General Category => Forced Induction => Topic started by: oinesra on August 04, 2009, 06:07:53 PM
Title: My car: rx7.
Post by: oinesra on August 04, 2009, 06:07:53 PM
Basic Homemade turbo setup.
Random Schwitzer turbo that is one of the biggest t3s i have ever seen. Ebay manifold and wastegate, Home Depot oil return line and front lip(not fully bolted on in pic.) JB weld putty on the charge pipe with crescent wrench flared ends. Down pipe is  flex pipe welded to the hat of a civic brake rotor, which is the same bolt pattern as a 4 bolt down pipe  :-*.  And insted of an intercooler I am running a cooling mist setup with an m3 preturbo and m5 after. I dont feel like proof reading this so fuck off.
My car, depot lip not bolted on.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FDSCN0816.jpg&hash=644d5268d00e8b2820a3f235819a0ce73ec63172)
and another
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FDSCN0812.jpg%3Ft%3D1249423239&hash=0337fcdd6483c3164df9836c8c4bad175297cd68)
lip chillin
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FDSCN0817.jpg%3Ft%3D1249423325&hash=7e03a24c1f381bd0089a954532ce3f84c13c4b9f)
engine bay
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FDSCN0807.jpg&hash=47ad25b82290c72de131c8b5dc897a1f63d2e058)
oil retun and bov/charge pipe
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FDSCN0810.jpg&hash=36d9426ec07a87faa7e2f562d516570eaf7b4b55) (https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FDSCN0813.jpg&hash=06403df779eaa1b845f373076344540e4b7a55a2)
yeah its green
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FDSCN0811.jpg&hash=a8417ee6ac696c52426285673eed535abeb607a6)
Title: Re: My car: Insert funny here.
Post by: Deleted User on August 04, 2009, 07:16:52 PM
green =  :mexi:
Post by: fearsomedan on August 04, 2009, 10:18:20 PM
I like the wagon. Please boost it. What are you using for tuning on the rx
Post by: Towdogg on August 04, 2009, 10:22:02 PM
green =  :mexi:
Um thats funny cause if you don't got enough money for me I'm bombing your shit that color green ......  And I do have a can of that grabber green....
Post by: Deleted User on August 04, 2009, 10:23:53 PM
how about u giv me a number so i can get my money right! i got 250$ do i need more u havent let me know!!!!!!!!
Post by: biscuit on August 04, 2009, 10:30:27 PM
Looks good.  How does it run?  Any problems with the MAF sensor?  Good thinking with the rotor... ;)
Post by: oinesra on August 05, 2009, 07:46:08 PM
The fact that they use a fucking flapper door maf is a problem, but other than that it had no issues but I fucked something up. I decided to up the boost. so i put a reuseable paperclip on the wastegate line and upped the boost to 15psi. It ran like a bat out of hell, but I belive I broke a side or corner seal.
not a bad run on this motor thow. its been 5 yearsof beating  and 3 chassies to finally let loose. Even thow it runs like shit, i still daily the bitch
Post by: HiProfile on August 06, 2009, 11:03:38 PM
lol I want to see this. I never put 1+1 together, but sure as shit, the t3 turbine is a 4x100 bolt pattern. Too bad the cheap ones are cast iron, work-hardened, and heat-cycled a billion times.
Post by: t_cel_t on August 07, 2009, 02:54:42 AM
that is the most gangster thing ever
Post by: NoPistons! on August 08, 2009, 03:12:46 AM
Not trying to call you out or anything here but what injectors are you using and how the hell did you not blow that thing up over 4 psi?
I've heard of people running tII motors on their n/a ecu's and vice versa but damn.
Ah, anyway that's cool.
I spy a 10ae next to the wagon?
Post by: caged on August 08, 2009, 03:27:33 AM
He has a cooling mist set up ;) . Nice rhmt set up, its good to see a rotor here for a change.
Post by: j.h.christ on August 08, 2009, 04:31:06 AM
holy shit you're right
Post by: bikewrench on August 08, 2009, 11:33:55 PM
pics of down pipe?
Post by: TTC on August 09, 2009, 02:28:28 AM
Some solid shit in this thread. Well done.
Post by: NoPistons! on August 10, 2009, 08:34:32 PM
I can't believe that's it.
Didn't touch the fuel at all........
Is this running off an n/a ecu or a TII ecu and afm with TII boost sensor?
Timing retarded via clocking the cas?
Any problems at the 3800rpm secondary crossover?  When are you hitting full boost?  Probably just off idle!?
Your setup blows my mind.  Like, just the fact it works and has been holding up.
Post by: TheMadScientist on August 11, 2009, 01:34:56 AM
more pics of the wagon pls  ;D
Post by: oinesra on August 11, 2009, 09:58:42 AM
pics of down pipe?
