Author Topic: turbo ID  (Read 10799 times)
fysh
turbo ID
« on: February 12, 2010, 03:59:34 AM »
friend said he pulled it off a Volvo. Seems like they came on 400 series. I'm having trouble finding specs on it. TAO307 family.
« Last Edit: February 12, 2010, 04:12:26 AM by fysh »
Re: turbo ID
« Reply #1 on: February 12, 2010, 07:05:16 AM »
1982-1993 VW
2.4 liter 6 cyl diesel motor.
About all I can dig up on it.
Re: turbo ID
« Reply #2 on: February 12, 2010, 07:09:04 AM »
t3 (duh) .42 housing, used on mk2 td jettas.
Re: turbo ID
« Reply #3 on: February 12, 2010, 12:32:57 PM »
Came off this.  LT28 van, 2.4l 6cyl diesel.
Re: turbo ID
« Reply #4 on: February 12, 2010, 02:21:14 PM »
This is the first time he's heard any of this.
fysh
Re: turbo ID
« Reply #5 on: February 12, 2010, 03:24:46 PM »
Yeah, I know what it came off of. It came off that VW van and an 87 Volvo 400 series. but what I don't know is what the trims are. What size is the compressor? Turbine? A/R? How much horsepower is it good for? That's the info I'm having a hard time finding.
Re: turbo ID
« Reply #6 on: February 12, 2010, 03:26:49 PM »
It's a .50 trim compressor, 225-250 whp.  Same as any Saab or Chrysler T3 from the 80s.  You never told me the turbine AR so I can't help you with spool.
bigwig
Re: turbo ID
« Reply #7 on: February 12, 2010, 03:30:06 PM »
This turbo is/was a dime a dozen.  It is the most common T3.  The only difference between any of them is the housings.  Honestly, you have the best housings so just leave it as is.  The only thing that you could do if you were really bored is find a .63a/r housing for the exhaust.  The difference is probably increasing the peak hp 5-10hp and 100rpm later spool.
Re: turbo ID
« Reply #8 on: February 12, 2010, 03:36:19 PM »
I got 200 rpm later spool with mine, but that was probably more due to the added IC/piping volume from the setup that went on that incarnation.
