Author Topic: tax return time, want to buy new/used tig welder...  (Read 18765 times)
90turboteg
  • Rebuildin turbos
« on: January 28, 2010, 03:06:36 AM »
well. i have around 1500$ to spend on a decent tig welder, i would like to get a ac/dc so i can do stainless and alum. been looking around at some welders. i don't see doing much thicker than sch40 on steel and maybe 1/4-1/2 aluminum maybe. something that does well, has a postflow, don't care if its air or water cooled. i use a miller 250sw at work but its a little older.
lmk what you nogs think. thanks
Re: tax return time, want to buy new/used tig welder...
« Reply #1 on: January 28, 2010, 03:30:56 AM »
ill sell you my Smiley tig for $1500  8)
« Reply #2 on: January 28, 2010, 03:47:52 AM »
check craigslist like 5 times a day, thats how i found my setup. granted i did look for over a year.
« Reply #3 on: January 28, 2010, 12:04:20 PM »
1/2" Aluminum you are going to need some heat. Not sure you will find something with that kind of amperage in that price range.
« Reply #4 on: January 28, 2010, 01:49:07 PM »
Fuck I actually OWE the IRS money for the first time since Ive been actually making good money... Legally......
Tax preparer last year fucked up and the UI I was getting wasnt being deducted from like i thought it was. LOL... Owe 1500
« Reply #5 on: January 28, 2010, 05:04:18 PM »
You need a minimum of 300 amps to effectively weld .5" aluminum without preheating. IF you have the service you might be able to find an old esab, miller aicrafter, or hobart cyberwave for $1500, most of the old esab had watercoolers built in. You will need a watercooler if you plan to weld over .25" aluminum. And those old transformer machines will pull over 100amps 3 phase.
90turboteg
  • Rebuildin turbos
« Reply #6 on: January 29, 2010, 02:06:59 AM »
ya well i doubt i will ever have to do anything that thick. i can use my syncowave 250dx at work for anything that thick alum... i mainly want to be able to do charge pipes/brackets and weld manifolds and downpipes. so 1/4 at most in my shop. ive been looking. there was a hardly used miller sw200dx on craiglist for 1500 with a argon tank and a bunch of extras like 3 months ago. too bad i didnt have the cash :-\
« Reply #7 on: January 29, 2010, 02:22:55 AM »
for 1500bucks you should buy my wagovan...  :-*
« Reply #8 on: January 29, 2010, 02:34:39 AM »
for 15bucks you should buy my wagovan...  :-*
Ill buy it
90turboteg
  • Rebuildin turbos
« Reply #9 on: January 29, 2010, 03:02:41 AM »
Ill buy it
as long as it comes with a welder, im still thinken about it, id like to sell my suby first...  :yes:
« Reply #10 on: January 29, 2010, 12:33:51 PM »
Well I would say waiting for a another syncrowave 200 would be a good idea than, that extra 20 amps over the old 180's means something if you want to weld aluminum.
nock
  • pro... muther fuckin pro...
« Reply #11 on: February 04, 2010, 06:38:20 AM »
im into this setup about $1000. i traded the welder for an old beat up mig-master with a bad drive motor (wish i never bought that thing) and $500 cash. all the other crap (bottle, regulator, cooler, h2o torch,) was about $500. and its 900lbs so there is no way anyone will ever steal it unless they bring a fork lift. and yes lights dim when i crank it. one time me and mer were welding up the oil cooler and a transformer blew out down the street, just a coincidence, i think ;)
if you use a syncro at work, welding on one of these will be like kissing your sister.
« Reply #12 on: February 04, 2010, 07:14:10 PM »
Got danm, I forgot how hidious that beast was  :-X
nock
« Reply #13 on: February 05, 2010, 05:26:23 AM »
its former life as a forklift charger has left it with a bitter disposition, dont stair or it will eat you, it was hard enough just to get a picture.
rsmith2786
nock
« Reply #15 on: February 09, 2010, 03:11:58 AM »
http://houston.craigslist.org/tls/1569372374.html
that one looks great, looks like a water cooled torch too. just make sure its not so old that it has selenium rectifiers, they look like this:
http://www.lphoying.com/images/selenium.jpg
that machine dosent look old enough for seleniums, but its good to check. when they go bad you cant get replacements, silicon rectifiers will never go bad unless the machine was abused some how. i think there was a guy on the hobart forums who replaced his bad selenium rectifiers with silicon rectifiers. any how, if there bad you cant get a "drop in" replacement.
even if it dose have selenium rectifiers, dont rule it out, it dosnt mean there bad, just make sure to test the machine before you hand over the money.
most hf problems with older machines are spark gap related and can fixed without to much trouble. i had to clean and reset the gap on mine before it would work at all. the guy i bought it from didnt even know that the machine had a hf gap!  :o
90turboteg
  • Rebuildin turbos
« Reply #16 on: February 12, 2010, 03:27:58 AM »
ya, im thinking of just saving up more to get somthing that i wont have to replace. id like a sw250dx but the 200 is half the price or less and will do pretty much anything i need to do. i have a 20x30 workshop right now, just starting to get shit in there, making benches and what not, its more of a place to work on my/friends cars. its only 200 a month so i cant complain has 220 and lots of lighting :noel:
nock
« Reply #17 on: February 12, 2010, 08:59:02 AM »
by the time you find "the perfect cheap machine" you may have saved up more then it would take to buy a new syncro, or an older 350 amp syncro anyway.
90turboteg
  • Rebuildin turbos
« Reply #18 on: February 12, 2010, 02:17:44 PM »
i meant i was going to save up for a new machine... :noel:
