General Category => General Discussion => Topic started by: Joseph Davis on December 04, 2009, 02:39:25 AM
Is 564 whp and 418 wtq at 7200 rpms, Mustang dyno numbers, before the slicks ripped free of the rollers considered H22 power?
Thanks.
si :mexi:
Not bad seems O0 to me
what snail/boost?
im assuming not jeremys car... IDK how your "ripping" slicks loose unless you cant strap the car down well though
Thanks, glad you approve.
It's a T4 footprint 60-1, 30+ psi, and a 100 shot.
And not an H. O0
And not an H. O0
Z6?
And not an H. O0
on a 100 shot??? Uhhhh ok... ID hope youd see more than that
And not an H. O0
Z6?
Same displacement, only gayer than a slow car with a blue dashboard.
And not an H. O0
Z6?
D-series, 30+ psi, and a 100shot, will turn you out
And not an H. O0
Strap your car to a Mustang, post the results. If she broke free on a Dynojet at the same point it'd read 650 whp.
And not an H. O0
Brain I may be out of my skull but this could be a vitara D16. the boost level and and rev limit and 564 with the nitrous.
OH nooooooo not a fucking Y8. Someone needs kicked in the Ballzz. what a fucking waste of effort and money for spun bearings
D?
OH NOES
Too much torque for a b16, it has to be a d if its a honda. But we don't want to ASSume anything, that JD is a tricky mother fucker. And its true, he's fucked at least a mother or two, probably more.
Reread, stooges. 7200 rpms is when it lost traction at that power, before the nitrous we were making peak power at 9100 rpms. :mexi:
Well its your own fucking missleading fault. You said same displacment but GAYER. there is no gay at all in a z6 a z6 is the best sohc D you can get and theres no gay to be found in one. The only honda motor that I can think thats commonly used in our circle thats gay is a y8. a6's are not gay........wait a
This not it becuase it has larger displacment but I have to mention a 4g63 because a 4g63 would under acheave like that at 30 psi and spray.
I dunno man with the y8 eliminated the b16 is the only other gay honda motor. It would have to be sleeved though to make it that far...........No thats retarded why waste build cash on a b16 when you could use a gsr and be way better off. It could be a moms credit card build though.
Well I made 459ftlbs and I only broke free on the dyno for a small portion so maybe you are doing something wrong father
That dyno was operated by BMW owning canadian's so it dosent count
It was a mommy credit card build before it caught some wheelhop and cracked the driver's block mount, Stuart traded a bike he had $2400 in for it. Stuart might have $4500 in the car now. You'd like Stuart, not only has Dave B tuned his old turbo H22 Del Sol but Stuart fuck's Sewell's mom. He also has a '04 Honda 400EX with an R6 swap + 75 shot. Good people.
I can't get you to stop fucking your sister for five minutes, son. How do you expect me to get a non-family member to buy a real engine and a real turbo?
So its a b16 then? I don't know what else would make power at 9100 rpms with 1.6l of displacement
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fwww.swappedandboosted.com%2Fimages%2FZC.jpg&hash=da4031e6c1b3b01d9958f998b1165d16d671cb15)
ford engine?
does not apply to ZC..
how does it not apply?
do you consider the ZC to be a homosexual engine? Tom is going to ass-rape your mother with one of his $49 800whp manifolds
b16 is my guess
b16 w/sleeves.....
b16 w/sleeves.....
who would be retarded enough to dump $1k sleeves into a $50 block that is more useless than the $50 itself?
b16 w/sleeves.....
Sir, how much of the population do you perceive as intelligent?
b16 w/sleeves.....
exhibit a: all the jdm queerboys
b16 w/sleeves.....
it seems that i might be overestimating most of the world. i cant imagine it takes much than a small amount of common sense to realize how useless a b16 is
You guys are being a little harsh on that poor little b16. They've done good things before. Really. But give me an LS any day of the week.
im partial to the D
d16a1
d16a1
Has it kicked any rocker arms out?
zc
d16a1
zc
KO O0
super jdm zc powa
F20B
4G61
K20Z2
F22A1
LS9
D15B2 ;D
Guys, I was reallly frustrated about this so I called JD. I had to give him my mother's phone number, but he finally came out with it. It was Bisi's d16 build. He called JD after he was unable to make over 420whp on his own. JD strapped it on the dyno and with his magic tuning knowledgeabilities, they made the numbers said here before the massive torque from the d16 blew the rollers apart. Since it hit the 500 mark, and there was still 5000rpm's to rev out (thanks to bisi's super all moter skillz) Bisi is going to assume it was going to make well over 700hp, so he is coming out to the press in the next week to say his d16 make over 800hp, on 87 octane to boot. Good work, JD!
EW4
EW4
best sounding honda motor ever
http://en.wikipedia.org/wiki/Toyota_A_engine#4A-GE_.2820-valve.29 (http://en.wikipedia.org/wiki/Toyota_A_engine#4A-GE_.2820-valve.29)
or
http://en.wikipedia.org/wiki/Mazda_B_engine#B6ZE.28RS.29 (http://en.wikipedia.org/wiki/Mazda_B_engine#B6ZE.28RS.29)
With obd1 Honda ecu. Otherwise I can't think of anything else 1.6L worth a damn.
Your mother is a great motor as i motor skillz to sux my cack off :yes:
...dude?
...dude?
Sweet.
ShÃbby
WTF who typed that shit..... DARYL did I leave myself logged on your computer? If so your a fucking NIGGER
ZC CRX bitches, that's all you need
I'm pretty sure it was this guy.
widefool.mp4 (http://www.youtube.com/watch?v=dzqFkPxv69Y#normal)
OK. but now time for engine/setup details.
Sleeved B16, 60-1 compressor with a T4 footprint, 100 shot.
d16a1
at 9100 RPM?
(http://javascript:replaceText('%20:?:',%20document.forms.postmodify.message);)
EDIT: Should have read the last few replies.
B16 may be gay, but it is still better than H22 faggotry.
Spiker...
Or my third one.
Or my third one.
Mreh...
this makes me think my 60-1 is kind of useless if it took a 100 shot to get over 500whp
maybe I should sell it.
edited cause of shitty iphone posting.
You'll make plenty of power on that high reading ricer dyno you frequent, this was a heartbreaker Mustang.
you think sewell's dyno is high reading? he must have told me otherwise to make me feel better
He gives the best footrubs.
but no Sewell Racing air fresheners. i am so pissed cause my car smelled bad after i left there and i was expecting the ride home to smell nice
Shoulda got the sewell racing condoms. 20hp out of the box ;)
Tuners have been know to fart on customers seats while on the dyno.
Edited for your stanky ass cdm car.
I've never seen a cheap ebay turbo make anywhere close to what a "real(insert garret, holset, borg, etc etc here)" one makes.
[/quote]
It happens time to time.you think sewell's dyno is high reading? he must have told me otherwise to make me feel better
Mine reads the same as a mustang, well within about 1%.Shoulda got the sewell racing condoms. 20hp out of the box ;)
Only the top notch customers get those :P
Only the top notch customer's mothers get those :P
i have a real 60-1 not chinese. i have never had it on when i have been there though. i was saving it for another project, but JD has me worried now.
check yo PM's Honkey(sewell)
You had some cdm shit, when your at my place :yes:
the 60-1 is still a good turbo, i've made over 500 on a few of them.
thats what i wanted. an even 500whp. any more is a bonus.
i was pretty impressed with that CDM trash for daily driving though.