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FDSCN0822.jpg&hash=12d095f85c7596712be1849717cff74cd0b0f62a)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FDSCN0823.jpg&hash=c0ad420138599a6889161c6abe15888e64d39ff6)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FDSCN0819.jpg&hash=74c79361284691fd7691542fbd6d88323a32e645)
Post by: oinesra on August 11, 2009, 10:06:59 AM
for the longest time i was using  stock n/a ecu/AFM/pressure sensor/injectors and injecting 90% rubbing alcohol.
now im using all Tii stuff and injection 20% nitromethane rc fuel.
Timing is full advance at the CAS because the motor is bridgeported and wont idle on stock ecu correctly with stock timing
no problem with staged injection, cross over is fine. And full boost is at 3500, but the turbo hotside is huge.
The only problem with useing N/A stuff to boos is the pressure sensor. It will flip out when you hit more than 1psi, so i just unplugged it.
Title: Re: My car: rx7.
Post by: Robb on August 11, 2009, 10:41:53 AM
Wow.  The civic rotor/downpipe is fucking awesome. Now, unbolt that turbo setup and chassis from that engine, and replace the driveline with something that doesnt suck donkey cock.
Post by: 98redcavz24 on August 11, 2009, 11:14:09 AM
that downpipe is cockshot worthy. just awesome
Post by: HiProfile on August 16, 2009, 07:51:34 PM
Impossible. Everyone knows (or eats it up) that rotaries accellerate turbine shafts at 13.4x the normal rate of a piston engine. :mexi:
BTW I'm curious about the nitromethane fuel. You need a richer mixture due to nitro, get hotter burn temps, and 10-20% of the fuel is usually castor oil. Is it actually working well for you?
Post by: QikEnuF on August 16, 2009, 08:18:47 PM
Det Downpeez am sex
Post by: malichite on August 18, 2009, 12:20:52 AM
Definitely the floppy cock DP
Post by: 90dx on August 18, 2009, 12:11:52 PM
Lol awesome setup dude :noel:
Post by: colt45 on August 18, 2009, 01:37:38 PM
word bitch
Post by: Toysrme on August 18, 2009, 02:30:17 PM
downpipe is sloppy sex hot
R/C fuel is retarded. its very expencive, it spoils extremeky quickly from moisture, UV light or being stored in heat & if you ever put enough of that shit in there to do anything itd bog down or blow up like a little bitch. any benifit you're getting is front the alcohol being sprayed out of the nozzle.
same goes for isopropyl alcohol.
spray ethyl alcohol like you're suppose to. itll work better & its infinately cheaper.
Post by: oinesra on August 19, 2009, 10:40:19 PM
Works like a champ for me. Best thing I have used it 75/25 meth/water, but meth around here is like 15 a gallon. Plus with the rc fuel, I get cool blue and purple flames from under my car. That is usually enough to scare off the hondas.
I got an intercooler in the works so I can finally use the meth injection the way it was meant for.
Post by: HiProfile on August 21, 2009, 07:44:23 PM
Know what RC fuel (methanol) does when it spoils? It hydrates, as in absorbs water. In his application, it shouldn't matter much, since it's used mostly to cool the mixture a little than to be the main fuel source. Given most meth setups will be ~50/50, even severly degraded fuel will be fine. However I agree that most of it is overpriced. It's the lube content that would be the issue, although rotaries need all they can get for those seals.
Post by: Toysrme on August 22, 2009, 07:53:25 PM
im not trying to be an ass here, but ive got not only going on 20 years experiance working with R/C fuel; but we mix our own at our club.  i haven't had to buy 2-stroke R/C fuel in 3 years. here's my current stock, only the green cool-power is off the shelf fuel.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv414%2FToysrme%2F0822091713.jpg&hash=1e2281e3959ace895d302c26d397778a72e32e59)
ive been through about 5 gallons since this past last june. that's a fuckload. R/C fuel is so expencive because only two factories in the US currently have the OK from the fed government to sell nitro methane
AFA what happens to cars when you run it. I can tell you from first-hand experiance its nothing good. my dad had built a bradley GTII kit car in the 70s with a worked over 1800cc vw engine in it. by the time i was in jr high the choke was shot and if it sat any length of time you had to spray starter fluid down the carb. well guess what? no started fluid and me and my buddy wanted to drive it around abit so out came a spray bottle full of 35% cox fuel.
first time it fired it threw a spark plug out the fucking head.
flash forward to 3 years ago. im playing with the auxillary injector controller output on my SMT-6 in my v6 lexus. were doing some messing around to determine how far you can go on various fuels in a gas engine on the highway (between bigminham & gadsden on I59) we had a 3 gallon supply, a pair of 550cc injectors @ around 80psi. once it had ran for a min you could run that engine peachy fine spraying diesel in it and it would gain 4mpg+ on the highway. (by the time we got passed the first 20 miles on the highway the bitch would run a good 2-3 minutes after cutting it off too) kerosene would run OK, but was fairly dirty and produced some carbon in the intake tract (likely atomization problems)
straight alcohol fuels sucked dick VS petroleum. R/C fuel wouldn't run worth a fucking shit (tried FAI (0%) 5% 10% 15%). overheating was common after the first few minutes so was bogging upon any kind of accelleration.
