Pages: 1 [2] 3   Go Down
Author Topic: Since, I'm not counting on Buk to make me a manifold... btw nsfw  (Read 60493 times)
Re: Since, I'm not counting on Buk to make me a manifold...
« Reply #30 on: March 10, 2010, 05:53:38 PM »
So you didn't get anything done tonight??????
Modded T-stat is in the car.
clipped the brass bleeder thingy, drilled to .220" then 4 small .120" holes at the bottom of the T-stat.
Doubt it will help, but I was bored. Forgot how well the Y8 ED Slushy likes to move out for what it is.
too many holes, i did that shit once and my car never got above 140
That would be fine for the time being, that way the crack won't open up and push out coolant
« Reply #31 on: March 10, 2010, 05:54:43 PM »
Just upgrade radiator/coolant lines, run a high pressure radiator cap, and don't worry about it.
already have that, running 1" thick AZ rad. in place of the normal 5/8".
« Reply #32 on: March 11, 2010, 11:35:31 PM »
Bone go get your crackhead fixed in hybrid tech...
anyway...  here is what I did today...
can you see where this is going?
got in touch with my feminine side...  by breaking out the pink...
and took another dip...
« Last Edit: March 11, 2010, 11:39:41 PM by Foowee »
« Reply #33 on: March 11, 2010, 11:39:13 PM »
Looks bitchen.  Can't wait to see how you do the 2 and 3 runners.  Those look really tight.  God dnamit, NSFW this fucking post already too.
Re: Since, I'm not counting on Buk to make me a manifold... btw nsfw
« Reply #34 on: March 11, 2010, 11:54:34 PM »
yeah I'm gonna have to figure some figures on 2 n 3...  if you look at the last pic of the heat shield you can see where I'm gonna bend it...
« Last Edit: March 11, 2010, 11:56:06 PM by Foowee »
« Reply #35 on: March 12, 2010, 04:49:37 PM »
I am impressed with your fab work sir. Also the porn needs more pink
Atticus
« Reply #36 on: March 12, 2010, 11:00:08 PM »
Looks good man. Don't forget about the dip stick when mocking up 2 and 3.
« Reply #37 on: March 13, 2010, 12:51:23 AM »
heard across the river.....
"damnit!"
« Reply #38 on: March 13, 2010, 01:04:35 AM »
Y7/Y8 = no more problem with dipstick!
« Reply #39 on: March 13, 2010, 07:12:13 AM »
I may have to put a bolt in the center stud hole...  fuck a y7/y8, I've never spun a bearing n I don't plan on starting now...
2slow
« Reply #40 on: March 13, 2010, 08:29:18 AM »
what do you expect when browsing this site? i expect porn, racism, homophobes, and turbo shit
« Reply #41 on: March 13, 2010, 09:39:25 AM »
http://www.acestainless.com/index.php?act=viewProd&productId=6
$21 ea. is a bit steep, but I guess I probably need 'em.  What do y'all think?
Atticus
« Reply #42 on: March 13, 2010, 02:23:34 PM »
First time I bought mine from the local plumbing store about $10 each. (mild steel)
« Reply #43 on: March 13, 2010, 04:50:03 PM »
Go get a normal 90* bend and start cutting. I fit pipes in tight spots like that all the time. You will need to cut say a same pie section from the bend then cut another these "pie" cut section can form many different angle and fit in tight spots.
To make it easier to cut just tack weld 2 90* bends together in oposite directions. I use this technique alot to fit pipes.
have fun, it will take time.
clwtwizted
  • Fuck You!!!
« Reply #44 on: March 13, 2010, 05:55:24 PM »
Shit looks good.
NoPistons!
« Reply #45 on: March 17, 2010, 01:01:01 AM »
I love everything about this thread.
The only thing to make it sweeter would be to reveal the entire thing was mig welded........
« Reply #46 on: March 17, 2010, 08:33:15 AM »
It is.  I'm using a hh140 w/.030 308l n trimix(90%He7.5%Ar2.5%CO2) n I've also got a spool of .030 309l for flange joints.
The hobart has enough ass to melt the pipes together, but going to the flanges is another story.  Thankfully I have access to decent 220 miller.
I should be getting my short radius bend in the days to come...  and the weather is supposed to be nice so progress is in evitable...
clwtwizted
  • Fuck You!!!
« Reply #47 on: March 19, 2010, 03:19:30 PM »
what do you expect when browsing this site? i expect porn, racism, real men, and turbo shit
Fixed it for you.
« Reply #48 on: March 19, 2010, 04:35:56 PM »
This thread is full of WIN! Keep up that  O0 work!
« Reply #49 on: March 19, 2010, 11:07:56 PM »
Made quite a bit of progress today...
Then I went to the track to watch everyone else run :(
Time for another bath 'cause I'm covered in metal shavings and smell of tire smoke...
« Reply #50 on: March 24, 2010, 01:05:51 PM »
make sure you oval those runners out before you weld it to the head flange otherwise youll be motherfucking it when you try to put bolts in and they are getting caught on the welds.
« Reply #51 on: March 24, 2010, 02:30:00 PM »
Quality work sir
« Reply #52 on: March 24, 2010, 03:22:18 PM »
Werd  O0...  The shop that has the welder I need to do the flanges also has a massive vice.  I haven't forgot about that part...  I cleaned all the burrs out of the pipes n got the merge welded up today.  It'll probably be complete over the next few days.
« Last Edit: March 24, 2010, 04:03:33 PM by Foowee »
« Reply #53 on: March 30, 2010, 08:31:56 PM »
you have done well for yourself.
i didnt think those center runners would turn out that good!
« Reply #54 on: April 12, 2010, 10:18:21 PM »
I got the flange joints done...
2 n 3:
1 n 4:
y'all know the drill:
hatchboy
  • Bombs Over Baghdad
« Reply #55 on: April 12, 2010, 10:21:20 PM »
I spy breakclean charge pipes!
« Reply #56 on: April 12, 2010, 10:24:24 PM »
I've been saving starch cans, cause they're 3 inch...   :yes:
I need to hand out some props too...  This wouldn't have been possible without the help of these folks:
-bmcrace
-acestainless
-Adrienne Manning
-weldingsupply.com
-Dave Weber(moobs from the k head carnage thread)
-Lauren Michelle Hill
-The Beave(He's a cool dude even though he listens to Old Larry Widdy)
-Melissa Midwest
-china freight(cause $9 4inch angle grinders rock!!!)
« Last Edit: April 12, 2010, 10:51:45 PM by Foowee »
The_Beave
  • The Red Tape Avenger
    • Beaver Built Blog
« Reply #57 on: April 18, 2010, 12:25:46 PM »
:P to you, too, jackass!
Looks very good, man.
Not so obvious and ruthlessly odd.
Fab blog: http://beaverbuilt.blogspot.com
hatchboy
« Reply #58 on: April 18, 2010, 12:37:34 PM »
Noob post?
« Reply #59 on: April 18, 2010, 01:56:31 PM »
Noob post?
theacidbeaver ain't no noob.  He is one that reeks of badassknowedgeabilties...  if you pay attention to him you might learn a thing or two...
Pages: 1 [2] 3   Go Up
