dropping about 1 CR point it should be pretty good, may need more timing to make some power but nothing a set of det-cans and some street pulls in 2psi increments cant fix :noel:
when I was watching dave tune my 8.0:1 comp LS, he added a bunch of timing and it didnt make any more power. It didnt make any less eather. So just because you can add more timing in, dosent mean its making more power. Were talking about 2-5* of timing.
yeah I plan on adding until i hear a spot of det then backing it off 2* or so, the dyno will say if this is a good plan or not
thats pretty crazy though adding that much timing and no difference, i would just stick with whats lower if it makes no difference in the power
Thats what we did. Just rocked it low on the timing.
Thats why I was saying go with .75 retard in the base just turn up the boost in steps and keep the map looking logical as you work up to your high boost level. tune vac on the street Ive founf the dyno to be better for tuning fuel in boost it's to short to log very well street tuning. don't get me wrong ive tuned a few boost monsters on the highway but now that I have dyno access it's just easier and gets a way better result.
Yeah now it makes sense to me guess it take seeing it for your self to click haha.
Only reason I was saying to little retard was because I've always found 1/psi or more to be a great starting point.
Thanks for the advice, I have a good stretch of higway great for 3rd and 4th pulls
The 4th pulls always sketch me out though lol 120 in a beercan civic is nutty
Leed and I were doing 15psi 4th gear rippers on some back farm roads. It was a little hairy.....lol made my butthole pucker...... :o
Yeah even tuning my stock z6 at 13 made mine pucker Csnt saint for 20-22 on the vitara build
Think 93 with 10% ethanol will take that? How much higher could I go?
Pussies, I got a CX airborne above 130 with a cop chasing me.
93 should do 300whp in a shitty 1.6L, more with an efficient head & turbo setup. I can't imagine any turbos big enough make over 300whp at 13psi and still have a reasonable spool time on a D16.
The head is ported, pbt tb setup, 272 cam so it should be fairly efficient
The turbo is eBay but I've seen them go to 375wheel on here stock head
The turbo setup should be fairly efficient all 3", nice cold intake, everything is heat wrapped, turbo has a blanket on it, and the turbo housing was also ported along with the cast manifold
Thanks for the advice guys just waitin on some bolts I broke to get here then I'll fire it up
My LS is 8.0:1, delta 272/260, PBT intake/spacer/tb, and 3" exhaust, to4e 40trim, and we did 22 and then it settled to 20ish psi on pump 92oct, and we ran out of map sensor :'( I wanted to keep cranking on that whore but leed said he didnt want to push it past the map sensor.....lol I need a bigger map and bigger turbo....
