Author Topic: H2B with no adapter plate  (Read 20526 times)
« on: October 06, 2010, 05:21:20 PM »
This rhmt, so in other words im broke and dont feel like spending the money on either a qsd kit or Bisi. Anyone done one of these swaps with out the plate? Got any pic's?
I have a free F motor someone is giving me, and my type r trans. Looking at doing a super rhmt build using the F motor, 4g63 pistons, H23 rods, and some goodies from Chris M, and a nice truck turbo :noel:
Re: H2B with no adapter plate
« Reply #1 on: October 06, 2010, 05:22:58 PM »
Done 6 years ago in a trailer park in Palmdale,Ca.
« Reply #2 on: October 06, 2010, 05:23:33 PM »
Oh and the h2b is not just the plate sir
« Reply #3 on: October 06, 2010, 05:26:06 PM »
Was going to use both mounts on the trans, bolt in the axles, and fab up my own engine mount on the super cheap :evil:
Mounts will be a take from this :noel:  http://www.realhomemadeturbo.com/forum/index.php?topic=2098.0
« Reply #4 on: October 06, 2010, 05:30:02 PM »
custom flywheel and custom clutch required as well.
« Reply #5 on: October 06, 2010, 05:38:50 PM »
B disks have the same hubs as a H clutch. Disks are the same dia too.... Ive seen it done ghetooeeeeee but cant remember where.
« Reply #6 on: October 06, 2010, 05:58:17 PM »
Thats the plan, b series clutch, pp, starter, flywheel.
What would most say the limits are on the sleeves (Stock f22a6), rods (H23) and pistons (oem 4g63)? (JD, BDV, ROB?)
This is rhmt the more ghetooeeeeee the more jb weld there will be :P
« Reply #7 on: October 06, 2010, 06:03:17 PM »
Plus the halfshaft needs to be addressed
« Reply #8 on: October 06, 2010, 06:09:07 PM »
If you were doing f/h straight  in an EG chassis I have the axles and transmission. ;D
« Last Edit: October 06, 2010, 06:34:06 PM by 92CXyD »
« Reply #9 on: October 06, 2010, 06:11:29 PM »
Also do you own a bridgeport mill and weld cast materials? if not it will not be that cheap to do your idea hence why adapter plates are so popular. People who own machines are not working for pennies. Your average skilled machinist will charge 65-100 an hour.
If it was as easy as you seem to think it is there would of been a hell of alot more. The only guys I have seen sucessfully do a mix match of series motors and have cars that actually went to races were Hickman's crx with the h2b that was done 6 years back and the setup is now in Sweden and Sppedfactory.
Now can it be done yes. Do I have a transmission case modified just like Hickman's,yup, its collecting dust in the corner. Am I taking pics so the pics spread all over the internet and I keep hearing back how to do it,nope.
jarebear667
« Reply #10 on: October 06, 2010, 06:16:57 PM »
the limit on the motor depends on the compression ratio and they use stroker pistons when they do this or is the 23 rod short? than a h22? you should be able to get to 450ish no problem past that idk. depending on what you end up for with a cr. and why not just use a f trans or h, sell the type r and buyt 10
midwest HMT!
« Reply #11 on: October 06, 2010, 06:58:06 PM »
I agree sell the type r unit for atleast 800. There is your funds to build the car as you desire.
Eggylshatch
  • Pen15 Club President
« Reply #12 on: October 06, 2010, 07:20:27 PM »
meh, be different and try it.  If you have half a brain and some fab skills, access to parts, I'm sure you can figure it out.  Too many naysayers, life would be pretty fucking boring if everyone did the same damn thing and never tried anything different
« Reply #13 on: October 06, 2010, 07:40:34 PM »
H2B is fanboi shit for people with moneys. Rna M2X4 and call it a day, axle angle will suxor but the savings will outweigh ANY amount of niggery needed to overcome it.
« Reply #14 on: October 06, 2010, 07:45:00 PM »
H2B is fanboi shit for people with moneys. Rna M2X4 and call it a day, axle angle will suxor but the savings will allow you to boost it and outweigh ANY amount of niggery needed to overcome it.
« Reply #15 on: October 06, 2010, 11:50:56 PM »
shit i loved my h2b swap.but if i remember it was alot more work that you think. and your going to try and do it with out the plate? i hope you have ALOT of time and cash.
« Reply #16 on: October 07, 2010, 12:15:37 AM »
I remember the H2b adapter we had for the NW HMT pinks car looked very home brew ish, Like bust out the plasma cutter and tap a few holes  :mexi:
« Reply #17 on: October 07, 2010, 12:20:55 AM »
Yep, I remember that one too Steve. I think Jeff sold it on Craigslist.
blade8r
  • Rhapsodic Sinner
  • insolant bastard
« Reply #18 on: October 07, 2010, 01:16:17 AM »
wtf does Rna M2X4 mean?
« Reply #19 on: October 07, 2010, 02:21:44 AM »
h series transmission
« Reply #20 on: October 07, 2010, 03:10:53 AM »
someone local to me did it. i sent yoseph davis the pics but i dont have them anymore. basically it had 1 of the top bolts in, the t bracket in the back connected the motor to the trans and they drilled a hole through the block below the engine code stamp and put a long bolt and nut on it. i was pretty amazed. used the h22 clutch/flywheel and i think it was a b series trans mount.
« Reply #21 on: October 07, 2010, 10:16:07 AM »
With all the nigrigging.. how do you manage to keep that shit lined up?
« Reply #22 on: October 07, 2010, 10:58:01 AM »
Thats the part I cant seem to find anything on ???
Thought anout that, but I dont like the feel of the cable shifter :P
It was one of the trans BDV had the most luck with.
jarebear667
« Reply #23 on: October 07, 2010, 11:09:18 AM »
if you get nice enough shifter and a short throw with nicer bushings they still shift pretty nice had one in my hatch and i liked it for the most part.
midwest HMT!
« Reply #24 on: October 07, 2010, 12:28:40 PM »
What would be hard about having the input shaft in the clutch/pilot bearing while niggering it all up?
« Reply #25 on: October 07, 2010, 12:40:56 PM »
I belive the input shaft pilot bushing snub is different, not sure, but the hubs are definately the same.
Dont be a dipshit, just use a H trans. Unless your making 500 or more youll be fine.
« Last Edit: October 07, 2010, 12:51:02 PM by bigdaddyvtec »
« Reply #26 on: October 07, 2010, 05:19:10 PM »
thats pretty fricking sweet.
« Reply #27 on: October 07, 2010, 05:43:37 PM »
Cable shifters are fine I dont see any real issue with them.
« Reply #28 on: October 07, 2010, 06:17:58 PM »
Start with a random bare F/H block and the hollowed out transmission of your choice.  Machine a shaft that passes through your main bearing saddles and the transmission bearing journals, so that it precisely locates the two.  Modify the trans bellhousing as needed to fit your block bolt pattern - protip: weld aluminum sleeves w/ alignment dowel slots to the block, don't just rely on bolt holes.
Custom flywheel/clutch only needed if you are H2D.
« Reply #29 on: October 07, 2010, 06:54:26 PM »
Mine works jussst fine. I did the ziptie trick, gonna replace the plastic bushings with solids too here while its getting caged.
