What type of manual tranny fluid do you use in your Honda?
Honda MTF
- 8 (22.2%)
Cheap 10W30 motor oil
- 14 (38.9%)
Royal Purple
- 5 (13.9%)
Other
- 9 (25%)
Total Members Voted: 34
Author Topic: What type of manual tranny fluid do you use?  (Read 28118 times)
TWOLOUDnPROUD
Re: What type of manual tranny fluid do you use?
« Reply #30 on: May 02, 2009, 01:36:35 PM »
My last honda tranny i used Rotella oil 15-40 in it for two years with out any problems :yes:
« Reply #31 on: May 02, 2009, 05:10:12 PM »
I've been wanting to try that myself, but has been two years without a manual tranny equipped car. Thoery is the extra zinc will add some cushion.
« Reply #32 on: May 02, 2009, 09:27:18 PM »
That be the case, add some ZDDP additive to your regular oil and you save a little resistance from the lighter weight oil
Ever look into graphite?
turbo4life
« Reply #33 on: May 05, 2009, 04:10:50 AM »
usually 10 30 anything
75-140 gear oil in crx ls trans did not want to shift on a cold morning but 3rd did not grind
20-50 vr1 valvolin with zddp adative
wokrs good just change it as needed dail driver can go 30 k
track car
1k racing miles  (road coarse) not weak sauce straight line 'n
End the fake food.
hotrex
« Reply #34 on: May 06, 2009, 04:01:18 PM »
bg syncromesh 3
