Pages: 1 ... 38 39 [40] 41 42 ... 47   Go Down
Author Topic: UI's 703hp Purple beast - She is injured  (Read 832362 times)
Re: UI's 703hp Purple beast - She is injured
« Reply #1170 on: June 17, 2010, 04:47:44 PM »
Well cams have been measured, the center lines match up. Only issues (that would have nothing to do with the engine failure) are that some of the lobes are out of square and some bad grinding on the base circle. Plenty worthy of warranty, and getting your money back, but not why the piston and valves were kissy kissy. Levi have you talked to the shop that degreed your cams yet?
« Reply #1171 on: June 17, 2010, 05:06:08 PM »
The issue with that is, just because they were "degreed in properly" doesnt mean there was sufficient p2v or v2v clearance.                Even though we know they weren't degreed in properly.
Anything on the valves that indicates v2v??
« Reply #1172 on: June 17, 2010, 06:47:29 PM »
V2V is nearly unheard of on a Honda.  The valve seperation angle is sinply not wide enough for it to be a practical concern - save in weird situations like this one.
« Reply #1173 on: June 17, 2010, 07:36:19 PM »
My moneys on p2v but the cams being degreed wrong( intake cam was fully advanced) tightens p2v on the intake side.  I swear i seen p2v marks on the number 3 piston but Passanger says he inspected them better and they weren't there, so idk.
No OS valves this time though.
« Last Edit: June 17, 2010, 07:38:19 PM by sewell94 »
« Reply #1174 on: June 17, 2010, 07:44:21 PM »
Obvious.
Negative.
Its just weird that there isn't evidence of contact on any of the other cylinders, for both failures.
Its bothering me that there isn't something absolute, or perhaps there is and I have just overlooked it, adding to my frustration.
« Reply #1175 on: June 17, 2010, 07:55:32 PM »
Post pics?
« Reply #1176 on: June 17, 2010, 08:03:34 PM »
« Reply #1177 on: June 17, 2010, 08:05:18 PM »
The usual head/chamber and piston face pics.  I doubt I can pick anything out if you can't, but A) it can't hurt and B) I'm curious.
« Reply #1178 on: June 17, 2010, 08:15:12 PM »
I'll get some pics, on the failed cylinder you can't see much, iirc at least two valve heads are off and scattered/impregnated in the head and piston.
« Reply #1179 on: June 17, 2010, 09:15:11 PM »
Hype r cams (W stock gears), white size vlaves... Turn up boost on turbo to LET THE TURBO make WHPZZZZ...
Cams and gears could be sold on HT to fund the down (up?)grade.  Success......
Simple enough solution to the fucking cam niggery and other fail...
Toooo simple????? Maybe if there was a chrome font????
« Reply #1180 on: June 17, 2010, 09:50:25 PM »
You might get Paul Wall to sponsor the car?
narfdanarf
« Reply #1181 on: June 17, 2010, 11:40:25 PM »
I disagree completely.  The same exact thing would have happened to me if I hadn't done a V2V check on my car, and I personally know of a few people who have had the same thing happen.  There is a reason it says on the tech sheet that skunk2 gives you with the cams "Do not use these cams with oversize valves"  The pro1's are pretty close it is even ok if you back them off a little from centerline, but with the pro2's and pro3's that's a big negative.  This is based purely on personal experience.  V2V has been much more of a concern with the motor's I've put together over P2V.
« Reply #1182 on: June 17, 2010, 11:43:09 PM »
yep i know por1s at true 0,0 will have v2v contact with stock valves
« Reply #1183 on: June 18, 2010, 12:29:23 AM »
It still seems funny to me that the thing ran for a few hours, often bouncing off the rev limiter, than with no evidence of anything slipping, there is collision.
« Reply #1184 on: June 18, 2010, 12:39:23 AM »
seems funny to me that the motor was "degreed in" and the intake gear )IIRC) was advanced all the way and none of you homos thought it odd...   O0
« Reply #1185 on: June 18, 2010, 12:58:30 AM »
Oh I thought it was odd, I mentioned it to Tom, and he kind of ignored it because the car was running really good. That is why no one did anything, the car was running the best it ever had. And while this was ignorant, and we should have done something about it, its still weird it ran so good for so long before failure. I've just never seen a mechanical failure like this where the timing belt or cam gears hadn't worked themselves loose.
« Reply #1186 on: June 18, 2010, 01:08:32 AM »
Fuck you, I thought it was odd, i got emails/pm to levi saying i didn't think it was right, because he sent me pics of the cam gears. I also stated it the night before we tuned the car. I've done enough pro1 cars to know that the gears either end up with 4 degrees seperation or 0 degrees depending on which version they are.
I never ignored it or you at all. We had a conversation the night before, and i was like i dont think its right, And that i didnt feel comfortable moving them that if you guys wanted to move them it was your decision.
I also spent the whole time on the dyno saying somethings not quite right.
No use letting someone point a fat finger to get a bunch of BS/bickering started.
« Last Edit: June 18, 2010, 01:51:46 AM by sewell94 »
« Reply #1187 on: June 18, 2010, 01:09:52 AM »
Fuck you
Fuck it makes me hard when you talk to me like that....  :-*
« Reply #1188 on: June 18, 2010, 01:38:08 AM »
Fuck you
I'm glad that i can excite you.
You will never get this  O0
« Reply #1189 on: June 18, 2010, 02:18:45 AM »
I'm not pointing fingers. We both agreed we didn't think it was right. And we both figured it was running pretty good the night before the dyno. Nothing has changed since I talked you last, right after it blew up. I said it wasn't your fault and I meant it. If I felt otherwise I would just say it. I don't "hint", I tell. :-*
« Reply #1190 on: June 18, 2010, 03:19:53 AM »
hahahahaha
got me good
« Reply #1191 on: June 18, 2010, 03:39:39 AM »
Its not Toms Fault. Nobody ever said it was.
We will figure this shit out, not to worry.
« Reply #1192 on: June 18, 2010, 04:47:59 AM »
Fuck you
As hard as his snoring gets you?
« Reply #1193 on: June 18, 2010, 05:06:23 AM »
Fuck you
I snore so loud, i've woken myself up O0
« Last Edit: June 18, 2010, 05:15:29 AM by sewell94 »
« Reply #1194 on: June 18, 2010, 12:59:33 PM »
The deer in the lights look followed by the quick steamroll to the corner of the room as i trioed to snuggle (fuck) you was hilarious....)
I chose your hair over Levis boobies
« Reply #1195 on: June 18, 2010, 01:03:32 PM »
Tommy's wop mop is the stuff fantasies are made of, huh?
Don't mind me, I'm just the resident angry bald guy.
« Reply #1196 on: June 18, 2010, 01:05:47 PM »
I hate to say this, but I actually respect you at times, whereas Toms sluttish nature just begs for fucking.
« Reply #1197 on: June 18, 2010, 02:44:03 PM »
Just not in the morning, right?
« Reply #1198 on: June 18, 2010, 04:59:20 PM »
« Reply #1199 on: June 18, 2010, 05:09:32 PM »
Hellllllo.... Immmm MR ED...
Am I the only one seeing it???
When you do.... yull shit Brix
Pages: 1 ... 38 39 [40] 41 42 ... 47   Go Up
