General Category => Hybrid/Tech => Topic started by: realAgentMurdoc on April 30, 2009, 10:26:27 PM
Okay...my itr trans is boring (4.40 FD)... would I be crazy to just swap in a 4.928 final drive in there and calling it a day?
is it really that crazy to run at roughly 5600rpm at ~90mph? Sounds pretty flippin' nuts even for me.
Another option is tossing in a LS 5th in there to compensate a little, but it's just not that gangster. But then again it should yield a hair higher in rpm at the same speed with the itr 5th w/the 4.40.
Also... the 4th gear makes me weary... should I swap it out? 100mph at 8400rpm doesn't shound too pleasing to me. Also, entertaining the idea of a longer first gear.
I have no idea wtf is good with this tranny bullshit... I are not understood transmissions.
If any of you have suggestions as far as what gears to use with a 4.928 final drive for peak performance, I am all ears. But mind you this is a daily driver, I'm just stupid.
98+ itr spec had 4.7xx you could prolly get that cheeper than the 4.9 then your accel will be good and have lower rpm but not buy much
lol, i actually have the same question. i was thinking of not going to crazy and just getting the 4.785 + LS 5th...
also love how you use 90mph, not 60 like everyone else... i always use 80mph when im talking engine/tranny speeds, cuz i dont do 60 :P
http://autocrossing.com/cgi-bin/gearcalc.cgi (http://autocrossing.com/cgi-bin/gearcalc.cgi)
http://www.teammfactory.com/gearcalculator.php (http://www.teammfactory.com/gearcalculator.php)
Just put a LS 5th into a CTR box, owner is very happy.
Don't forget about GearX FD's, I think I can get them for about $450.......
yeah I know... I just don't want the run of the mill itr tranny no more. I want something a little beefier than the 4.7 version. And I really don't wanna touch the motor, I wanna leave it realatively stock. So I figured I'd play with the tranny.
lol! 60mph has no significance to me... I cruise at 80-90 on the freeway, hahaha. I'm a realist not a fantasizer... lol!
I was contemplating the 4.7 for a brief moment, but I want something a little more aggressive, lol!
isn't the CTR just a 4.4 FD? the 4.4 isn't cutting it for me. It just makes it a B16 with LSD.
Oh and I'm going with MFactory LSD and FD... pro series FTW! 8)
Bone,
How much for cable l3 crx final drives?
The b16a gearing is already pretty ideal unless your running a tall tire at the track. Get more powa!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
alot of people around my way use the 4.40 b16 1/2 gsr3/4 ls 5 but that mostly boosted setups any all motor cars want there b16 trannys shits like gold here.
B series vtec stuff has been whored out for like 10+ years so it kinda is worth gold these days if its still in one piece
Coming from a 4.40, there is literally no difference between 4.7 and 4.9 FD. Wes calced it out, I think it was 1-1.5 mph difference per gear. Also, NA only you actually lose power with a turbo car unless you're trying to make up the difference with a taller tire in which case you need to worry about replacing more than a FD.
Do whatever is cheapest either 4.7 or 4.9, run an LS 5th. Should net a ~10% bump in power to the wheels in 1-4th.
TY... 4.9 it is then, lol!
