Author Topic: Does this thing come out  (Read 19448 times)
« on: March 28, 2009, 12:55:30 AM »
This is on my H1C I can't tell if this fucker is removable? I tried to un screw it but can't get it loose
« Last Edit: March 28, 2009, 12:57:56 AM by jdmhatchracer94 »
Re: Does this thing come out
« Reply #1 on: March 28, 2009, 12:58:06 AM »
OIL FEED
If so then yes
My 2 didnt have them
OIL Drain  dtraight T3 drain from Tunar TOys is all I needed
Both ports didnt have the fittingas in picture
« Reply #2 on: March 28, 2009, 12:58:58 AM »
And is that a 21cm housing?   I got a smaller one I think out in the shop
« Reply #3 on: March 28, 2009, 01:07:51 AM »
yeah if it doesn't come out was gonna get a fitting to work with it.
I dunno what size housing it is just got it yesterday.
« Reply #4 on: March 28, 2009, 01:19:22 AM »
I just went and looked again took the wire brush to it and saw a gap.
How to I measure to see what size housing I have?
Another question whats the average oil psi for these things 20-30 psi?
« Last Edit: March 28, 2009, 01:32:41 AM by jdmhatchracer94 »
« Reply #5 on: March 28, 2009, 03:02:07 AM »
It should have an internal restrictor.
« Reply #6 on: March 28, 2009, 03:05:57 AM »
If it does I'm pissed, because I got jipped on mine
1/32 BTW if it doenst
« Reply #7 on: March 28, 2009, 04:10:26 PM »
I will have to see if I can dig up a pic I have. One of the trucks I helped put a set of twins on, the owner only had -6an  line around so that is what he used for his oil feed. No issues. I know that BW recommends a minimum of a -4an on their turbo's. Other then BB turbo's, I have never used a restrictor.
« Reply #8 on: March 28, 2009, 11:14:07 PM »
1/32 isn't that kinda small?  How the hell would i tell if it has a internal restrictor?
Logan76
« Reply #9 on: March 28, 2009, 11:32:20 PM »
I would run 1/16th, 1/32nd is more for BB turbo's.
« Reply #10 on: March 28, 2009, 11:57:34 PM »
the fitting has a nipple in it but that fucker is about 1/4"
« Reply #11 on: March 29, 2009, 12:55:11 AM »
My Holset H1C did this with a 1/16
And thats after 400 miles at 336whp
Then I went to 1/32 after the rebuild and it I got 446whp out it and then sold to confirm a good rebuild
Restrictor and drain all sold even the brainded lines, just to have what I had and make sure that it wont leak"and I have 78pis oil pressure at WOT"
But fuck all that jazz.
Pt6262E made 470whp on 3.5 cylinders before it all gave out
« Reply #12 on: March 29, 2009, 01:37:57 AM »
ok so how would I do a restrictor on that? theres no flangejust get a fitting with the 1/32 hole?
« Reply #13 on: March 29, 2009, 02:04:53 AM »
Take the fitting that screw into it
WELD IT UP
THEN GET A 1/32 bit for a dremel and CHUCK it into a Bridgeport mill
WILL hold a constant RPM/pressure
and then no worries afterwards
DO WORK, and DO IT WELL
« Reply #14 on: March 29, 2009, 02:20:59 AM »
and if u take that queer fitting out...
get a M12x1.5 to AN adaptor and never look back.
Logan76
« Reply #15 on: March 29, 2009, 09:35:43 AM »
I've never heard of anyone having trouble with a .062 restrictor before, I'm not saying you are wrong, I've been wrong many times before.
« Reply #16 on: March 29, 2009, 06:57:50 PM »
damnit wanted the easy way out. Yup just have to make somethin for this fucking thing.
just looked up the part # and it says I have the 18cm housing
also from what i just read says it should see 30psi at idle and up to 70psi underload
« Last Edit: March 29, 2009, 07:55:26 PM by jdmhatchracer94 »
