Author Topic: Romulator problem  (Read 14631 times)
walter
Romulator problem
« on: January 25, 2010, 06:21:35 PM »
i got already a romulator with keyspan http://www.tripplite.com/en/products/model.cfm?txtModelID=3909 but i can't install it in my laptop, i havent drivers for Romulator , i installed drivers of keyspan but i needs software for romulator i guess, not sure what to do!!.
any help will be appreciate it a lot!.
walter
Re: Romulator problem
« Reply #1 on: January 25, 2010, 07:42:06 PM »
8 views, no help  :-\
« Reply #2 on: January 26, 2010, 03:43:31 AM »
There are no drivers for the ROMulator, it uses a RS-232 communications protocol.  Either the software you use supports the ROMultor across a COM port, or it doesn't.
walter
« Reply #3 on: January 26, 2010, 09:49:10 AM »
does romulator should be connected to the ecu then? i tried the keyspan with romulator only in my home, not sure if im doing it right.
thx for help JD.
« Reply #4 on: January 26, 2010, 12:01:23 PM »
Why didn't you buy a Ostrich?
« Reply #5 on: January 26, 2010, 12:05:27 PM »
Do the normal stuff associated with legacy serial connections - check baud rate, latency, see what COM port the software is looking for (typically a low number) and make sure the Keyspan cable is coming up under that COM port, etc.
If that doesn't work then get an Ostrich - they are so popular because not having to fuck around with USB-serial cables fucking rules.
« Reply #6 on: January 26, 2010, 01:49:59 PM »
True that!
« Reply #7 on: January 26, 2010, 05:29:22 PM »
True that!
quoted for truth!
« Reply #8 on: January 27, 2010, 12:51:59 AM »
« Reply #9 on: January 27, 2010, 12:52:28 AM »
« Reply #10 on: January 27, 2010, 07:50:00 PM »
walter
« Reply #11 on: January 29, 2010, 05:40:02 PM »
i got another cable, expensive  >:(, samething but i found the drivers in official website and works. ill test it with TE now!
walter
« Reply #12 on: January 30, 2010, 09:10:26 AM »
well i tried it and works but no 100% smooth, i got erros in some changes i make.
where is an example :
*** Loading RTP environment..
*** Programmer: 1 COM: 6 Settings: 115200,n,8,1
*** Looking for ROMulator..
*** ROMulator v1.50.  Found!
*** Synronizing ROM to ROMulator...
*** ROM Syncronized! You may now begin editing ROM characteristics.
*** Launch ON/OFF Changed: From: 0 - To: 1
*** Launch Control RPM Change: From: 4000 - To: 1200
*** VTEC Output Line Change: From: 0x23 - To: 0x1
*** VTEC RPM Change: From: 0 - To: 0
*** Boost Cut ON/Off Changed: From: 0 - To: 0
*** Boost Cut MAP Change: From: 4000 - To: 2,8
*** Byte write error! No changes mande! (0x3F)
*** RPM Change: From: 6906 - To: 1500
*** Boost Cut MAP Change: From: 1200 - To: 2,8
*** RPM Change: From: 1500 - To: 6900
*** Launch ON/OFF Changed: From: 1 - To: 0
*** O2 Function Change: From: 1 - To: 2
*** VTEC Output Line Change: From: 0x23 - To: 0x2
*** O2 Function Change: From: 2 - To: 0
*** Launch Control RPM Change: From: 1200 - To: 3500
*** VTEC Output Line Change: From: 0x23 - To: 0x0
*** Boost Cut MAP Change: From: 3504 - To: 2,8
what is the problem?  :-\
« Reply #13 on: January 30, 2010, 05:29:48 PM »
It's hard to keep an asynchronous transmission timed correctly when you are converting from whatever speed the computer is putting information out on the USB bus, stepping from USB speed transmission to RS-232 via a $20 adapater that cost $3 to make, and having the ROMulator try to decypher it at the speed it thinks shit should be coming in.  I've run into this problem with UTECs, where I can make small changes but the sync errors from trying to upload whole maps trash things.
Also, ROMulators suck.