the first time we went out and tried to transition into using alot of R/C fuel the oil turned into sludge in the manifolds, it froze the EGR valve, clogged the throttle body vac switching passages, made a mess on the ACIS flap(varriable intake manifold) throttle blade & clogged the ISC. found oil in the AFMs bypass channel...
the conclusion we found was that it took minimal effort to get maximal gains by leaning the car via the o2 sensors until it was pulling timing out, then adding diesel back into it until it quit. no smoke, cruised like a champ and gained an easy couple of mpg. by the end of that & aero improvements we had the car doing no LESS than 31mpg on the highway and the combined mileage on it was nearly 30. (this on a car that never would do better than 18/24)
so im telling you via real experiance... if you put enough R/C fuel into an engine to do a shit, you're going to run into problems.
leave R/C fuel for engines that can burn it and have their oil feed from the fuel supply and run as a glow motor.
Post by: caged on August 23, 2009, 06:31:58 AM
Why does this sound like a crock of shit? How did it throw a spark plug out of the head after cranking?
Post by: Joseph Davis on August 23, 2009, 01:24:32 PM
Arsenio, I knew you had what it takes to fit in here... and to do it with a rotory of all things.  Fucking Awesome.
Post by: Toysrme on August 23, 2009, 05:50:24 PM
first cyl that fired shot the plug out the head with half the threads going with it. my first experiance with a heli-coil came immediately after that.
Post by: NoPistons! on August 24, 2009, 04:55:09 PM
Get some vids of this thing.
I bet it sounds insane.
Is it a full bridge or just bridged aux ports?
"there's only one guy in the city that sells nitro meth" -toretto
You have plenty of room to rock a v mount if you wanted to.  Remove the shroud, get an e fan from the junkyard and cut some vents in your hood like this [[[.   It's ghetto but it works and still keeps you stealth.
Post by: oinesra on August 24, 2009, 10:00:27 PM
It is was only half bridged, so just the secondary and auxiliary ports were bridged.  But I grew tired of fighting with it to start because of the rear rotor being messed up, so I just swapped in a junkyard motor until I can rebuild the other one.
This  'new' motor is pretty solid but the oil control rings seem to be going. It smokes a lot on the first crank up of the day. And obviously its a LOT slower, but I will just up the boost I guess.
I don't plan on using an electric fan any time soon. I just don't think that are as reliable or work as well as a clutch fan. I have used them in the past but they never cool as well as the stocker. And I already got the front mount worked out in my head, I just have to stop being lazy and do it.
Also, wile the motor was out I said fuck it and made a 3in downpipe with and adapter to the stock exhaust, cat and all...
I will see about getting a video of it with open down pipe though.
And I guess, thanks, JD?
Post by: Joseph Davis on August 24, 2009, 10:04:37 PM
Not needed.  You earned it on your own.
Post by: oinesra on August 24, 2009, 10:07:49 PM
HAh I was trying to be sarcastic but I suppose that dosen't play well over the online.
Post by: Joseph Davis on August 24, 2009, 10:35:13 PM
I am immune to your sarcasm.    :-*
Post by: oinesra on September 03, 2009, 05:43:25 PM
blah blah blah. I did a turbod my car, let me do post in forsale.
Post by: Joseph Davis on September 05, 2009, 03:33:41 PM
I'm all for it, but I had nothing to do with the n00b ban from the FS forums.
Post by: Kain on September 24, 2009, 02:25:57 AM
my car is better in every single way.
Post by: Tim on September 24, 2009, 08:26:44 AM
Kain every single car made is better than yours, they haul girls home to fuck.
Post by: Kain on September 24, 2009, 09:11:54 AM
even if its a meat wagon?
his shit is soo cobbled together and soo haphazardly put together. the ignition isnt even correct let alone proper fueling.
Post by: SloS13 on September 24, 2009, 09:18:27 AM
This is RealHomeMadeTurbo.com not RealUnhobbledAndNonHaphazardlyTurbo.com
Post by: Robb on September 24, 2009, 09:33:23 AM
So?  Its a rotary.  Its gonna pop one way or the other.  What does it matter if its today or tomorrow?
Pot, Kettle, black.
Post by: Joseph Davis on September 24, 2009, 09:52:44 AM
Pot, Kettle, black.
DO NOT LET AARON CAKE READ THAT HE WILL ARGUE WITH YOU ON THE INTERNET AND THEN BAN YOUR USERNAME ON FORUMS YOU COULD CARE LESS ABOUT
Post by: Joseph Davis on September 24, 2009, 10:18:05 AM
ok
Post by: oinesra on September 24, 2009, 10:37:49 PM
jealous
Post by: Kain on September 25, 2009, 01:24:25 AM
not in any way, shape, or form. not only do i not have a puke green engine bay, i am also not a mexican. by default, god has forsaken you.
Post by: junkyard racer on September 25, 2009, 05:57:20 AM
I dont think you own a rx7. never seen pics. i also have never seen a build thread.
did you build your car, or is it a shop built car?
