Pages: 1 2 3 [4] 5 6   Go Down
Author Topic: Good bye trick slut (kinda) Hello white power.  (Read 82285 times)
Re: Good bye trick slut (kinda) Hello white power.
« Reply #90 on: October 23, 2013, 01:53:13 PM »
my truck is being a bitch right now, has a vibration at idle and hesitates cruising. i probably need injectors. COCK
« Reply #91 on: October 23, 2013, 02:38:27 PM »
Plan is to SPIN my streetcar down the track Sunday quicker and faster than Fagmodes wrong wheel steer "Racecar"  has ever been........
....the first time its ever been on slicks... Barring getting kicked out for going way too fast or breaking a tranny.
This motor is insane the power it made. 30-40 more on pump with 2 LBs less at it... 670 on meth and pump at 23.5 pounds (It made 604 or some shit on 29 last time) and still maxxed the fuck out at 750 on Racegas and meth at 32, with fuel left.
Being it made stuppppppppppppppppppppppppppid power last week on the rollers... ITs pretty fucking realistic.
so What did it do at the track?
flat_black
« Reply #92 on: October 23, 2013, 10:31:24 PM »
Lol nice quote
« Reply #93 on: October 24, 2013, 02:54:58 AM »
Get my truck back with the built PATC tranny in it on Monday.
Cant wait! Warrantee covered almost all of it.
Wastegate wired shut, build the new air ram  and install the grid delete.
Edge juice back in it and left on 5 LOL  :)
Alto red eagle power packs with extra clutch disks and kolene steels
Oversize overdrive spring
All sonax billet servos,
Oversize Carbon solid band
billet band anchor and strut
Billet apply arm
Transgo Shift kit
Sonax manual valve
GM billet gov solenoid assy
PATC super single billet convertor - Billet apply piston with billet velocistator with 500 RPM lower stall
Dyno tuned and all.
Car went 11.20 at 132 on soft boost launching it trying to save axles... 1.95 60. Letting out...  Incredible part was it was holding 23.5 PPSI in 3rd fucking gear... we nevver ran it with the whole meal in it. Got some very good info... Need to get a REAL H22 Pass side axle (broke 2 with preloading) and Launch it like I dont give a fuck and even shifting it like a girl 10s are there... No problem. Only made 3 passes... None all out, none full boost, none shifting hard and none with better than a 1.95 60 being scared of the axles breaking.
Last run of the day we had it setup to leave making 17-18 PSI on the antilag, 22 in 2nd, 25 in third and 35 in 4 and 5....  Axle broke and I didnt have time to get another one. First time it broke we cobbled one together in the pits...   Went 11.7 on a 2.3 60 shifting slow and letting out at the end... Trying to figure out BBG settings. Both Ros and i were fucking amazed how much power the car was putting down early....Broke an axle on the next pass 3 feet out, cobbled together a clusterfucked axle out of spare parts and ran the 11.20 at 132  on the 1.95 leaving nice and no ton kill still, shifting slow (Shift events show .5-.75 second shifts)
Next pass we set it up to let it fucking eat (Raised the launch RPM as it was kinda bogging on the hit and boost to NOG in all gears. I left HARD. Axle broke. Done for the day LOL. Like I said, It will run in the 140s, mid tens with one more event worth of seat time and axles in it  ;)
I was fucking amazed with how easily the car went straight and how well it hooked. It was litterally almost driving itself, smooth as fuck and straight...They said they were going to use the rest of the years worth of VHT for the day because the weather was cold and they werent lying. This fucking thing hooked like a motherfucker. We actually had to raise the launch limiter...
Getting a PS axle solution and a cage put in it.. Dad was aking about what we need to do to put a bigger turbo in it but I dont htink I want to. Trannys coming out for a look since thats ALOT of power it put down and all the big WHP dyno pulls, but theres nothing noticable wrong (thank god)....
Veryu successful Seat time and shakedowns. Motors healthy as fuck and shes ready for a cage :)
Pops
Passed tech (Guy checking the car laughed his ass off when I opened the hood)
Getting fuel
6.5 PSI cold in the tubes of the 26" MTs... (Tried to get the hubcaps to work, but the lip is too deep, but didnt have to do SHIT to get them on, just took off the MHs and put em on and there was room).
Shell be going to the track more next year.
Made 550 WHP on straight 92 at 16 pounds  (took 17-18 to make 520 on the old motor)
Guillaumes porting and the cams doiing work, Compressor happy, but on racegas it got curbstomped into the wall. It needs a bigger turbo on it. Made 750 again spinning the tires on the dyno... Around 500 TQ, but took 35 falling to 32 pounds instantly  to get there... Turbo is DONE. I sprayed meth on the C16 to and there was plenty of fuel for more WHPZ.......
