Author Topic: profec B connection  (Read 9634 times)
walter
profec B connection
« on: February 06, 2010, 12:55:08 PM »
do i can use the low fitting for conect profect, i know it has to go to in the top of wastegate but i lost fitting and i can't connect anything there..  so i dont know if will works too if i use the low one..
lmk asap!
Re: profec B connection
« Reply #1 on: February 06, 2010, 01:49:30 PM »
Yes I ran mine just off the bottom on my Civic.
walter
« Reply #2 on: February 06, 2010, 02:00:03 PM »
cool, thx!
« Reply #3 on: February 06, 2010, 02:40:57 PM »
It should work just by hooking it up differently. Boost goes to the old vent port and the old inlet port is now the vent port. The outlet stays the same on the solenoid, except it runs to the lower WG port.
Basicly you're making it normally open instead of normally closed (or vice versa from Greddy's dual-port/3-way setup). 0% is boost pushing the valve open, 100% duty is no boost pushing the spring open.
This is a picture I made a while back for someone, the arrows show air movement. off = 0% duty, on = 100% duty
theidealone
« Reply #4 on: February 06, 2010, 03:17:06 PM »
^Whats the purpose/necessity of that cork filled vent plug??? Do you have to have something similar, or could you just leave it wide open?
walter
« Reply #5 on: February 06, 2010, 05:12:17 PM »
just blew it  Jew
ill check tomorrow, i think it's blew HG. i did hold up like 23-25 psi stock knocking  :noel:
after test it i was thinking about change connections since im using bottom fitting but i made some pulls and blew it
good info but a bit late  :-\
anyway, ill connect it better the nextime !
here is how i connected to soneolid.
and i think i had to have connected like this.
SgtB
« Reply #6 on: February 06, 2010, 11:46:23 PM »
It's a trash filter. Doesn't take much grit to kill a MAC valve.
« Reply #7 on: February 07, 2010, 04:09:47 AM »
QFT, random strike killed one just by looking at it.
Too bad the info was late. I actually have a boost control FAQ I've been thinking about posting to prevent stuff like this. If it was hooked up opposite, it would have tried reducing boost but actually INCREASED boost.
walter
« Reply #8 on: February 07, 2010, 06:06:30 AM »
i dont know if it's right to have connected like using internal WG still.
i only had the Boost controller OFF and i got +15-20 psi (i think i di can get more boost even), i switch on the boost controller and the samething happened.. it's new one brand  :?: it was set up 0% set low so it should be ran with stock boost pressure..eh¿?