Post by: j.h.christ on September 25, 2009, 03:35:00 PM
you're a balding midget greek that looks like equal parts lollipop guild and child molester who has never gotten his dick wet other than taking a bath.
joke's on you, friend.
also, this:
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi40.photobucket.com%2Falbums%2Fe218%2F1320feet%2Fkain2.jpg&hash=cf40ad8a803cf7c5bcd3a1c053a561c764d8127b)
Post by: oinesra on September 25, 2009, 10:29:47 PM
MY BAD! if that really is you kain, im sorry for talking shit to you. noe i see why you  act the way you do.
Post by: hotrex on September 25, 2009, 11:27:55 PM
kain is a faggot nigger pussy.  look at him. you know his dick is 3 inches hard  witha cornucopia of pubes surrounding the tippp
Post by: junkyard racer on September 26, 2009, 05:46:46 AM
I think you are the only one that thinks about kains peepee
Post by: Joseph Davis on September 26, 2009, 08:23:37 AM
I think you are the only one who thinks about how many other people think about Kain's peepee.
Post by: Kain on September 26, 2009, 10:17:45 PM
do i have to take pics every 5 seconds of what im doing?
Post by: Joseph Davis on September 26, 2009, 10:21:15 PM
Frank Pants takes pictures every 5 seconds, what's your problem?
Post by: Kain on September 27, 2009, 05:16:20 PM
frank has a camera fetish?
Post by: junkyard racer on September 27, 2009, 06:58:59 PM
something like that.
and no, but 1 of your car would be nice to see. So would a ripper vid.
Post by: Joseph Davis on September 27, 2009, 09:38:34 PM
HOLY SHIT KAIN'S CAR IS LEGIT AS FUCK I WANT TO GO DOWN ON HIM
Honest to god word for word AIM convo.
Post by: oinesra on October 15, 2009, 03:39:16 PM
Well, I got tired of the rivrts poping out from the lip every time it scraped something. And I didn't feel like redoing all of them with washers on the back, so I just got a lip from a early model s13. With about 15 mins. With the heat gun it bolted up like stock.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FIMG00004.jpg&hash=e4651c0dfef5fdd60afce4ec0dbd16bc5ff0edfd)
Post by: Patrick on October 15, 2009, 04:36:53 PM
pimp car, you should flat black it
Post by: Kain on October 16, 2009, 03:56:30 PM
or just dont be an idiot and paint it a regular color.
Post by: Aaron Cake on October 16, 2009, 04:45:56 PM
This seven is much cooler than my car. You sir, are my hero.
Post by: crxvtec91 on October 16, 2009, 04:54:22 PM
Word on the street is you ban people user names that disagreed with you when you say that rotories are the best thing ever, indestructable, and perfect in every way :?:
Post by: oinesra on November 08, 2009, 05:28:29 PM
got the turbo intake manifold and top mount in place.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FIMG00097.jpg&hash=9b30487e0d092cf143f7c5f3fc31e35be236e6c3)
Post by: Ntrain2k on November 08, 2009, 06:01:13 PM
Does the pepto pink add horsepowerz?
Post by: Joseph Davis on November 08, 2009, 06:07:43 PM
Oh, god.
Post by: crxvtec91 on November 08, 2009, 06:38:12 PM
Pink and blue..... :?:
Post by: junkyard racer on November 09, 2009, 03:18:40 PM
ban for being gay.
Post by: j.h.christ on November 09, 2009, 04:08:23 PM
ban for being like widebooty.
Post by: Robb on November 09, 2009, 04:51:32 PM
WHY THE FUCK WOULD YOU PUT A TOP MOUNT BACK ON??? ARE YOU A FUCKING IDIOT?!?
I guess so.  Ok.
Post by: ryan89crx on November 09, 2009, 07:07:17 PM
Post by: turbob16hatch on November 09, 2009, 07:18:01 PM
I seriously didn't mind your thread/build, but WTF were you thinking? i mean give me a fuckign break you can't think that looks good. and if you think it looks like dog shit(which you should or BAN) why the fuck would you put that on your car?
Post by: oinesra on November 09, 2009, 07:43:37 PM
Wait! You mean that you guys don't think this is cool?
STIs have pink on them. And my car is faster, so I need more pink then they do.
Post by: Ravage70 on November 09, 2009, 07:45:13 PM
Bend over I'll show you whats cool.
Post by: oinesra on November 09, 2009, 07:54:07 PM
You are going to put a picture of you sisters vagina on the ground in front of me? Or are you trying to make a move? Queer
Post by: Kain on November 13, 2009, 12:56:58 AM
I guess so.  Ok.
i run stock topmount but i inject copious amounts of fluids before the turbo and thus cooling it.
also, that charge pipe looks like this. if you knew any better, youd ditch that stock inlet tube to the TB, and get the tmic modified to exit the air just like the air intakes.
Post by: Robb on November 13, 2009, 12:04:11 PM
I take it you took basic physics in high school?  You do realize what happens when you pass excessive water in mist form through a condenser right?  Food for thought.
