Pages: 1 [2] 3   Go Down
Author Topic: should i trust shot peened rods?  (Read 44769 times)
Spanish-rice
Re: should i trust shot peened rods?
« Reply #30 on: May 15, 2009, 07:27:52 PM »
i get my car dyno tuned every spring and its usally spot on. i stay just below 12:1 in the high R's in boost and dont see any spikes with my wideband. idk how to really judge tune quality other than saying its street driven and ive never gotten less than 35mpg highway on E85 at my full power level. seems good to me but i guess i cant compare it to a known GREAT tune
« Reply #31 on: May 15, 2009, 07:31:52 PM »
well its not a base map. I know guys that thing a basemap is a tune.
I dont know if leed is still running his stock b18, but I think he was putting somewhere in the range of 450+ on stock internals. But its a top notch tune!
« Reply #32 on: May 15, 2009, 07:40:20 PM »
alright another question then. how much power would you assume a stock internal ls vtec could hold?
ls vtec what?
Spanish-rice
« Reply #33 on: May 15, 2009, 07:53:09 PM »
ls vtec what?
im just thinking if that bottom end is already done we could put it together with the ls bottom end instead but that raelly doesnt make sense with a brand new built head on a bottom end that im nervous about reving past 7
« Reply #34 on: May 15, 2009, 07:54:40 PM »
See what did i tell you about thinking. haha  ;D
« Reply #35 on: May 15, 2009, 08:07:40 PM »
all i got to say is that seems far fetched to say they don't stretch when making considerable hp.
but then again this info is coming from the guy who said mini-rams boost creep  :-*
Horsepower is a compressive load and has nothing to do with tensile loading, which is the only load the rod bolt recieves.
I said piss poor wastegate angles cause boost creep.  Have you read Maximum Boost, or any other basic primer on the subject?
I'm sick of you arguing with everything I say not because you disagree on some factual, physical, theoretical, or first hand experience level but because you don't like me.  Either emit some tech from your cumtrap or you're gone from this site. I can make that happen real quick, asshole.
« Last Edit: May 15, 2009, 08:09:22 PM by Joseph Davis »
« Reply #36 on: May 15, 2009, 08:51:51 PM »
take a joke buddy
and i was discussing the topic, i'm not a motor guru nor do i say i am, i was simply thinking out loud.
and i would say you need to chill on the defensive reading.
« Reply #37 on: May 15, 2009, 09:12:07 PM »
zc
« Reply #38 on: May 15, 2009, 09:15:32 PM »
take a joke buddy
And I get this in my PMs:
also you have yet to say you were wrong on that mini-ram that i built. so don't yell at me when your the hypycrit.
Fuck you, dude.  You built a manifold with a wastegate exit that required the exhaust gasses to turn tighter than 90 degrees, I pointed it out and that it was a problem at low boost, and when it was pointed out the car had a 15 psi wastegate and was going to be a track vehicle I said oh that's okay then it'd work fine for that. AND THEN YOU FLEW ALL OVER ME ABOUT IT LIKE I DIDN'T KNOW WHAT I WAS TALKING ABOUT DESPITE DEALING WITH BAD DESIGNS FOR A LIVING.  Do you know what inertia is?  You dont blow air in one direction and have it magically do u-turns because it wants to take a scenic route.  Divergent and convergent merge collectors are used for a reason.
How about you do two things for me?
1) Open up Maximum Boost and look at the pretty picture of the shallow angle divergent wastegate exit on the 25 year old F1 car.
2) Stop arguing with everything I say, in multiple threads, on a non-factual non-logical level.
« Reply #39 on: May 15, 2009, 09:21:34 PM »
wasn't arguing you stupid fucking  O0
« Reply #40 on: May 15, 2009, 09:22:24 PM »
zc
« Reply #41 on: May 15, 2009, 09:23:23 PM »
Yeah, I noticed.  What you are is an idiot who can't grasp simple concepts.
