General Category => Forced Induction => Topic started by: toyolla86 on November 11, 2009, 02:28:12 AM
is there a step by step how to rebuild a turbo thread yet.
There was on OHMT, but more or less just take shit apart and put it back together as clean and well oiled as possible. There arent a whole lot of parts in a turbo, and if you disassemble it yourself, take some pics so you know how it goes back together. Im sure there are some writeups somewhere, just google "how to rebuild a turbo"
On a side note, I recently had a lengthy conversation with a Borg-Warner research tech, about how quickly turbos will unbalance themselves. Basically after statically,dynamically, and harmonically balancing one, you can heat/load it up, then recheck the balance after it cools and it will be out. Not by much, but they attribute it to shaft warpage (cant visibly see it of course). Interesting tidbit.
wow that sucks.
well im thinking i better rebuild my cdm turbo.
ive priced them from 50-130. is any one kit better than the next.
wow that sucks.
I can vouch for G-pop. I just rebuild a k03 this morning using one of their kits, and they have never done me wrong.
wow that sucks.
G-pop is where it is at. :noel:
yeah their prices are a little higher but they really make ordering the kit much easier.
i feel like they know what theyre talking about
do they have a coupon code
Only time I did it, it felt apart. I mark both sides to so I could have a point to line them back up with. Lasted a hole 3 blocks :?:
wow that sucks.
where can i buy new wheels for a k03s?
i think gpop has them. ive called them before and priced turbine wheels.
altho i never bought them.
looks like ill be calling that guy back.
i gotta make sure the turbo is rebuild able.
i may just go with a 14b.
what does everyone think rebuild a 16g or buy a real 14b.
the 14b should spool faster for my little 1.6. plus i dont run super high boost. ill probably top out at like 10-12 psi
T3
http://www.dsmtuners.com/forums/articles-turbo-system-intercooler/316421-t3-turbo-rebuild-part-1-a.html (http://www.dsmtuners.com/forums/articles-turbo-system-intercooler/316421-t3-turbo-rebuild-part-1-a.html)
http://www.dsmtuners.com/forums/articles-turbo-system-intercooler/316422-t3-turbo-rebuild-part-2-a.html (http://www.dsmtuners.com/forums/articles-turbo-system-intercooler/316422-t3-turbo-rebuild-part-2-a.html)
TD05/06 so would be any mitsu based turbo more or less
http://www.dsmtuners.com/forums/articles-turbo-system-intercooler/303828-td05h-td06-turbo-rebuild-part-1-a.html (http://www.dsmtuners.com/forums/articles-turbo-system-intercooler/303828-td05h-td06-turbo-rebuild-part-1-a.html)
http://www.dsmtuners.com/forums/articles-turbo-system-intercooler/303829-td05h-td06-turbo-rebuild-part-2-a.html (http://www.dsmtuners.com/forums/articles-turbo-system-intercooler/303829-td05h-td06-turbo-rebuild-part-2-a.html)
hope this helps.
hope this helps.
FYI this dude says he torques them back to 100inch/lbs. Factory spec for TD05 is 16, I see no reason to tighten that much, but its your turbo so whatever.
16g=10x the turbo of the 14b, but only if you fix the failure internal gate.
well for right now i found a good 14b locally for 70 bucks.
that should take care of the oil leaking into my intake.
we'll see if its a good rebuild job or not.
last time i drove it, it was making noises at full boost. (unhealthy sounding noises)
kinda sounded like a nice spool ssssssssss then to a scraping shhhhhhhh
so like ssssssssssssssshhhhhhhhhhhhhhhh
just picked up the 14b. looks like its in great shape.
zero shaft play.
wicked fun turbo for a street car