Post by: Kain on November 13, 2009, 12:58:33 PM
do explain. last time i took physics was back in 2004.
Post by: Joseph Davis on November 13, 2009, 01:00:52 PM
Maybe it isn't the rotory that's the failure, Robb.  Maybe it's the people owning them that fuck them up.
Post by: oinesra on November 13, 2009, 01:13:14 PM
Well, if you must know. I never intended to use this thing. I painted it pink and bolted it on.  It is growing on me thow.
I don't even have a vented hood, and ill be god damnd if im going to cut up a mint aluminum hood. Deff. would if it was a steel hood.
But after looking at the intercooler, I might get the core boxxed in and make it into an air to water unit.
And yes, it is the owners 90% of the time.
Post by: Robb on November 13, 2009, 03:48:32 PM
Sir, you can run that top mount all you want, your custom silicon hose makes up for it.  :noel:
Same thing that happens anytime you cool off water droplets.  Their tendency to "hold together" with each other increases dramatically.  Suddenly, that fine water mist you injected into your hot compressed air charge becomes puddles in your intercooler or your intake.  Ever see what happens to a hydrolocked cylinder/rotor/anything?  Water doesnt compress.
Has your car actually ran with this setup?  How LONG has it ran this way?  I hope also you are injecting more than just water...
Post by: j.h.christ on November 13, 2009, 04:44:50 PM
i don't
Post by: Minor Threat on November 13, 2009, 07:44:32 PM
i don't
HAHA
Post by: Kain on November 14, 2009, 01:55:12 AM
yes
6 months
100% wa wa.
Post by: oinesra on November 16, 2009, 06:18:14 PM
Someone take this paint from me. I can't stop myself.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FIMG00129.jpg&hash=aea86fd7e141a8cfa9dc21d7bdc2cf7631b3b778)
Post by: j.h.christ on November 16, 2009, 06:38:08 PM
you can't mask for shit either. wtf is wrong with you?
Post by: oinesra on November 16, 2009, 06:45:07 PM
The lip it tapped off perfect. I didn't care about the tire, some paint thinner fixed that...
And boredom will screw with your head. Don't have my license, so I feel the erge to do something to the car.
Post by: Robb on November 16, 2009, 06:46:35 PM
Your gonna have a silver spot where that weight is.  Be sure to keep some of that paint handy.
Also, +1 for conti tires.  I like em on the Porsche's.
Post by: j.h.christ on November 16, 2009, 06:54:50 PM
fucking wax it or something. clean the interior.
PUT DOWN THE FUCKING SPRAY PAINT
Post by: oinesra on November 16, 2009, 06:56:36 PM
Hey you are in north carolina right? Im going up to virginia the first week of december. Maybe I can stop by and have a few beers. Hell might even need a place to stay the night.
The paint is for fun, it will come off soon.
Post by: Robb on November 16, 2009, 07:48:16 PM
JD lives in my house.  You chill with him, and your chillin with me.
Post by: oinesra on November 16, 2009, 07:52:17 PM
but what im saying is we can go get drunk, and let nature take it course.
Post by: oinesra on November 16, 2009, 08:38:33 PM
Forgot this intercooler was in the attic. I got it from a dude with a h2b eg hatch. It weight about 20lbs. Core it 3.5x6x20  might have an issue with one outlet, but fuck it.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FIMG00131.jpg&hash=920813fd9571611ed5d22dc47d4474461bf6e849)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FIMG00130.jpg&hash=6707bbb8a7289ca438867386fd6922ada641078f)
Post by: Robb on November 16, 2009, 11:33:16 PM
Damn, I didnt know rotaries had VTEC now?!? Did Aaron Cake invent that too?  :?:
Post by: oinesra on November 16, 2009, 11:38:56 PM
dont worry about that piece of s. my roommate has been working on that shit for years, and it still dosent run..... hondas....
Post by: oinesra on November 22, 2009, 07:00:38 PM
Ok, no moar pink lip.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FIMG00155.jpg&hash=b6bb904f8e53f8dc01bb909cc288084012c86e93)
I still need to finish polishing the lip
Post by: Robb on November 22, 2009, 07:50:49 PM
IN for the ripper vids.  As I recall from my previous rotary endeavors, an FC will do one hell of a doughnut.  :noel:
Post by: junkyard racer on November 22, 2009, 09:44:54 PM
actually if that stupid auto camber bullshit is still inserted, a doughnut is somewhat difficult in a fc.
Post by: oinesra on November 22, 2009, 09:55:54 PM
it not 'auto camber' if anyhting it would be 'auto toe' and yes, I still have it in one side. The passenger side got fucked up wile doing the 5 lug swap so i made a new one out of radiator hose. and as soon as i get this slut back together and get my license back, i will make a ripper.
Post by: junkyard racer on November 22, 2009, 10:54:17 PM
auto camber, auto toe, fuck you. im drunnk.
