Pages: 1 [2] 3 4 ... 8   Go Down
Author Topic: RHMT project #6 - 2000 CRV  (Read 150333 times)
t57b18
Re: RHMT project #6 - 2000 CRV
« Reply #30 on: January 23, 2010, 10:48:21 PM »
will be following this build im doing a buget built crv turbo also....
« Reply #31 on: January 23, 2010, 10:54:45 PM »
fucking copy cat..
« Reply #32 on: January 24, 2010, 03:00:19 AM »
So what did go wrong?
« Reply #33 on: January 24, 2010, 11:49:49 AM »
First wrong move was to get an ebay adapter plate instead of a proper BMC one because I thought saving $20 was a good idea.
Second wrong move was - I couldnt find the proper sized allen-head hardware ANYWHERE in town so I used some random bolts I had laying around and grinded the exhaust housing to accomidate for the larger head sizes of the hex head bolts I was using
Lastly, some unexplained phenomena caused 3/4 of the turbo-to-adapter-plate bolts to cross-thread or something.  Went in, got hard to turn then quit turning alltogether and 2 of them's head were stripped by this point.
I've got all 3 parts chillin on a small BBQ grill on high.  Gonna try welding it all together then stick it back in the grill to cool.
« Reply #34 on: January 24, 2010, 03:01:23 PM »
Well good luck, sir. This will be one sick ass build. Question: Did your manifold require you to grind down the last 3 runners in order to bolt to head? My fucking manifold was drilled wrong by the chinese baby that drilled it.
« Reply #35 on: January 24, 2010, 04:51:57 PM »
I don't believe so.  I havent bolted it to the head yet but I rested it on 2 studs and there didnt seem to be any problem lining it up.   Right now I'm just hoping there arent any exhaust leaks due to a portion of the welding everything together job was a bit tough to get the wire into because of the stripped bolts.
Gonna remove the oil pan in anticipation of some stevemode lines today and remove the remainder of the exhaust.  gotta wait on my flanges to make the dp/exhaust.
Edit: Oh yeah, my welder's wire feed motor took a shit today - now only works on higher speeds.  Wonder what rebuilding the motor entails...I might try removing it today to see whats up.
« Last Edit: January 24, 2010, 04:53:32 PM by SloS13 »
« Reply #36 on: January 24, 2010, 05:56:03 PM »
That's the problem working on shit, you always run into problems that were not anticipated. Good luck on your shit nig
« Reply #37 on: January 25, 2010, 08:30:39 AM »
thanks man.  Another problem arose and that was me welding the exhaust housing on BACKWARDS.  I'll either fix it or go t3.  I got a shit-ton of work to do this week but hopefully I can get around to it.  God I suck balls.
jarebear667
« Reply #38 on: January 25, 2010, 11:55:08 AM »
sounds like you need to step away from it for a week. haha
midwest HMT!
« Reply #39 on: January 25, 2010, 12:30:44 PM »
you're 100% right but as usual I will reject your advice and continue to fuck shit up.  Gotta stock up on angle grinder discs.  Fuck me in the goat ass...
Turbo, manifold and adapter plate + hardware = ~$200
Fucking shit up beyond recognition $0
Having an understanding wife - priceless
« Reply #40 on: January 25, 2010, 03:21:55 PM »
Just take your time, and it will all work out. Grind the welds, throw that shit on the bbq and re weld.
« Reply #41 on: January 25, 2010, 04:59:45 PM »
I got it all welded together..My welder is acting fucked up but hopefully it'll hold.  Once it cools I'll see where I'm at.
« Reply #42 on: January 25, 2010, 05:58:24 PM »
Got pic's?
« Reply #43 on: January 25, 2010, 07:12:07 PM »
1fasthf
  • RHMT resident Bruce Buffer
« Reply #44 on: January 26, 2010, 12:17:53 AM »
OMFG I LOVE IT!!! O0
« Reply #45 on: January 26, 2010, 12:21:14 AM »
Gangster!
potatodude
1fasthf
« Reply #47 on: January 26, 2010, 01:06:20 AM »
ya still waiting on the ACOCK explination
dont dodge it this time, i would like an affirmative answer about this ACOCK
« Reply #48 on: January 26, 2010, 08:34:34 AM »
It's a plaque thing with my wife's maiden name on it, misspelled.  :P
« Reply #49 on: January 26, 2010, 03:10:51 PM »
May I dare ask her maiden name. :-*
« Reply #50 on: January 26, 2010, 03:12:14 PM »
« Reply #51 on: January 26, 2010, 04:07:38 PM »
hahaha downhill and quickly.
nice manifoldturbo.  almost dodge-esque of you.
weirtech
    • Weir Technologies Inc.
