General Category => Hybrid/Tech => Topic started by: jdmshocker on August 01, 2009, 06:49:07 PM
Title: GSR trans case has a small crack
Post by: jdmshocker on August 01, 2009, 06:49:07 PM
so i'm putting my hydro gsr tranny back together and i have a slight crack on the case, ill post a pic
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv376%2Fvietxxdragon%2FIMG_0134.jpg&hash=7f8bda2ffb8d03f8ead02f373a28e12b109a5689)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv376%2Fvietxxdragon%2FIMG_0135.jpg&hash=269407d8095e9cd732341cbb8d0dc96b78157479)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv376%2Fvietxxdragon%2FIMG_0136.jpg&hash=5a5c4ca9333dcd001c88289e01f242cc3a8be925)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv376%2Fvietxxdragon%2FIMG_0137.jpg&hash=4a457a3b5dcf91785ff8694265dcb92d978a68f4)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv376%2Fvietxxdragon%2FIMG_0138.jpg&hash=92d867a82e23695825df25ebb794460b915fbaed)
Shitty camera phone pics
Title: Re: GSR trans case has a small crack
Post by: jdmshocker on August 01, 2009, 06:52:12 PM
how do i go about fixing it?
Post by: onlyflash944 on August 01, 2009, 07:46:20 PM
option a: weld it proper
option b: jb weld it proper
Post by: jdmshocker on August 01, 2009, 07:52:21 PM
i was probably going to JB weld,  i was actually thinking about using Quicksteel, me and my dad have used it on our boat engine (chevy 350)  and the exhaust manifolds.  I figure the crack is very small and filling it with JB weld or something like that would be just fine?
Post by: Ntrain2k on August 01, 2009, 08:56:02 PM
It depends on where the crack is, how big it is, etc.
Got that pic yet?
Post by: jdmshocker on August 02, 2009, 01:18:25 AM
PICS
Post by: widebody93 on August 02, 2009, 04:20:18 AM
I suggest taking it to a machine shop after you have it hot tanked. let then groove into it with a die grinder and re tig it from the outside. NOT FROM THE INSIDE
Post by: Ntrain2k on August 02, 2009, 01:38:44 PM
That shit needs to be welded at a minimum.
I'd probably hunt for a new case or tranny myself.
Post by: jdmshocker on August 02, 2009, 01:57:40 PM
damn, i just sanded it some and put on some quicksteel stuff, i guess i'll start looking for a new case :(
Post by: civiceggturbo on August 02, 2009, 02:22:48 PM
grind that shit off and buy someone a 30 to weld it
Post by: onlyflash944 on August 02, 2009, 02:28:38 PM
Post by: jdmshocker on August 02, 2009, 02:29:35 PM
thanks!  i have a buddy with a tig welder hopefully he can weld it up for me!
Post by: chris on August 02, 2009, 02:33:07 PM
cast is very tough to weld correctly
Post by: onlyflash944 on August 02, 2009, 02:37:10 PM
yes, make sure he knows whats going on
Post by: jdmshocker on August 02, 2009, 02:39:18 PM
any advice or tips for tig welding the case?
Post by: chris on August 02, 2009, 03:06:18 PM
aluminum sweats out oil if oil has been present. Most welders cant do cast correctly.
Post by: jdmshocker on August 02, 2009, 03:18:52 PM
so really i need to bring it to a really good welder or get another case.................damn i'm shit out of luck
Post by: onlyflash944 on August 02, 2009, 06:32:43 PM
yes
Post by: Ghetto_D on August 02, 2009, 07:23:54 PM
Just go to the junkyard and get a new case and be done with it.
Post by: jdmshocker on August 02, 2009, 11:30:33 PM
yeah, problem is there is no integra's at all in the junkyards around me :/    I'll have to source out a new case online
Post by: 89shithatch on August 03, 2009, 12:47:35 AM
jb weld it and run that fucker.
Post by: t_cel_t on August 03, 2009, 05:03:13 AM
hit the crack with a torch for a few mins that should burn off most of the oil, then rinse with acetone/alcohol/brake cleaner something that cuts oil.
Post by: d-rail on August 03, 2009, 05:42:17 AM
If you heat if up and clean it a few cycles then weld it while its hot you should be ok. But putting filler in somewhere that has already cracked do to stress is not the answer.
Post by: jdmshocker on August 03, 2009, 10:22:24 AM
yeah brake cleaned the hell out out of it, but i didn't try torch it or burning off the oil, good idea.  I'll probably try to get a dremel or something on it as well before welding it
Post by: Ravage70 on August 04, 2009, 12:53:00 AM
is that the outer case?
I have one for sale 50 shipped
Post by: crttaz on August 04, 2009, 02:41:50 AM
a fucking steal!
Post by: jdmshocker on August 04, 2009, 02:56:54 AM
I'll keep you in mind, may have found two trans locally.
Post by: bigdaddyvtec on August 04, 2009, 03:18:36 AM
grind along the crack SLIGHTLY, hit with torch SLIGHTLY, drill 2 small holes at either end of the crack and tig it.  Tranny cases are tricky ask me how I know....
Post by: stealthiskey on August 04, 2009, 08:42:13 AM
+1111!!1
Post by: ifly87 on August 04, 2009, 02:38:40 PM
Yeah be carefull if you torch it, heat can change the properties of the aluminum pretty easily. Damn. I wouldnt jb weld it, i'll bet that thing opens up when there's a heavy load on it. I'm supprised it didnt come apart.
