Pages: 1 2 3 [4]   Go Down
Author Topic: **The Shuttle Lives** 412.80 HP, 4th gear Kenny Rogers roaster!!  (Read 52061 times)
QikEnuF
Re: **The Shuttle Lives** 412.80 HP, 4th gear Kenny Rogers roaster!!
« Reply #90 on: August 26, 2009, 10:29:33 PM »
get some wheel liners too.. looks like you drove in the rain. your tires proly picked up a lot of sand and put it up by the hood hinges and along the rocker moulding, it sits in your door jam/rocker moulding and scratches the bottom of you doors.
HAHAHAHAHAHAHAHA
/thread
« Reply #91 on: August 26, 2009, 11:38:52 PM »
  I'm in the process of tearing some shit apart. We DID have to swap in that oil sammich, had it leak a little, had the hose pulled off the top of the black box for a couple pulls, etc..
  I'd be concerned if it was constant smoke, but it seems like it's every couple minutes, usually after the few 4th gear rape sauces I've done.
« Reply #92 on: August 27, 2009, 09:14:51 AM »
RAPE
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #93 on: August 27, 2009, 11:00:47 AM »
I read this shit last night but was to fucked up to realize what was up.
Your car = hottness
WOT
  • The Canadian
« Reply #94 on: November 28, 2009, 07:07:56 PM »
Congrats on finishing it up
« Reply #95 on: November 28, 2009, 07:59:45 PM »
When I had smoke upon deceleration it was the head that was leaking oil past the valves.
« Reply #96 on: November 28, 2009, 10:55:27 PM »
Thanks.
  The block is torn down now for winter. Bigger plans to come for spring. Nothing super crazy, just working out the shit that is less than superb.
« Reply #97 on: November 28, 2009, 11:02:45 PM »
what was wronge with the block???
« Reply #98 on: November 28, 2009, 11:07:59 PM »
Well, the high rpm stutter seems to do with the fuel supply, whether real, or simply having too small of a filter on it. That fix for winter was a given. I did a compression and leakdown before I stored it, and the numbers weren't that great. 155's +/- 3% across. Leakdown numbers were anywhere from high normal to 38%, so I tore it down. Seems there's a scratch in a wall from a ring, and the piston/wall clearance seems way loose, but I haven't measured it yet. Gonna do larger IM, cams, TB, etc. and just decided to freshen up the whole thing.
If work picks up a little, I may look for a sleeved block, but I'm not sure.
« Reply #99 on: November 29, 2009, 01:58:31 AM »
you spent 10 years building that pos and dyno'd it went wot 4 times and are taking it apart.
roll that entire car into a lake
BangBusMaster
« Reply #100 on: November 29, 2009, 02:21:31 AM »
haha
« Reply #101 on: November 29, 2009, 02:45:47 AM »
yep buy a 5.0  :yes:
« Reply #102 on: November 29, 2009, 02:52:44 AM »
What is your compression ratio to have 155 on cylinder?
Btw, are the pictures overexposed the bad weather or it's like that where you live. Never seen a picture of you car without rain...
« Reply #103 on: November 29, 2009, 12:25:04 PM »
about 9:1 on a healthy motor i'd say
« Reply #104 on: November 29, 2009, 12:30:29 PM »
Shit my Ls is 175 on all 4 with 8.0:1 comp. Sounds like you got some problems for sure. Hope it all pans out for you.
Eggylshatch
  • Pen15 Club President
« Reply #105 on: November 29, 2009, 12:34:36 PM »
yeah i think a 9:1 should be around 180-185
« Reply #106 on: November 29, 2009, 12:44:57 PM »
it depends how you take the test also...
« Reply #107 on: November 29, 2009, 01:46:40 PM »
True, but there's no denying that there is something wrong with the motor as he had a 38% leak down.
WOT
  • The Canadian
« Reply #108 on: November 29, 2009, 05:57:43 PM »
Oh well he tore it down
Stealth do you happen to have a link to the documented RHD swap?? I cant find it, I know when I left you were just starting, but I cant find the thread or pics
« Reply #109 on: November 29, 2009, 09:35:09 PM »
I never did a rhd writeup, and my compression should be 9:1. I think I'm going to end up getting a new bare block and honing that.
« Reply #110 on: November 30, 2009, 09:42:06 PM »
170 psi.
Varies a lot with cam, and to a certain extent how fast the starter turns over the engine, but 170 psi is the median number for 9:1 CR.
TheMadScientist
  • I'm like Batman and Shit
« Reply #111 on: November 30, 2009, 09:46:44 PM »
My bone stock Z6 was 190psi +or- 3 across all 4 cylinders. 155 does seem low but like JD said the cam makes quite a difference.
« Reply #112 on: November 30, 2009, 11:31:52 PM »
I wouldn't worry about the compression test results as much as the highly varying leakdown results.
Pages: 1 2 3 [4]   Go Up