« Reply #42 on: May 15, 2009, 09:23:55 PM »
Your a fucking idiot arent you?
HP has absolutely nothing to do with the tensile strength of a rod bolt. Piston speed and mass are the limitations of the rod bolts.  When a piston/rod is on the power stroke, its forcing the rod down on the crank, the bearing shell and oil wedge take the beating, not the rod bolt.  Power has little to do with it.
« Reply #43 on: May 15, 2009, 09:24:19 PM »
zc
« Reply #44 on: May 15, 2009, 09:27:40 PM »
250HP ALLMOTOR h22 Crx Testrun
stock rod bolts in h22's like 9600 rev limiter
« Reply #45 on: May 15, 2009, 09:35:16 PM »
 :o
« Reply #46 on: May 15, 2009, 09:39:34 PM »
i think the same people who came up with the idea that rods bolts need to be changed decided block guards were a good idea.
« Reply #47 on: May 15, 2009, 09:43:47 PM »
ok i will put this disclaimer on my question so JD shuts the fuck up.
why would they put "upgraded" hardwhere on eagle's if it was not needed?
there JD i asked a question :'(
« Reply #48 on: May 15, 2009, 09:53:14 PM »
ill counter your question with a question. have you ever seen the "non upgraded" hardware on eagle fail?
« Reply #49 on: May 15, 2009, 09:58:09 PM »
Don't you have enought powa to ban him already? JD always say the truth. And even when its not the truth its never wrong.
« Reply #50 on: May 15, 2009, 10:01:21 PM »
No idea
« Reply #51 on: May 15, 2009, 10:11:21 PM »
then they obviosuly do it so people like you who actually think they would sell hardware thats too weak and make them feel like they are getting something extra in the deal.
ive yet to hear of a sinlge rod bolt failure other then some honda tech faggots who heard someone that knew someone that had them fail, meaning the person was a retard and fucked something up and blamed it on that.
« Reply #52 on: May 15, 2009, 10:20:20 PM »
You remember the early Eagles that had the bad rep for having a small rod bolt?  The ones Jojo Callos made 1200 whp with on a bet, and then ran that engine for a season with no failures?  Why did they upgrade that hardware since it's obviously not needed?
The answer is simple, they "upgrade" hardware to satisfy no nothing faggots who talk about shit they don't understand, and can't understand even after it's been explained to them 3-4 times.
« Reply #53 on: May 16, 2009, 01:54:30 AM »
Oc
« Reply #54 on: May 16, 2009, 01:38:51 PM »
The so called upgrade also in some cases increases rotating mass if the boss area of the rod is enlarged to handle the larger fastener. (usually you try to reduce it)  Look at some of the shit the cup cars are running now.  6mm titanium valves, 20mm wrist pins, Honda big end rod dia., etc.  Bigger isn't always better, afterall isn't that now why imports get some respect.
Also, Shot-peening does not increase the strength of a rod or any other component, it merely relieves surface stresses, to help reduce the chance of a fracture to form.
« Last Edit: May 16, 2009, 01:41:43 PM by Conceptz-X »
« Reply #55 on: May 16, 2009, 02:19:40 PM »
JD your wrong, these fucktarts do understand; the word "UPGRADE" so clearly it has to be better for a reason :P
« Reply #56 on: May 16, 2009, 02:57:13 PM »
the word "UPGRADE" so clearly it time for a music video
Beyonce Commercial
« Reply #57 on: May 16, 2009, 03:25:08 PM »
turbo4life
« Reply #58 on: May 16, 2009, 05:20:46 PM »
jdm UPGRADED always justifies it self so stop arguing jd.
End the fake food.
« Reply #59 on: May 16, 2009, 10:02:26 PM »
Don't ban anybody. Noobs won't learn anything if ya ban em everytime they repeat some honda tech bullshit.
Pages: 1 [2] 3   Go Up