Pump and meth 23 pounds revving to 9K bitch....What....:O)
« Last Edit: October 24, 2013, 03:07:36 AM by bigdaddyvtec »
« Reply #94 on: October 24, 2013, 06:40:16 AM »
It's sad you had to SELL it for it to see the track! lol
In for 9's... :evil:
« Reply #95 on: October 24, 2013, 09:43:12 AM »
Trubo to small for the power?
« Reply #96 on: October 24, 2013, 11:18:58 AM »
Fuck yeah! Let me know next time you go to the track you nigger! I want to go!
flat_black
« Reply #97 on: October 24, 2013, 09:42:46 PM »
Prelude still went faster... just saying
« Reply #98 on: October 24, 2013, 11:20:40 PM »
I'm good with that. Preludes been to the track more han once too... you alrady know what was happening the last pass lol....... Howd the airbags blowing up in your face when the axle broke in the 240 at the 330 mark feel ;) that was nuts hahaha
« Last Edit: October 24, 2013, 11:28:15 PM by bigdaddyvtec »
flat_black
« Reply #99 on: October 25, 2013, 12:07:59 AM »
It scared me i pee'd a little... finding parts for S14's sucks...New dash from Nissan is 1200 bucks... i may have one lined up.. we'll see
gringotegra
  • Smoking Bisimoto's Builds, 1 Car At A Time
  • BISIMOTO KILLER!!!!!!!
« Reply #100 on: October 25, 2013, 06:06:49 PM »
Good job on the car at the Track and getting it back togethers!
« Reply #101 on: October 28, 2013, 09:56:02 PM »
Talk is cheap.  :-*
« Reply #102 on: November 19, 2013, 07:57:45 PM »
yay they came, the filter setup is awesome.
« Reply #103 on: December 17, 2013, 02:53:28 PM »
runs great with the +50hp & +100ft-lbs!
gunna smoke the tranny already felt like shit with the ONE wot pull.. 2nd to 3rd shift slippage
« Last Edit: December 17, 2013, 06:19:59 PM by random-strike »
« Reply #104 on: December 17, 2013, 06:18:06 PM »
« Reply #105 on: December 19, 2013, 06:31:02 AM »
I ve been working on it. Bitch is alive and well... Got the hot unlock code for the EDGE box (Level 6=150 WHP and 350 TQ)... Feels fucking great. Tranny is up to the task now and giving me no shit... Truck is fun to drive :O) Level 6 on the edge box runs hot quick... Tax time Ill be putting a BW FMW 362 or 364 on it (Staying single)... Definately help with the EGTS, then EFI live and a REAL TUNE on it... But I can run the 100 HP tune (250 TQ) and rape it hard now with the little supporting shit Ive done.
Built a homemade 4" Aliuminum tube for it:
Infinity Reference door speakers, Kenwood double DIN DVD install (Did the bezel myself one day I got bored, dont like the look of the nav bezel setup)
Put another coat of paint on after this pic, cant see the rings anymore :)
Fosgate 200.1 bridged into 2 ohms and 2 Fosgate dual voicecoil 10s in a B-Box.
Have most of my fuel system upgrades, just need to get the Holley 150 Pump I plan to run...
Got freebie Heater delete spacer from Dave , and a couple flanges to fab up my own horn (Also fabbing new FMIC chargepipes). Had to mod the spacer, number 1 injector line rubbed
So got off my butt and bought a 3" Stainless U bend this weekend  and mocked up my  intake:
Welded it up:
Adios pindeho:
Hola ola :O) :
Next ill put the 2 micron filter setup in it. Needed to get this done beforehand to figure out where brackets need to go. Still waiting on fittings and stuff to get here. Have everything else. After that... Tax time, S362FMW @ or S364 and EFI Live.  :)
Edge JWA is for sale (Its hot unlocked now).  EFI live, Insight CTS and CSP are next after the tubo upgrade :)
« Last Edit: December 19, 2013, 06:38:53 AM by bigdaddyvtec »
« Reply #106 on: December 19, 2013, 12:50:10 PM »
Looking good, but for the money an S362 or S364 are, why wouldn't you throw an S475 under the stock charger (port the wastegate on it) and rock that? Bigger powerband, cooler, and more power potential.
That is what we ran on Tmathis's dually.
