Author Topic: GSR trans case has a small crack  (Read 18328 times)
jdmshocker
« on: August 01, 2009, 06:49:07 PM »
so i'm putting my hydro gsr tranny back together and i have a slight crack on the case, ill post a pic
Shitty camera phone pics
« Last Edit: August 02, 2009, 01:19:04 AM by jdmshocker »
jdmshocker
Re: GSR trans case has a small crack
« Reply #1 on: August 01, 2009, 06:52:12 PM »
how do i go about fixing it?
« Reply #2 on: August 01, 2009, 07:46:20 PM »
option a: weld it proper
option b: jb weld it proper
jdmshocker
« Reply #3 on: August 01, 2009, 07:52:21 PM »
i was probably going to JB weld,  i was actually thinking about using Quicksteel, me and my dad have used it on our boat engine (chevy 350)  and the exhaust manifolds.  I figure the crack is very small and filling it with JB weld or something like that would be just fine?
« Reply #4 on: August 01, 2009, 08:56:02 PM »
It depends on where the crack is, how big it is, etc.
Got that pic yet?
jdmshocker
« Reply #5 on: August 02, 2009, 01:18:25 AM »
PICS
« Reply #6 on: August 02, 2009, 04:20:18 AM »
I suggest taking it to a machine shop after you have it hot tanked. let then groove into it with a die grinder and re tig it from the outside. NOT FROM THE INSIDE
« Reply #7 on: August 02, 2009, 01:38:44 PM »
That shit needs to be welded at a minimum.
I'd probably hunt for a new case or tranny myself.
jdmshocker
« Reply #8 on: August 02, 2009, 01:57:40 PM »
damn, i just sanded it some and put on some quicksteel stuff, i guess i'll start looking for a new case :(
civiceggturbo
« Reply #9 on: August 02, 2009, 02:22:48 PM »
grind that shit off and buy someone a 30 to weld it
« Reply #10 on: August 02, 2009, 02:28:38 PM »
jdmshocker
« Reply #11 on: August 02, 2009, 02:29:35 PM »
thanks!  i have a buddy with a tig welder hopefully he can weld it up for me!
« Reply #12 on: August 02, 2009, 02:33:07 PM »
cast is very tough to weld correctly
« Reply #13 on: August 02, 2009, 02:37:10 PM »
yes, make sure he knows whats going on
jdmshocker
« Reply #14 on: August 02, 2009, 02:39:18 PM »
any advice or tips for tig welding the case?
« Reply #15 on: August 02, 2009, 03:06:18 PM »
aluminum sweats out oil if oil has been present. Most welders cant do cast correctly.
jdmshocker
« Reply #16 on: August 02, 2009, 03:18:52 PM »
so really i need to bring it to a really good welder or get another case.................damn i'm shit out of luck
« Reply #17 on: August 02, 2009, 06:32:43 PM »
yes
Ghetto_D
« Reply #18 on: August 02, 2009, 07:23:54 PM »
Just go to the junkyard and get a new case and be done with it.
jdmshocker
« Reply #19 on: August 02, 2009, 11:30:33 PM »
yeah, problem is there is no integra's at all in the junkyards around me :/    I'll have to source out a new case online
89shithatch
« Reply #20 on: August 03, 2009, 12:47:35 AM »
jb weld it and run that fucker.
« Reply #21 on: August 03, 2009, 05:03:13 AM »
hit the crack with a torch for a few mins that should burn off most of the oil, then rinse with acetone/alcohol/brake cleaner something that cuts oil.
d-rail
« Reply #22 on: August 03, 2009, 05:42:17 AM »
If you heat if up and clean it a few cycles then weld it while its hot you should be ok. But putting filler in somewhere that has already cracked do to stress is not the answer.
jdmshocker
« Reply #23 on: August 03, 2009, 10:22:24 AM »
yeah brake cleaned the hell out out of it, but i didn't try torch it or burning off the oil, good idea.  I'll probably try to get a dremel or something on it as well before welding it
Ravage70
« Reply #24 on: August 04, 2009, 12:53:00 AM »
is that the outer case?
I have one for sale 50 shipped
« Reply #25 on: August 04, 2009, 02:41:50 AM »
a fucking steal!
jdmshocker
« Reply #26 on: August 04, 2009, 02:56:54 AM »
I'll keep you in mind, may have found two trans locally.
« Reply #27 on: August 04, 2009, 03:18:36 AM »
grind along the crack SLIGHTLY, hit with torch SLIGHTLY, drill 2 small holes at either end of the crack and tig it.  Tranny cases are tricky ask me how I know....
stealthiskey
« Reply #28 on: August 04, 2009, 08:42:13 AM »
+1111!!1
ifly87
« Reply #29 on: August 04, 2009, 02:38:40 PM »
Yeah be carefull if you torch it, heat can change the properties of the aluminum pretty easily. Damn. I wouldnt jb weld it, i'll bet that thing opens up when there's a heavy load on it. I'm supprised it didnt come apart.
Lol...Fags
