General Category => Forced Induction => Topic started by: EG-MIKE on May 11, 2013, 12:09:47 AM
sorry guys i am not asking to be spoon fed im just having a hard time properly sizing a turbo.
i currently have a cast mani with t3 flange and was thinking about trying to find another tb0357 i think it was. that seemed like it had potential before i fried it on accident.
or i can make a adapter for my hf manifold to my gt17 but im afraid the gt17 wont have enough pull to redline or it wont be capable of producing 200whp.
any thoughts are appreciated
my goals are 185-200ish whp, and idk if it be possible in a del sol but break into the 13's on the 1/4. mind you i'd like to keep this cheap so a turbo that can be readily found at junkyard or on CL
YOU! RODS! OUT OF THE BLOCK, NOW!
Don't go past 180 on D15 rods.
damn. 180 sounds weak
i wish i could find a sweet deal on some usdm d15b rods with pistons, but im not that lucky.
look at my build thread to see what happens haha
yeah i already blew up my old b7 on 9psi with a 6262 knock off, check my build thread in sig
I did 260whp on a high compression oem build on pump. D15 block, y8 head, crower 2 n/a, t3 60/63 7 pounds.
It did shed a rod on that pull.
anyone have expierence with the saab tb0357's? i think that'll be perfect for the little stock d15
There was a set of aftermarket d15 rods on that for $200
pretty sure oczc has them for 99 shipped. id love to go with the internals and just push the big turbo i have now, but its not in the budget right now so im gonna stick with stock block for now with a nice lttle t3 or this gt17.
im finding it hard to see this little gt17 pulling to redline @7250 when it supposedly fully boosted by like 2500rpm's. over on DSO there are a couple people that got great results with these little turbo's, so i might just go with it.
unless i find another tb0357, it just looked so perfect on the motor and felt amazing the few times it seen boost @5psi before the turbo fried. ( my fault installed oil to the coolant port on accident )
Oczc haha go hx35 with a .55 turbine housing it is fun
Mike, you seem like a hell of a guy and a go getter. We'd like to sponsor you with a set of custom D15 rods, but need to make sure you're 100% behind us. If you could post pics of you holding an OCZC Tuning sign, and PM me the particulars of your setup, we can get the ball rolling.
Thanks.
Thanks.
im down, just a hand drawn sign or what? also if you got a sticker or 2 ill throw them on my del sol. i plan on hitting every car show/ race event i can this year after i get it boosted. probably will be boosted within the first week or so of june then tuned mid june. but if im gonna be building the motor i need to know now so i can get the other parts needed to support a high boost high hp d15 build.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi653.photobucket.com%2Falbums%2Fuu254%2F93d3ls0l%2Foczc_zps24ddcf87.jpg&hash=08ee284fefb333d25383f73f1aac5c7dd329680a) (http://s653.photobucket.com/user/93d3ls0l/media/oczc_zps24ddcf87.jpg.html)
i drew out a sign real quick hope you dont mind the colors tom
Don't count on OCZC rods, lol. Stella keeps shipping the wrong rods...
The "40/48" 50-trim T3 turbo you're talking about is about the best turbo for the price on that D15. They'll do over 200whp if you push them, and spool really quick. Since you can't make much power on the stock D15 before it shits the bed, it's best to get a turbo that will beef up your low end. Someone else had a small MHI turbo on a small motor that was really nice, the dyno showed a huge powerband starting at 2500rpm or so. I just can't recall who or what turbo. The 40/48 will be the easiest to get going if you already have a t3 manifold.
Or build a JY Supercharge kit using a s/c off of a Previa, get a good tune.
Rock out 200whp when you need it. :noel:
thanks for the info, i believe you might be reffering to scottdh20 from dso's d15beast7 build that consisted of the b7 and a garrett gt17. which i actually have one just need to rebuild it, i have several HF mani's so thats no biggie. just make a flange which i already made a template for if i do go that route.
How much does one of those set you back, these days?
OCZC FTMFW!!!!
My second one was free.
But normally if you go to a Junkyard and pull one they are about $100 or so.
On egay they are selling for $200 or more.
New ones are 850 to 3100 depending which place you by them.
Ogura Clutches TX15 out New Jersey has them. :noel:
