Author Topic: manifold dilema - mild steel inline 6 log manifold  (Read 105223 times)
7808
Re: manifold dilema - mild steel inline 6 log manifold
« Reply #30 on: January 26, 2015, 05:28:07 PM »
1.5 sch pipe size would be overkill in a honda, (for manifold runners) 1.25sch has a od of 1.66
JohnHandcock
« Reply #31 on: January 26, 2015, 05:44:34 PM »
I suppose to pick up some  today but ran out of time. Im have to bust out the tig welder O0
« Reply #32 on: February 12, 2015, 08:37:28 PM »
you guys got any tricks for notching out pipes to merge them into another at 45 degrees without a fancy shop full of tools?  ive been just straight cutting them at the angle then using grinders and grinding wheels to "round" them out to lay against the straight pipe nice, takes forever and sucks
« Reply #33 on: February 13, 2015, 12:34:11 AM »
Old English 800............. probably the worst tasting malt liquor in the world.
weirtech
    • Weir Technologies Inc.
« Reply #34 on: February 13, 2015, 12:40:03 PM »
if you have access to a mill, a holesaw would do it.  anther option is a plasma cutter.  make a template and trace it onto the pipe and cut as much as you can with a vertical band saw or an angle grinder.  proper tools can make life much easier.
« Reply #35 on: February 15, 2015, 06:20:30 PM »
got one for $38 after sale and coupon. cutting 1.25 sch  at a 50-55 degree angle is pushing this thing but it works fine.
http://www.harborfreight.com/pipe-tubing-notcher-42324.html
« Reply #36 on: February 16, 2015, 07:22:13 AM »
Usually those tend to be offset to one side and you need to shim the sliding ring.
7808
« Reply #37 on: February 22, 2015, 02:57:55 PM »
this should work
« Reply #38 on: February 24, 2015, 03:11:41 PM »
I like this  :noel:
« Reply #39 on: February 25, 2015, 01:16:46 AM »
Looking good
7808
« Reply #40 on: February 27, 2015, 12:26:29 AM »
what I love about mig welding.. its pretty easy to fill large gaps by dragging a puddle across, and im pretty good at it because I suck at measuring and planning
messed up, didn't leave enough room to sneak a down pipe past runner 6, had to cut it off and re make it with 2 45s, ended up warping the flange pulled up on that end. had to get creative. I sliced the runner back apart and shoved a piece of steel under #5 and bent it back down using the bolts to pull it. it was pretty bad now its pretty good
« Reply #41 on: March 25, 2015, 03:50:06 AM »
ya so I pretty much cant fit a wastegate pipe off the manifold anywhere, kinda built my self into a corner.
im thinking about using some 1" OD tube I have and taking a branch off each of the two main runners into a little collector into my 38mm wastegate.  anyone know if this would work ok?
« Reply #42 on: March 25, 2015, 11:39:29 AM »
I don't see why it wouldn't work.
Eggylshatch
  • Pen15 Club President
« Reply #43 on: March 26, 2015, 12:27:33 PM »
Sounds pretty normal to me, and looks like it should be easy enough to do where those two long segments run parallel
Re: -
« Reply #44 on: May 21, 2025, 02:24:40 PM »
I know its probably a stupid question, but what do you think would be better for a 4 branch, mild steel or stainless ?  Been reading the recent posts about manifolds cracking and what not and wondered if a mild steel one would be better. Im assuming mild is softer than stainless ? Just wondered if it could cope with the vibration / heat stress better as it is slightly more flexible.
Besides, I need a manifold, I can weld mild, and Im really poor
Again with replying old posts  :?:
For lower cost use mild steel, use thick walls and good wire/rod for the material.
For cheap log manifolds, search on here some excellent ideas.
Seen people use weld els, plumbing pipe, fence posts, and the like.
Main thing is use supports/braces, think about the weight of turbo, wastegates and flanges hanging about brace help cut cracking done to a minimum.
