Author Topic: 4WD not working wtf!  (Read 9637 times)
« on: February 10, 2010, 10:58:23 PM »
I got a 98 s10 Blazer and the damn 4WD isn't working....  It worked last snow storm....   ???
I push 4 HI and the light comes on but no 4WD....    Its werid cause if I leave it in 4HI and drive it, it feels like its kicking in....
Also if I take off at a light it feels like its working then just goes out then i fishtail abit...
IDK...  You guys got any ideas....
Gonna put it on the lift tommrow at work and check it out...
Re: 4WD not working wtf!
« Reply #1 on: February 10, 2010, 10:59:06 PM »
Burn it
« Reply #2 on: February 10, 2010, 11:01:44 PM »
do those have the vacuum actuated 4wd like the older units?
i used to have a 80s s10 pickup and i would have to manually engage the 4wd with a clamp cause the vacuum actuator was broken
« Reply #3 on: February 10, 2010, 11:08:10 PM »
Yeah, if it has vacuum actuators, then either a hose went bad or an actuator has a leak/ is broke. If it's electric, have fun fixing that.
« Reply #4 on: February 10, 2010, 11:50:12 PM »
Go to the front differential look at the switch.
It will either have 2 hoses or 3 wires.
2 hose=> find the leak and check for cracks on the switch and most likely replace it.
3 wire=> check and see if the wires are damaged. Sometimes you can move the wires and the front differential engages.
drivin96
« Reply #5 on: February 11, 2010, 12:05:21 AM »
that sucks guy
« Reply #6 on: February 11, 2010, 12:27:30 AM »
I have fixed a millon s dimes for no 4x4. I need to know if the front drive shaft is turning when in 4x4.
« Reply #7 on: February 11, 2010, 12:43:34 AM »
That is what I was gonna do and see what else is going on under there...
How cheap and easy is the fix if they dont turn?
« Reply #8 on: February 11, 2010, 12:50:09 AM »
most of the time its sum thing stupid and cheap. I bet the front drive shaft turns but the front diff isn't locking in.
7808
« Reply #9 on: February 11, 2010, 12:50:51 AM »
2nd burning it.
my dads jimmy i had to replace the 4wd computer once or twice already
salesmonkey
« Reply #10 on: February 11, 2010, 09:49:05 AM »
i just bought a 81 subaru brat yesterday. 4wd seems to work good. will have to test it out this weekend.
rhmt for life
« Reply #11 on: February 11, 2010, 10:39:56 AM »
Those things are awesome
Adam Lofton
« Reply #12 on: February 11, 2010, 10:53:03 AM »
And carburetted.  :(
« Reply #13 on: February 11, 2010, 01:45:04 PM »
Sweet there is a local with one that has a full sti drivetrain swap. It's pretty cool even has sti seats clashing with the wicked 80's interior.
« Reply #14 on: February 11, 2010, 01:47:41 PM »
That's got to be light enough that it's rendered the merely strong STi drivetrain bulletproof, and doesn't load the engine to the point that the factory pistons are as weak as they are in an STi.
TTC
« Reply #15 on: February 14, 2010, 12:59:40 PM »
Brats are fantastic, its like having an el camino without all the beaners chasing u.
« Reply #16 on: February 14, 2010, 01:39:41 PM »
It looks like those were still vacuum actuated.  For some reason I thought they were electric.
salesmonkey
« Reply #17 on: February 14, 2010, 04:59:20 PM »
pictures of said brat that i bought. its a 81. 1.8 carb, 4high/4low, 4speed, rear seats, factory bumper and winch, runs good.
rhmt for life
« Reply #18 on: February 14, 2010, 05:17:33 PM »
damn, that shits clean. dont think i could drive it in the salty snow and ruin it
« Reply #19 on: February 14, 2010, 05:45:55 PM »
I want it.
« Reply #20 on: February 14, 2010, 06:41:08 PM »
Yea, you can't find cool shit like that in FL.
« Reply #21 on: February 14, 2010, 07:31:48 PM »
Wow that winch bumper sexually arouses me.
« Reply #22 on: February 14, 2010, 07:39:40 PM »
BTW, they all came with the rear seats.  Subaru cheesed those in there in an attempt to bypass the truck tax of the 80s, and it worked.
salesmonkey
« Reply #23 on: February 15, 2010, 12:35:12 AM »
ya i know that it, it was callled the chicken tax
more info on the tax
"The Chicken Tax — actually a 25% tax on potato starch, dextrin, brandy, and light trucks"
"Passenger cars imported into the US were charged only a 2.5% tariff, compared to 25% on light trucks."
a lot of them have been removed. but if you look around can pick up a set for about 100-200$.
rhmt for life
