Pages: 1 ... 5 6 [7]   Go Down
Author Topic: New econo car - broken POS - build up thread  (Read 143535 times)
Re: New econo car - broken POS - build up thread
« Reply #180 on: January 09, 2020, 09:58:23 PM »
Sold Cobalt today
« Reply #181 on: January 10, 2020, 08:33:38 PM »
got magnaflow 24" put on my RAM today. sounds great. how the truck should've came from the factory. not loud but actually has great sound. very happy
« Reply #182 on: January 13, 2020, 04:46:17 PM »
bought this 98 ls1 z28 for 2500 bucks on craigslist yesterday. i had to drive to bremerton, wa to get it tho. it was raining super hard the whole way up there and off and on heavy rain / slushy snow on the way back.
the guy bought the car for ls swap into his nova and ended up not doing it. it sat for 2 or 3 months with the t-tops leaking so it was wet inside but i got to it before there was any mold or real damage. someone put wood panel stickies onto a lot of the interior pieces LOL. has 130k and a4.
it runs and drives really nice its a steal for 2500 bucks. i'm going to put some elbow grease into it and get it fixed up nice. i started peeling off the wood shit on the drive home
has k&n lid, SLP loudmouth exhaust and the tips were put on backwards lol... it had a CEL on the way home and by the time i got back the CEL went off and stayed off. never checked to see what it was
PROS:
cheap
straight body with no dents
runs & drives great
decent wheels
SLP exhaust
shift kit or programming in transmission
everything inside works (power windows/power locks/power seat/power mirrors/cruise control)
CONS:
mismatched bald tires on every wheel
windshield wiper motor bad or broken / bent tab in mechanism wipers work fine but stop in the up position
goofy interior pieces
t-top leak
no T-STAT or broken T-STAT (never heats up fully but gets hot enough to have some heat)
backwards exhaust tips
headlights stuck on brights
brake rotors slightly warped but still stops good
headlight rubber seals messed up
no key fobs
belt sequel
cheesy messed up tint, especially on the rear hatch window (can't even see out of it)
already bought:
long tubes
t-stat
serp belt (installed right away)
275/40/r17 tires
drilled / slotted rotors & ceramic pads (same as ones i put on cobalt)
o2 extensions
2 new black 3.5" exhaust tips (same i put on cobalt)
bow tie valve stem caps  8)
« Reply #183 on: January 14, 2020, 09:28:27 AM »
PROS:
cheap
runs & drives great
decent wheels
SLP exhaust
CONS:
t-top leak
no key fobs
belt sequel
already bought:
long tubes
t-stat
275/40/r17 tires
o2 extensions
« Reply #184 on: January 14, 2020, 12:40:12 PM »
Google photos sucks I'll upload somewhere else in a bit
« Reply #185 on: January 14, 2020, 01:31:10 PM »
« Reply #186 on: January 14, 2020, 03:38:16 PM »
Not bad. I'd put some stock headlights in it.
« Reply #187 on: January 14, 2020, 05:09:27 PM »
i wouldn't buy them but i really don't mind it so much.
my gripe is with the brights being stuck on, they cut the wires to the normal lights so they wouldn't be on at the same time lol
i'm 90% sure its just the little rod that goes from the switch through the column and into behind the dash, it gets loose or whatever and just needs adjusted... i haven't had time to even get under there and just manually turn them off lol
« Reply #188 on: January 15, 2020, 04:32:24 PM »
car looks much better with the right sized tires
« Reply #189 on: January 17, 2020, 03:04:09 PM »
« Reply #190 on: January 20, 2020, 07:57:04 AM »
Looks like rolling racism
« Reply #191 on: January 20, 2020, 02:57:43 PM »
OK
Pages: 1 ... 5 6 [7]   Go Up