Post by: junkyard racer on November 22, 2009, 10:55:39 PM
 :-X
sounds like you should get a moped and make a ripper vid with that
Post by: Kain on November 23, 2009, 04:14:31 PM
i do doughnuts all teh time in my fc, no auto bullshit being dissabled, and i have teh stock non turbo rear end ( that i plan on blowing up) i dont to burnouts cus of wheel hot.
Post by: Robb on November 23, 2009, 04:35:50 PM
Local guy ran 10's consistant on his 200k mile n/a trans and rear. I have long suspected that the n/a rear isnt as weak as its made out to be.
Post by: patsmx5 on November 23, 2009, 05:25:04 PM
Pretty sure those had the mazda 7" IRS, which is what all 94-05 miatas have. They are not weak, but will fail from wheel hop. No wheel hop, they don't break. Wheel hop, they break.
Post by: Joseph Davis on November 23, 2009, 10:40:41 PM
They are stronger than the engine is.
Title: My car rx7
Post by: D.Alomb on December 02, 2009, 11:00:33 PM
kinda sounds like whats happenin to me. boost is fine up to a point then the car starts jumping and flipping out, and I look stupid on the freeway... what i noticied was that my car was set to be at boost 14.7 and when i get to that speciific rpm, my boost was already at 14. so as i put more throttle I think my wastegate or w.e is set so when my car goes over 14.7 it cuts off fuel.. let me know if thats whats up . and how u go about fixing it.
Title: Re: My car rx7
Post by: crxvtec91 on December 02, 2009, 11:06:55 PM
Simple go get a tune, Omg that was hard :P
Post by: Joseph Davis on December 03, 2009, 10:14:34 AM
So that's your problem... you're a rotory guy.
Just make a n00b post complete with porn, we'll help you as much as we can.
Post by: arsenio on December 11, 2009, 11:05:16 PM
jesus fuck. timed out 3 times trting to post this shit.... if it dont go through fuck it.
get a fuel cut defender, or say fuck it and unplug the map sensor
Post by: arsenio on December 13, 2009, 02:58:03 AM
Traded the apexi bov for a set of charge pipes and rfl combo to my homeboy.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FIMG00186.jpg&hash=7b6e5d6421c81c8c89f4b1336ee279630637dfad)
Post by: jarebear667 on December 13, 2009, 11:47:02 AM
lets see some rippers before you fuck it all up, hope once you fuck it up you dont put another rotory in it.
Post by: arsenio on December 13, 2009, 09:11:45 PM
that a/c condenser was good for something.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FIMG00189.jpg&hash=680291af327c891d8dc2143aa8a6d0a71adbb096)
Post by: Robb on December 13, 2009, 09:51:21 PM
Solid work.  I have that same Husky ratchet/socket set.  :noel:
RFL's are junk btw.  Trade it to some riceboy for something that doesnt suck. Trust me on this one.
Post by: Joseph Davis on December 13, 2009, 09:54:26 PM
The real RFLs are okay-ish if you mount them in a cool dry place and lube them every other oil change.  Most "RFL" I see these days aren't real.
Mind, I wouldn't buy an RFL if I needed a BOV, but if I already had one I'd work with it.
Post by: arsenio on December 13, 2009, 09:59:55 PM
its real, and i already greased that bitch up. pipes already came flanged for it/ with it.
i would prefer not to hear a bov at all,  but i needed the frount mount since i had to sell the meth kit.
Post by: Robb on December 13, 2009, 10:03:02 PM
I ran a real one on my gsx and dustin on his talon back in the day, and we were scrounging in the couches to find enough quarter shims to keep the damn things from leaking.  No thanks. I'll stick to my 1g bov's and $25 plastic bosch valves.
Post by: arsenio on December 26, 2009, 06:15:40 PM
pink bed knob shifter:
USDM
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FIMG00198.jpg&hash=98a57d0d8ff1be858a32d714520723432ae04ce7)
JDM
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FIMG00197.jpg&hash=c3af740c724bda8c9bca2004f70cf3909f74fbcf)
And no SUPER SEXY LONG version because it causes to much noise.
Post by: PhilStubbs on December 26, 2009, 09:51:37 PM
have you taken that car to a VT dyno day before?
the more you post, the more i think i have talked to you
Post by: Joseph Davis on December 26, 2009, 09:56:06 PM
Here's the autographed picture he sent me... Arsenio's my hero.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi256.photobucket.com%2Falbums%2Fhh166%2Fjoeymisanthropy%2FARSENIO.jpg&hash=4d8578c69ce8538bf22d666c049e6758888ad4a9)
Post by: PhilStubbs on December 26, 2009, 09:58:59 PM
yea, that pic is what got me thinking. the guy i talked to had a shaved head, but im sure every guy with no hair had some at some point
Post by: Joseph Davis on December 26, 2009, 10:00:38 PM
You hear that, Arsenio?  This guy's thinking about you.
Post by: PhilStubbs on December 26, 2009, 10:04:01 PM
thats probably not something for him to be proud of or even care about. i am nobody
Post by: arsenio on December 26, 2009, 10:29:24 PM
yeah, i usualy keep it shaved, but said fuck it for now.
