Author Topic: Super slow build / twin scroll hx35 rt4wd civic wagon  (Read 39348 times)
Re: Super slow build / twin scroll hx35 rt4wd civic wagon
« Reply #30 on: November 26, 2012, 11:59:33 PM »
I really want to try a set on the grm car. What is that adaptor for on the top, just dropping the o-ring size? I drilled my current rail to run bigger o-rings than stock.
My current injectors I picked up used and originally came from fuelinjectorclinic.com. I can't get good drivability to save my life on this car. Idle sucks no matter what I do and starting sucks hot or cold
The adapters are to reduce them to 11mm Honda rails. If you remove the 3 spacers in the D/B rails, they will fit perfect in 14mm fuel rails. Or I have the cheaper 800cc injectors that will fit like stock except I have them with the larger 14mm o-rings too.
Danz has my 800cc's running a D15 great, so you shouldn't have a problem (unless it's not the injectors). I could swing a real crackhead price since your budget is tracked in GRM. Of course I wouldn't mind some advertising in return.
Here is a picture of the 800cc's cut from 14mm to 11mm to fit a Honda rail:
« Reply #31 on: November 27, 2012, 11:16:12 AM »
I am interested in talking about crackhead prices. I have my own decal cutter so I can plaster whatever you want on the car. To end the threadjack I'll pm you with what space is available on the car
« Reply #32 on: December 03, 2012, 08:15:12 PM »
I know where you should put the sticker:
« Reply #33 on: December 03, 2012, 10:13:46 PM »
Kumho has already taken that spot
thagreenteam
« Reply #34 on: December 04, 2012, 10:15:27 PM »
As far as the build goes I don't think much will be happening to it for a while. I am working out in Meridian, Ms for about a month (or longer) until I get a better offer that is, hopefully, coming up in SLC, Ut
Only time I am going home for a while is on holidays, to see my baby being born in March, and in April to take my CWI test. Who knows, something might get done on the holidays when I'm home.
thagreenteam
« Reply #35 on: December 09, 2012, 03:29:23 PM »
Sorry to disappoint, but I can not finish this turbo build. I don't have the desire anymore to have a turbo car. I need to just get back to enjoying the car as it is, and back to my desire to ride motocross again.
Motor is for sale if anyone is interested.
FS: Sleeved/ O-ringed D16z6, Endyn head - Houston-Imports.com
« Reply #36 on: December 09, 2012, 04:20:08 PM »
I wish I had the cash I'd buy this.  :noel:
thagreenteam
« Reply #37 on: December 09, 2012, 04:37:49 PM »