« Reply #52 on: January 26, 2010, 04:12:31 PM »
you wife is "Acock" from now on.
« Reply #53 on: January 26, 2010, 05:03:21 PM »
It was Aycock.  We're in the south bo.  Actually me and her grandfather (mother's side) share the same name (first and last)
« Reply #54 on: January 26, 2010, 07:19:23 PM »
So your banging your sister??? You and levi should hook up and exchange storys......lol  :P
« Reply #55 on: January 26, 2010, 07:36:24 PM »
Had a spare 2hrs today. Did work
coolant lines are crazy but I might actually cool this one. WG hitting the slave.  A couple degrees of clocking should fix that.  Hopefully I wont need to shorten the actuator arm, etc.
Feed done.  Return will be done when the JB Weld® cures
FMIC comes tomorrow.  Gotta get around to eyeballing some shit and make a http://www.mandrel-bends.com/ order
« Last Edit: January 26, 2010, 07:38:36 PM by SloS13 »
« Reply #56 on: January 26, 2010, 09:28:15 PM »
You need 2.5" or 3"
Last time I ordered from there I bought out their b stock mild steel bends and needless to say, 15 of anything looks a lot bigger in person
« Reply #57 on: January 26, 2010, 09:54:52 PM »
Too late + ordered a couple other silicon bits from egay
Description    Part #    Tax    Price (ex)    Price (inc)    Total (ex)    Total
4 x    2.50" Stainless Liner Hose Clamp    VIS-HC-250    0%    $1.75    $1.75    $7.00    $7.00
1 x    O2 Bung - Mild Steel    O2BUNG-MS    0%    $5.00    $5.00    $5.00    $5.00
1 x    2.50" ID x 6.00" Long, Stainless Flex Tube    FLEX-250-6    0%    $24.99    $24.99    $24.99    $24.99
1 x    2.25" OD, 16 Gauge, Aluminized Steel Straight Tube    AS-225-065    0%    $4.75    $4.75    $4.75    $4.75
3 x    2.50" OD, 16 Gauge, Aluminized Steel Straight Tube    AS-250-065    0%    $5.25    $5.25    $15.75    $15.75
1 x    2.50" to 2.75" Black Silicone Reducer    VIS-SR-250-275-BLK    0%    $9.99    $9.99    $9.99    $9.99
1 x    2.50" Aluminized Steel, 3.75" Radius, 45 Degree Mandrel Bend    AS-16-250-375-045    0%    $11.75    $11.75    $11.75    $11.75
1 x    2.50" OD, 3.75" Radius, 16 Gauge, Aluminized Pro BK
  - BundleItem: 2.50" Aluminized Steel, 3.75" Radius, 45 Degree Mandrel Bend (Qt
  - BundleItem: 2.50" Aluminized Steel, 3.75" Radius, 90 Degree Mandrel Bend (Qt    PBK-16-250-375-AS    0%    $44.62    $44.62    $44.62    $44.62
6 x    3.00" Stainless Liner Hose Clamp    VIS-HC-300    0%    $1.85    $1.85    $11.10    $11.10
1 x    2.50" Black Silicone Hump Hose Coupler    VIS-SHH-250-BLK    0%    $12.49    $12.49    $12.49    $12.49
jarebear667
« Reply #58 on: January 27, 2010, 12:10:31 PM »
how are you going to clock it? i guess if its not a lot but its kinda where it has to be isnt it?
midwest HMT!
« Reply #59 on: January 27, 2010, 01:14:59 PM »
yeah gotta clock it.  It looks right in the pic but the manifold isn't really bolted down
Pages: 1 [2] 3 4 ... 8   Go Up