I havent been up to VT on a dyno day, but we go up there about every other week to do some cars.
 post a pic of your self.It might jog my memory.
 maybe you, marcj and i can have a circle jerk. :o
Post by: arsenio on December 26, 2009, 10:32:21 PM
on second though, i guess that would be a triangle/ tri-force jerk.
Post by: PhilStubbs on December 26, 2009, 10:55:50 PM
I'm not real interested in the circle jerk, but maybe we will end up in the same place at the same time one day. I already know marcj though, so there will be nothing exciting there. Ha ha.
Post by: Joseph Davis on December 26, 2009, 11:21:57 PM
SPAMMARC
Post by: arsenio on December 26, 2009, 11:27:18 PM
SPAMMARC
he was telling me that you had to put him in check wile playing WoW. I guess talking about stabing around little kids offends you?
Post by: Joseph Davis on December 26, 2009, 11:29:32 PM
No, he was talking in a graphic manner about his wife in front of my 12 year old WOW friend.  That, and it's fun to blame him every time I die whether or not it's his fault.
Post by: arsenio on December 26, 2009, 11:31:06 PM
Why the fuck do you have a 12 year old friend. WoW or not, that just kinda creepy.
Post by: arsenio on February 06, 2010, 06:08:19 PM
Fuck all you bitches.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FIMG00225.jpg&hash=20c46b0715765b65e1c03f8016d161f5f6654dde)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi157.photobucket.com%2Falbums%2Ft66%2Foinesra%2FIMG00227.jpg&hash=616cf1ed9dea8d28747111bba8f2ba40824b9147)
No more open downpipe.
Post by: jarebear667 on February 07, 2010, 11:52:46 AM
hahaha fuckin ghetto only thing that sucks is that flex doesnt last long but it might outlast that rotory.  :P
Post by: PhilStubbs on February 07, 2010, 08:19:15 PM
i ran one for quite a while once. lasted just fine and i still have it kicking around in my garage somewhere
Post by: arsenio on February 28, 2010, 07:48:01 PM
Finally got a day off with decent weather. Got the charge pipes ran and the pink top mount ran up front.
Now, I have ridden in cars with RFLs, and herd them when they drove by. Yes they were loud, but Jesus Christ, this one is obserd. The first few times it blew off, it sounded like you would expect from a RFL. But on a second gear pull, 10 psi, 7900rpm shift, this fucking thing sounded like a Tie-Fighter zooming passed me. A lady that was walking her dog actually jumpped back when it went of.
I have a feeling that I will be bombarded by civics trying to race me.
Post by: PhilStubbs on February 28, 2010, 09:31:14 PM
i doubt you will have any real competition from any civics in town. a stock rx7 should be able to spank 90% of the civics that look your way
Post by: NoPistons! on March 08, 2010, 01:20:27 AM
I turned into the 50 percent of the turbo loving lot that believes bovs are stupid......
I'm stupid so i suppose it's whatever.
I thought for a minute that you had a t70 on your car....you just happened to be selling one on BrotaryHaterClub a few months ago.....
I did a quick edit on my post.
Let it be known i'll be installing a gt3582 on my whip.  Full ching chong apex seal busting dont give a fuck if it breaks shit.  As long as Rene Franco is able to stand behind the stuff he sells, i'll buy it and do my best to make it work.  Lol.
Post by: Robb on March 08, 2010, 11:56:55 AM
What are you gonna do when the broken apex seals take out the turbine wheel on your faggot gt35 that cant be rebuilt? Throw more money at it like the rest of the rotards?
Post by: Joseph Davis on March 08, 2010, 03:58:14 PM
Some of the PacNW crew have rebuilt them.  I wouldn't want to have to, though.
Post by: Kain on March 08, 2010, 04:59:39 PM
ah... you assume this happens. with stock apex seals its rare, however carbon seals destroy everything.
Post by: arsenio on March 08, 2010, 05:16:59 PM
Again, kain proves he dosen't know what he is talking about. If anything, carbon apex seals would do the least damage.
I was never selling a t70 anywhere. I was selling the turbo kit off my car, but driving a n/a car is fucking lame, so I put it back on.
Post by: turbob16hatch on March 08, 2010, 05:31:42 PM
Thats why you get rotory aviation seals and they just bend in submission and loose compression.
Post by: NoPistons! on March 11, 2010, 01:26:23 AM
It's non-ball bearing, faggot.
RA and stock seals ftw.  Superhard race seals are for RACE TEAMS.
RA seals period are the shit.  The apex/side and rubber seals are awesome.  Hopefully that's what my buddy is rebuilding his fd with if he can every take time off of work.
There's a long list of things that cause rotary death.
You can have a nice, high powered, RELIABLE rotary engine but you need to tune it properly and run MORE fuel than you THINK you need....which pretty much throws my whole plan to keep the gas mileage somewhat decent (for a rotary) out the fucking window.  Since i'm stuck with my spinning triangles (i'm not getting rid of my rx7, sorry) i figured i'd educate myself in what it takes to keep them from blowing up while making some decent numbers.
