Author Topic: test vid  (Read 7718 times)
test vid
« on: January 17, 2010, 01:14:18 AM »
z28 Camaro flyby
gooseman
Re: test vid
« Reply #1 on: January 17, 2010, 01:33:29 AM »
To bad everything about those cars, besides the motor, is fucking garbage.
Re: test vid
« Reply #2 on: January 17, 2010, 01:39:53 AM »
fanboi
that car will put you through the windshield, it brakes like a motherfucker
Re: test vid
« Reply #3 on: January 17, 2010, 01:42:28 AM »
2002 Camaro 60-0 120ft
2002 Acura NSX 60-0 117ft
i was totally fucking amazed how well the car stopped especially for being a vert and 3700lbs
Re: test vid
« Reply #4 on: January 17, 2010, 01:44:15 AM »
stopping is over rated.
gooseman
Re: test vid
« Reply #5 on: January 17, 2010, 01:51:16 AM »
fanboi
Windshield isn't laminated? It;s a bigger POS than I thought.
And why didn'y they design the fender better? Instead of the bottom of the fender being higher than the pinch rail, it goes over it. They just decided that putting a little "Do not jack here" sign was good enough....
Re: test vid
« Reply #6 on: January 17, 2010, 01:55:25 AM »
fanboi
space age air flow dynamics obviously
Re: test vid
« Reply #7 on: January 17, 2010, 01:55:59 AM »
GM's are POS's
everyone knows that. if ford had designed the LSx and put it in the mustangs with the ford t56 you would have the best car in the world pretty much.
Re: test vid
« Reply #8 on: January 17, 2010, 02:02:30 AM »
Those things are abortions to drive on the street, bloated with blind spots by design, the ultimate expression of ignorance.
There is only one purpose for them, only one thing they do well:
Re: test vid
« Reply #9 on: January 17, 2010, 02:05:32 AM »
ignorance.
Re: test vid
« Reply #10 on: January 17, 2010, 02:07:26 AM »
ignorance.
Your buying the convertible version of a drag car?  For once I agree with you.
Re: test vid
« Reply #11 on: January 17, 2010, 04:41:11 PM »
My mom has a '02 ws3, I infact do not like to drive it. Feels like my first daily driver - '77 Olds Delta 88 - just with a stick & more power. The thing nose-dives like the boat did (before I replaced the boat's shocks).
My friend also agrees on that point to the extent that he parted his SS out after building the motor for boost - and slapped the ls1 into a fox body.
WPPF
Re: test vid
« Reply #12 on: January 17, 2010, 05:42:18 PM »
My jetta is cooler.
90dx
Re: test vid
« Reply #13 on: January 17, 2010, 07:01:13 PM »
The best thing to do with a Camaro is too take the running gear out and throw the rest of the car in a dumpster.
