Author Topic: motorcycle camera mount  (Read 28453 times)
skinnye
« on: March 24, 2009, 12:07:22 AM »
I was thinking about buying a camera mount but then came up with an idea to make my own.  Here is how I did it:
Step one: get an old mirror, remove the mirror and keep the stem.  Also get a piece of steel and drill a few holes in it
Step two: Put stem on bike and mark where you want the steel piece to be
Step 3: Remove stem from bike and weld the steel piece to it, go to your local hardware store and get a bolt/washer setup.  Install on bike and take it for a test ride.
Tested it out and decided it needed a shield and a rubber washer.  So I made a shield out of lexan and added a rubber washer.  Total cost $3 for the sheet of lexan, all that other crap I had laying around.
Testing it out on my rigid cb750, boring vid prior shield and rubber washer
DIY motorcycle camera mount
Testing it out on my sv650 on a local twisty road, post shield and washer.  I need to figure out how to get rid of the reflection.
Sv650 with Viper Slip on, riding a local twisty road
Emperor
Re: motorcycle camera mount
« Reply #1 on: March 24, 2009, 01:07:53 PM »
sweet
reflections?
easy
diffrent ways:
1)buy a sheet anti refelction foil in your local camerashop
2),,Box,, the whole thing, so no light can reflect
3)if possibel put a kind of rubber ring over the lens ring and put it close as possibel to the window
hope that helps O0
RHMT Boost everything
-Cars
-Bikes
skinnye
« Reply #2 on: March 24, 2009, 04:33:57 PM »
I actually figured it out, I just moved the shield closer to the lense, I made a video today of my buddy's kz1000.
skinnye
« Reply #3 on: March 24, 2009, 06:16:41 PM »
Here is the video I made today
Custom Kawasaki KZ1000 Rigid Sidecar
« Reply #4 on: March 24, 2009, 06:22:45 PM »
your buddy needs an LSD.  In the video, you can tell that only the left wheel spins.  :P
awesome mount, vids, sidecar
« Reply #5 on: April 01, 2009, 06:10:46 PM »
i made one of these last year, i just got 2 bolts that were the same thread as my gas tank filler thing and made it out of a few pieces of aluminum, bolted it on my tank using rubber and metal washers, i liked it cause it shows my gauges  :P  then i threw it away after making a couple dangerous videos
« Reply #6 on: April 01, 2009, 06:20:14 PM »
Nice writeup skinny, love the sidecar vid
« Reply #7 on: April 01, 2009, 10:09:02 PM »
it should show the speed-o
nice work tho
