Author Topic: Transmission peoples... need some gearing knowledgabilities  (Read 19011 times)
realAgentMurdoc
« on: April 30, 2009, 10:26:27 PM »
Okay...my itr trans is boring (4.40 FD)... would I be crazy to just swap in a 4.928 final drive in there and calling it a day?
is it really that crazy to run at roughly 5600rpm at ~90mph?  Sounds pretty flippin' nuts even for me.
Another option is tossing in a LS 5th in there to compensate a little, but it's just not that gangster.  But then again it should yield a hair higher in rpm at the same speed with the itr 5th w/the 4.40.
Also... the 4th gear makes me weary... should I swap it out?  100mph at 8400rpm doesn't shound too pleasing to me.  Also, entertaining the idea of a longer first gear.
I have no idea wtf is good with this tranny bullshit... I are not understood transmissions.
If any of you have suggestions as far as what gears to use with a 4.928 final drive for peak performance, I am all ears.  But mind you this is a daily driver, I'm just stupid.
lilpooh21186
Re: Transmission peoples... need some gearing knowledgabilities
« Reply #1 on: April 30, 2009, 10:42:36 PM »
98+ itr spec had 4.7xx you could prolly get that cheeper than the 4.9 then your accel will be good and have lower rpm but not buy much
Ecu chipping
basmaps
« Reply #2 on: April 30, 2009, 11:24:59 PM »
lol, i actually have the same question. i was thinking of not going to crazy and just getting the 4.785 + LS 5th...
also love how you use 90mph, not 60 like everyone else... i always use 80mph when im talking engine/tranny speeds, cuz i dont do 60  :P
http://autocrossing.com/cgi-bin/gearcalc.cgi
http://www.teammfactory.com/gearcalculator.php
« Reply #3 on: April 30, 2009, 11:48:40 PM »
Just put a LS 5th into a CTR box, owner is very happy.
Don't forget about GearX FD's, I think I can get them for about $450.......
realAgentMurdoc
« Reply #4 on: May 01, 2009, 01:08:48 AM »
yeah I know... I just don't want the run of the mill itr tranny no more.  I want something a little beefier than the 4.7 version.  And I really don't wanna touch the motor, I wanna leave it realatively stock.  So I figured I'd play with the tranny.
lol!  60mph has no significance to me... I cruise at 80-90 on the freeway, hahaha.  I'm a realist not a fantasizer... lol!
I was contemplating the 4.7 for a brief moment, but I want something a little more aggressive, lol!
isn't the CTR just a 4.4 FD?  the 4.4 isn't cutting it for me.  It just makes it a B16 with LSD.
Oh and I'm going with MFactory LSD and FD... pro series FTW!  8)
« Reply #5 on: May 01, 2009, 04:33:56 AM »
Bone,
How much for cable l3 crx final drives?
« Reply #6 on: May 01, 2009, 04:36:43 AM »
The b16a gearing is already pretty ideal unless your running a tall tire at the track. Get more powa!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
lilpooh21186
« Reply #7 on: May 01, 2009, 04:04:20 PM »
alot of people around my way use the 4.40 b16 1/2 gsr3/4 ls 5 but that mostly boosted setups any all motor cars want there b16 trannys shits like gold here.
Ecu chipping
basmaps
« Reply #8 on: May 02, 2009, 01:12:15 AM »
B series vtec stuff has been whored out for like 10+ years so it kinda is worth gold these days if its still in one piece
« Reply #9 on: May 04, 2009, 11:11:29 AM »
Coming from a 4.40, there is literally no difference between 4.7 and 4.9 FD.  Wes calced it out, I think it was 1-1.5 mph difference per gear.  Also, NA only you actually lose power with a turbo car unless you're trying to make up the difference with a taller tire in which case you need to worry about replacing more than a FD.
Do whatever is cheapest either 4.7 or 4.9, run an LS 5th.  Should net a ~10% bump in power to the wheels in 1-4th.
realAgentMurdoc
« Reply #10 on: May 05, 2009, 03:10:04 PM »
TY... 4.9 it is then, lol!
