Author Topic: Most RHMT way of upgrading ignition  (Read 34388 times)
Re: Most RHMT way of upgrading ignition
« Reply #30 on: September 07, 2009, 01:26:04 PM »
Say it breaks up at 7K+ in full boost. Try 7K+ in vacuum and see if it breaks up. If it still does, something on the primary side is bad (wiring, pickup, ignitor, etc). If the problem is gone without the load present, then it's a weak spark from something on the secondary side (ignitor, coil, wiring to them, dwell not right, etc).
« Reply #31 on: September 07, 2009, 03:37:16 PM »
Steve broke 400 whp on a fairly conservative reading dyno.  He needs to upgrade to an external Blaster coil and be done with it.
« Reply #32 on: September 07, 2009, 05:06:42 PM »
    Who was saying one of the sohc igniters and coils are the same as B16?
internals are all the same...,
chris did say that i believe
« Reply #33 on: September 07, 2009, 06:19:15 PM »
I said that. Their the same Ive actually swapped internals from my d16 distributor on my car into a gsr distributor to troubleshoot problems before. interanllt they are the same thing.
buk9tp
« Reply #34 on: September 07, 2009, 06:26:20 PM »
x2 i can also vouch for this..
swapped d series shit into my gsr dizzy..
made my stumble go away but not my up top break up..
meh
« Reply #35 on: September 07, 2009, 10:28:24 PM »
 Right now I'm debating doing just the ext. coil, or the coil and the box. Not sure what the box does exactly after the coil is replaced.
  Well, since my tranny now wants to pop out of 5th gear every minute, I may just do the ext. coil and drop some funds on a new tranny.
jarebear667
« Reply #36 on: September 08, 2009, 11:15:36 AM »
low on fluid?
midwest HMT!
« Reply #37 on: September 08, 2009, 02:33:38 PM »
I've used d and b ignitors with h/f distributors.