My friend's fd died due to too much boost and not enough fuel.  Some sort of solenoid problem with the stock twins or it being off tuned for how cold it was outside.  I dont remember exactly.
What i'm getting at is you match the turbo and boost to your fuel and motor and make sure your tune is perfect as well as monitoring and datalogging everything.  Air intake temerature played a role in the failure of my friend's car.  Shit it can happen to any engine but tuning and balance is everything.  Safely on my stock doweled block i'm looking at 350 max using only an aftermarket bad ass oil pan to aid in keeping the engine plates from shifting.  I'm still trying to decided what management i want to go with (power fc or greddy emanage ultimate i guess) and what injectors i'll need to keep a rich tune and low egt's.....  I picked the turbo for it's fast spool and response as well as exhaust flow working out well with stock exhaust sleeves/ports.  It wont choke the engine up and can make 400hp easy at 15 psi spooling at around 3000 rpm.  Not that i'm after that but the turbo just fits the job and i like the fact i can change housings and wheels as i please with ease because of how much support the journal bearing gt's have and after seeing the dyno sheets on some third and second gens i can't argue with it's performance.
I figure n/a shortblocks are cheap enough to really not give a damn about losing a seal or a housing so i've made up  my mind to stick with it regardless of what my friends or some people on the internet say about the rotary.  They aren't fuel efficient but are very boost efficient and are reliable with the right modifications.    Most of my reliability mods are underway now.  Clutch, driveline, cooling, cdi ignition, stri gauges, wideband.....  I've had to cut back on smoking, eating out, partying and buying beer on the regular but it's worth it.
Post by: Robb on March 11, 2010, 10:18:12 AM
You are delusional sir.  But as long as you are throwing $$$ away, toss some in my paypal account would ya?  :-*
Post by: arsenio on March 11, 2010, 12:01:39 PM
Sixports are where its at.
I have used rotary aviation, atkins and stock. For a long term motor, mazda 3 piece is the way to go. For high boost, I would say aviation seals, but they beat the shit out of the housings, but are cheap.
For a daily that you want to make power, mazda two piece seals are the way to go.
A sixport motor with ported middle plate and exhaust is all you need for 350.
I wouldn't bother with pinning and oil pan braces untill you are stepping into the high 400hp range.
I have yet to blow up a 13b that was built with new seals. All the junk bin motors let go within a year though.
Post by: arsenio on March 11, 2010, 12:09:30 PM
Also, I cut a huge fucking hole in my hood!
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi39.tinypic.com%2F1zget5x.jpg&hash=390dd23e66620f34df243afffb230a03276efa95)
Post by: Joseph Davis on March 11, 2010, 02:07:03 PM
Post by: NoPistons! on March 11, 2010, 04:54:11 PM
Do you mean mazda 3mm or mazda 3 piece.  My engine is using 2pc seals from pineapple iirc.   I'm not cracking the engine open unless i have to.  Seriously.  If it works out and makes 300+ i'm happy.  If it grenades or something else fucks up it wont be a surprise but i'm hoping everything will be ok.  I have a while before all the parts are gathered up but i did get a good deal on the turbo, wastegate and manifold....  Ching chong cheap.  I really dont care if it holds up or not.  Like someone else said, i love pissing money away.    JIc coilovers and a-tech wheels bn body kit, re-amemiya 2 way lsd.....$2000 rebuild on the engine.......   Way over $7k invested in the shitbox as it is in less than 2 years.
Post by: arsenio on March 12, 2010, 01:16:24 AM
I ment the 3 piece 2mm seal. The ones they don't make any more.
Don't mind robb, hes a closet rotorsexual.
7G's huh. you really do like to piss money away. witht that kind of cheese, you should have a bad ass 7 by now. I think im in 2G's, including the $700 for the car.
Also (https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi42.tinypic.com%2F3505qbl.jpg&hash=d728e5aefe5708f6cefdabed328ea4954b0d4a48)
Post by: NoPistons! on March 12, 2010, 05:57:06 AM
That is really fucking disturbing.
Post it on rx7club and link the topic on here!
As far as how i invested in my car, i built it backwards i guess.  I dont regret it.  I'm having fun with it and it doesn't seem like a chore to me to work on it.  Shopping and gathering research is a chore though....  The actual work doesn't bother me at all.
Back to the vent in your hood and more pics of the car and non-vomit inducing photoshopped porn.
 This is your fucking thread!!!!!!  Continue with the fc goodness.
Post by: 2slow on March 12, 2010, 06:37:37 AM
cris benoit would never be caught alive in a rx7. he would rather choke his son to death then to be seen in one of those
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi257.photobucket.com%2Falbums%2Fhh240%2FTW1NTURB03KGT%2Fcris.jpg&hash=f3069d4186d52fbbba6cdae54177a94f5e0c2a54)
Post by: Robb on March 12, 2010, 12:18:49 PM
Arsenio, im comfortable in my hate for the rotary engine.  :noel:
Post by: Joseph Davis on March 12, 2010, 12:35:25 PM
