Author Topic: Identify this flange...  (Read 42743 times)
phillyd
  • Life is Good
« on: March 07, 2009, 02:39:02 PM »
'#39#3988 supra turbo - needs moar bewst.
Re: Identify this flange...
« Reply #1 on: March 07, 2009, 02:41:04 PM »
yeah looks like a t4 ;D
phillyd
  • Life is Good
« Reply #2 on: March 07, 2009, 02:55:41 PM »
it's not t4.
holset 't4' flanges are off by 1/4" on bolt holes.  you COULD just dremel them and use a t4 flange though (dimensions are fine in width, not height)
So will the ports on the manifold and the turbine housing match up correctly? I would just need to worry about getting the bolt holes lined up?
phillyd
  • Life is Good
« Reply #3 on: March 07, 2009, 03:32:09 PM »
it's 3.5 for width spacing instead of 3.25 iirc..
the port is pretty much the same size though
http://www.volvo.com/NR/exeres/479167ED-EF82-4BA4-BB23-D0B3A4378842.htm
this is roughly what it came from, too.
Good info, thanks!
Does this schematic apply to all Holset T4 flanges?
« Reply #4 on: March 09, 2009, 04:11:25 AM »
Look near the end of Garrett's turbo catalogue for 2009 (2nd half), they list 3-5 types of T4/diesel flanges in it. Its hard to see because they imported such low-quality pics in, but you can guess at most spots.
phillyd
  • Life is Good
« Reply #5 on: March 26, 2009, 10:26:48 PM »
holset doesn't have a t4 flange, but yes the flange that LOOKS like a t4 is as what i've stated.
h1c is t3, 1d and 1e, 2d 2e etc are holset ''t4'' flange
I picked up a Holset H1E...is has a 'real' T4 flange...:
phillyd
  • Life is Good
« Reply #6 on: March 27, 2009, 10:24:20 AM »
your measurements are wrong if you think that is t4, your bolt pattern is the OD of the t4 flange size, not the actual t4 bolt pattern.  :dunce:
The T4 schematic you posted is measured from the middle of each bolt hole...my measurements were taken the same way. How are my measurements wrong?
