Author Topic: sidecar race bike swingarm and my homemade bead roller  (Read 16552 times)
weirtech
    • Weir Technologies Inc.
« on: January 14, 2010, 12:09:47 PM »
have a sidecar race bike in the shop that needed a bit of modification.  the owner is too tall for it, so he wanted to move the engine back as far as possible, but still retain the 86" spec between the front wheel and rear wheel.  so we cut out the frame, made a shorter swingarm and moved the engine back 4" so he can lie down lower in the bike.  still need to move the shifter and brake pedals back, but i'm waiting for him to come by to do that so we can put them exactly where he wants them.
before paint:
old swingarm and frame:
all put back together:
and here's our homemade bead roller.  the only thing i'd change would be to add a pair of gears on the backside so you don't have to turn the aluminum pipe by hand as you crank the handle.  i still think it does a good job and i probably won't use it all that much, but i always wanted to have one.
RotaryGeek
Re: sidecar race bike swingarm and my homemade bead roller
« Reply #1 on: January 14, 2010, 01:18:59 PM »
sexy as usual man. Good work.
TunerToys
« Reply #2 on: January 14, 2010, 03:58:48 PM »
Good stuff, now get that CRX thread updated! :)
« Reply #3 on: January 14, 2010, 06:26:30 PM »
fuck you should have made a few of those bead rollers and sold them the the rhmt boys on the cheap. I would kill for one.
NoPistons!
« Reply #4 on: January 14, 2010, 11:54:24 PM »
http://cgi.ebay.com/ebaymotors/TP-Tools-Metal-Forming-20-Bench-Mount-Bead-Roller_W0QQcmdZViewItemQQhashZitem53df0f3524QQitemZ360224601380QQptZMotorsQ5fAutomotiveQ5fTools#ht_1996wt_875
Weir's was probably cheaper to make maybe but it's not like a bead roller is THAT expensive and it can pay for itself eventually.
I'm not trying to take away from your post (weir) by any means.  That's pretty cool.  Always nice to see the stuff you do.
« Reply #5 on: January 15, 2010, 04:04:05 AM »
why are you so fucking baller in everything you do?
d-rail
« Reply #6 on: January 15, 2010, 04:15:34 AM »
tits idea, anyone with a lathe or knows anyone with a lathe could make that.
weirtech
« Reply #7 on: January 15, 2010, 09:37:44 AM »
this was done with a lathe and a mill, although it could probably be done a bit differently with just a drill press.
this bead roller cost me nothing to make since all the material was picked out of the "spare metal but not scrap" bin in the shop.  the hardware we had, as well as the bushings on the roller shafts.
no pics of the whole bike.  i'll post some up when the engine is back in it and the shifter mechanism is done.  right now i'm really excited about the bender i just got!  it should be together later today.
« Reply #8 on: January 16, 2010, 09:06:28 AM »
i have one of those sheet metal bead rollers. it needs some slight modification to be any good for tubing.
NoPistons!
« Reply #9 on: January 17, 2010, 02:41:15 AM »
I figured.   Used would be another option but weir's home built tool is so damn tough that cockroaches will be bead rolling pipe on that shit long after humanity has been wiped from the earth.
For the occasional home mech, the "whatever" bead roller works.  Dollar for dollar i'd rather spend a night at the titty bar and do the vice grip thing.  Who was it who did that?  Welded 3 screw shanks to some vice grips?
ktown powder coating
  • Noob of the month Oct 09
« Reply #10 on: January 17, 2010, 08:43:56 AM »
very nice work on both the swing arm and the roller
« Reply #11 on: January 17, 2010, 09:21:54 AM »
im not knockin the all purpose bead roller. i use it for other things also. im glad i have it
« Reply #12 on: January 22, 2010, 10:53:31 PM »
that roller is bad ass
« Reply #13 on: January 23, 2010, 08:47:24 AM »
Hey Aaron, how much would a set of those mandrels cost a nog? i can make the rest, i just dont have access to a lathe anymore
weirtech
« Reply #14 on: January 23, 2010, 11:46:01 AM »
if you have a mill with a boring head, you can probably make them with a bit of creative tooling.
« Reply #15 on: January 23, 2010, 10:39:58 PM »
i dont have a mill. maybe one day