« Reply #107 on: December 19, 2013, 04:50:05 PM »
nice, i like that intake tube. make one for me for free thx
i'm gunna get efi live in the near future too. not gunna push it until trans stops and gets rebuilt though
« Reply #108 on: December 21, 2013, 03:02:35 PM »
THE STRUGGLE IS REAL
« Reply #109 on: December 23, 2013, 03:19:47 PM »
Got the rest of my stuff for the 2 micron fiter setup... All the AN -6 pushlock line... pushlock 90s, fittings for the CP3 and OEM filter etc... So got busy with a ruler and some carboard...
 prototype stuff in posterboard  LOL...
Yall know I love mocking shit up in posterboard....
Here is the mount that will bolt to the front 3 holes on the head just forwaerd of the plunum lid.  It sits the filter head just under my air horn  :O)  Ill go get some steel tomorrow and get it built ASAP so I can put my baldwin in the OEM canister and run the big WIX 2 micron between it and the cp3. I wanted it high as possible to eliminate siphoning when changing it, and also my pressure gauge will be coming right off the filter head right at eye level with the hood open. More pics soon of final install  :O)
flat_black
« Reply #110 on: December 23, 2013, 08:46:59 PM »
brodozer brian loves teh trucks..
« Reply #111 on: December 29, 2013, 10:31:01 PM »
flat_black
« Reply #112 on: December 29, 2013, 11:04:16 PM »
SWEEET bracket FAG!
« Reply #113 on: December 30, 2013, 02:44:49 PM »
Work it will, just like your mama out on Pac highway fgor 4.65 a BJ  :)
« Reply #114 on: January 07, 2014, 03:14:00 AM »
Well, finally put the Baldwin filter/seperator in the OEM canister and ran my -6 AN plumbing from the OEM filter can to the 2 micron setup I built for my truck this morning :)  Weird, the wrinkle coat looks like crap in a couple of the pics... Looks great in person. Meh :O)
Using a NAPA filter head, WIX 2 micron filter, all -6 pushlock AN fittings and earls fittings 12mm x -6 and 1/2 NPT x -6 I had lying around, some -6 fuel rated hose and a 30 PSI liquid filled gauge mounted to a bracket I built out of some 1/8 inch steel and a piece of round stock. Totall invested including gauge is about 130 with EVERYTHING.
Changed out the Baldwin, removed the old line... installed the pre filter line (already flushed and blown out of course), then mounted the filter. Cut the line from the WIX to the CP3 to length, blew it out... Then installed it and bumped the key till i got fuel in a jug. Attached the end to the CP3 tightened her up and it fired without a hiccup first turn :O)  Pressure gauge confirms I needs me a lift pump. Thats next. 12 PSI cold at the WIX, 10 warm.. Im sure it falls on its face from there.
Hope ya like :)  Trying to figure out what Im going to do for a lift pump... Im thinking a Holley billet Black (Non vane style)... With my own pickup modification to the stock basket and a -8 feed to the Baldwin... I dont want no 1/4 tank issues even though I typically never let it get under 1/2. All the basework at that point will make it ready to put on EFI Live and make some power...
Ill sell the Juice, get a EDGE insight CTS and EFI CSP5 setup. IF Tom ever gets back to me with prices figure out if its the 362 or 364 is going on it... Im not trying to put twins on it.
Install today:
« Reply #115 on: January 07, 2014, 11:36:52 AM »
If you are dead set against twins. Which I cannot fathom why, with a $650 S475 below that stock charger it will be great for anywhere from 450hp-800hp+, have a bigger powerband, run cooler, ect...
Do the 364. A 62mm charger just isn't enough of an upgrade over the stock 60mm charger to be worth the money spent. A stock charger will do ~500hp yes it will be a hot 500hp, a 62mm charger will do a hot 550-575.
If you do end up with the single, and are going to get rid of the stock charger let me know, I starting to put together a set of triples using a couple stock HE351cw's.
« Reply #116 on: January 07, 2014, 06:16:49 PM »
364 it will be.
Its what Ross had me talked into... Just need to understand wastegate shit on these things better and what to do.
SImplicity... Also ease of working on
Random Hero
« Reply #117 on: February 16, 2014, 09:00:52 PM »
fuck you, i need more credit for this shit i do for you! lol, go twins hoss.
« Reply #118 on: February 17, 2014, 07:18:16 AM »
Ya, fuck. twins.... It is. 475 and port gate? Like port the FUCK out of it?
And if I do that alot of people go to an earlier manifold to but the Holeslut "UP" more... Do that too cuz Id really like to have the big 457 on the top LOL, only poss prob I could see would be the DP, but theres ALOT of room.
« Reply #119 on: February 17, 2014, 11:09:21 AM »
Twins bitch!
Pages: 1 2 3 [4] 5 6   Go Up
