General Category => Forced Induction => Topic started by: Lowerit on May 23, 2014, 10:14:00 PM
Title: Cheap turbo - your roots
Post by: Lowerit on May 23, 2014, 10:14:00 PM
I want to cheaply turbo my CRX.. the more I talk to people the more I see that the ITB idea is not a great one
I have a TDI intercooler,  I have been told that an integra ECU and injectors from the same Gen fit the bill...    So lets discuss.. not trying to make a ton of power.. 160whp in the CRX would work well for what I want.. I have an old Alpine tape deck, Fosgate amp and Vaurnet Decal in the back window.. I don't want to change a harness, I don't want to chip an ECU , or get an ostirch.
cheap cheap cheap...  cheap.
Title: Re: Cheap turbo - your roots
Post by: n/a mike on May 23, 2014, 11:35:37 PM
I don't feel like searching.
What engine do you have?
if you don't want to tune it then go with an fmu.
14b is a good sized small turbo, but I'm not sure about only 160hp
Post by: ratcityrex on May 24, 2014, 02:21:15 AM
Afc, dsm 450s and a msd btm.
Post by: jdmhatchracer94 on May 24, 2014, 04:33:03 PM
Rhb5 no intercooler map bypass and a sk2 na chip that was my first set up ran great
Post by: PhilStubbs on May 24, 2014, 10:11:59 PM
I dont understand not tuning it. it could be much better tuned than not
Post by: Lowerit on May 24, 2014, 10:24:06 PM
Im lazy
Post by: turbohf on May 24, 2014, 10:35:37 PM
couple check valves, fmu, and a btm dialed back a degree or so isnt tuned?  :o
Post by: turbohf on May 24, 2014, 10:37:43 PM
ps:  i vote IHI RHB5 also. plus whatever intercooler fits, if none fit, perfect too.
Post by: Sedrostyle on May 25, 2014, 02:52:32 AM
I'd go t28 or t25 whatever it is. Seems like its easier to find manifold adaptors for.
HF manifold everyone else stated the rest.
I have a integra ecu if you wanna buy it.
Post by: Ntrain2k on May 25, 2014, 10:32:02 AM
I like blown up shit
FIFY
Post by: Foowee on May 25, 2014, 11:14:30 PM
Is it mpfi or dpfi?  Supposedly, in the mid/late 90's, Stephan Papadakis ran 11's w/dpfi, I've been wondering how.  I think he used a much larger side feed injector for the secondary.  Sized a turbo to match so it would light when the secondary opened.  Then it would be fish store check valves on the map sensor n something to retard timing in relation to boost...
Post by: turbohf on May 25, 2014, 11:16:11 PM
its a 87 CRX Si...  ::)
Post by: Foowee on May 25, 2014, 11:18:25 PM
nevermind then...
Post by: PhilStubbs on May 27, 2014, 03:09:00 PM
Considering the fact that he knows multiple people that will properly tune it for free, that method makes no sense to me.
Post by: n/a mike on May 27, 2014, 07:22:34 PM
At minimum run a basemap "tune"
gonna buy an ecu anyway
Post by: Lowerit on May 28, 2014, 10:07:52 PM
post pics of your sisters ass.
I Will see you this fall Kneeee Grow
Post by: PhilStubbs on May 28, 2014, 10:13:46 PM
SWEEEEEEETTTT!!!! Bringing that pedophile asian boy lover?
Post by: HiProfile on May 29, 2014, 02:37:32 PM
Being an 87 makes it a bit harder. The irony is a FMU costs more than a set of DSM450's and a chipped obd0 ecu running turboedit or BRE. Even a basemap will run better & make much more power than an FMU.
Post by: Tim on May 29, 2014, 05:25:04 PM
I have an fmu and missing link if someone is shopping
Post by: Burntrubber87 on June 09, 2014, 08:06:39 AM
Hobbs switches and Volvo cold start injectors.
Adjustable FPR for the csi fuel circuit, Bleed valves and like others a BTM for "finetuning"... nog.jpg
