Pages: 1 ... 16 17 [18] 19 20 21   Go Down
Author Topic: my rwd crx project CRX2000!  (Read 752785 times)
weirtech
    • Weir Technologies Inc.
Re: my rwd crx project CRX2000!
« Reply #510 on: December 03, 2012, 07:58:31 PM »
yeah, it doesn't take much throttle to spin the tires.  just tapping it mid turn makes it swing like that.  it is going to take some time before i get comfortable enough with the handling before i start doing some serious hooning.  maybe in a big empty parking lot.  it loses traction at will, but regains it almost as quickly when you let off the throttle.  i need to learn the finer points of feathering the throttle.  it has been more than 5 years since i've driven this car (or any other manual for that matter) and it was fwd with considerably less power.  i don't know if i'll ever get the wg to open at 8 pounds...  if i do it wouldn't be for very long.
aaron
« Reply #511 on: December 03, 2012, 08:05:19 PM »
Shit thats how I felt this past weekend with my crx.....
weirtech
« Reply #512 on: March 28, 2014, 04:20:03 PM »
I need to start this thead over since all the pics are dead.  :-\
« Reply #513 on: March 28, 2014, 04:24:47 PM »
Please maintain our addiction to this thread... it is like pure crack for boost addicts  :noel:
« Reply #514 on: March 29, 2014, 01:47:53 PM »
Been a while since I saw an update... just the couple vids on youtube
weirtech
« Reply #515 on: March 31, 2014, 09:19:26 AM »
I just start posting pics from the beginning and try to get them in some sort of chronological order.  i'll add new stuff as I work on it.
this was what I started with:
weirtech
« Reply #516 on: March 31, 2014, 09:23:06 AM »
« Reply #517 on: March 31, 2014, 02:39:45 PM »
So sexy!
weirtech
« Reply #518 on: April 03, 2014, 08:53:29 AM »
engine placement:
firewall clearance:
subframe:
turbo placement:
manifold complete:
trans tunnel:
removed for skinning:
fully welded in:
weirtech
« Reply #519 on: April 03, 2014, 09:03:13 AM »
drive shaft tunnel:
modified pedal arms (bent towards driver's side)
cam sensor modification so it isn't pointing into firewall:
valve cover 2.0:
clutch/lightened flywheel:
« Reply #520 on: April 03, 2014, 11:26:10 AM »
So sexy.....
weirtech
« Reply #521 on: April 03, 2014, 12:04:47 PM »
I will try to get the rest of the pics up tonight, I need to add some recent updates as well.  should have a dry sump on it this year!
« Reply #522 on: April 03, 2014, 12:08:39 PM »
Dry Sump!!!
I want to see that and the work involved.  :noel:
weirtech
« Reply #523 on: April 04, 2014, 09:02:33 AM »
smoothing out the bay.  this was a real pita.  I don't enjoy body work.  trying to sand something that isn't flat is a laborious task.
traction bar and rad support:
fresh champ white on the floor:
old rad support:
rear end in place:
frame rail arches:
the s14 hubs and rotors were re-drilled for 4x100:
hankook 225/45/15's on 949's:
« Reply #524 on: April 04, 2014, 06:43:26 PM »
Oh man I love the 949's. They are so sexy on the rex. That f series looks right at home in there like it was meant for it.
« Reply #525 on: April 05, 2014, 12:55:59 PM »
So how does it feel to have so much work into something you dont want to drive it in case someone crashes into you?  Haha.  I have that feeling all the time.
weirtech
« Reply #526 on: April 07, 2014, 09:22:03 AM »
this car went into a ditch in july.  i'm not concerned at all, it is just a car.  I built this car to beat on it on the regular.  it isn't a trailer queen and it isn't strictly a weekend toy.  it is a any day of the week go to work or pick up the kids from school kinda car.  if it gets ruined by someone else smashing into it, as long as I can walk away i'm ok with that.  the work I put into it was about the process more than the end result... there never is an end result.  it constantly evolves and changes, just the same way you constantly learn and develop new skills.  the process is the key.  if you reach an end result you have missed the point imo.  i'm currently making changes and hope to have it out in late may.
aaron
weirtech
« Reply #527 on: April 07, 2014, 09:38:44 AM »
intake manifold:
1 degree of taper in the runners:
cnc'd stacks from solid 3.5" diameter billet:
the iacv has since been provided larger vac lines, but will again see a revision to larger lines this spring:
dh racing billet tb.  these guys aren't around anymore :(  I bought this tb from someone on this forum, but can't remember who- it was so long ago.  I had this tb on the b17 I had in the bay years ago.
shortened throttle cable:
fuel rail/fpr setup.  the rail was a rmr extrusion blank.
« Reply #528 on: April 07, 2014, 09:41:25 AM »
This build makes me happy in the pants.  :P
« Reply #529 on: April 07, 2014, 02:49:29 PM »
So much badass!
weirtech
« Reply #530 on: April 07, 2014, 03:40:40 PM »
charge piping at it's shortest:
p/s end tank:
d/s end tank:
intercoolerz:
it doubles as a hood latch mount:
coolant overflow:
coolant hardline, getting this in and out is a pita:
fuel tank 1.0 (version 2.0 is currently being mocked up):
fuel feed/return:
exhaust 1.0 (2.0 will be built this spring):
wg dump:
« Reply #531 on: April 07, 2014, 04:09:03 PM »
Heim exhaust hangers....lol Bad ass!
weirtech
« Reply #532 on: April 07, 2014, 04:33:01 PM »
yeah, there just wasn't really room for anything else.  really, I should have added a flex further up stream as well. :/  I can always add that after the fact though.
« Reply #533 on: April 08, 2014, 09:28:28 PM »
How do you like the RS3 tires?
Did the ditch fuck the car up?  Its ok I assume?
I dont think I've ever completed one build either.  Haha.  Good way to sum it up. Glad you arent afraid to drive it, I respect that a lot.
weirtech
« Reply #534 on: April 09, 2014, 09:39:49 AM »
the rs3's are fantastic value.  you aren't going to get a better tire for that little money.
as a result of the ditch excursion:
1. all 4 rear subframe bushings were destroyed (now replaced with prothane bushings)
2. fuel tank was dinged up and had come disconnected at the fill neck tube- I scrapped it and am building a new one to be placed in front of the rear end.
3. the only cosmetic damage was the drivers side rear quarter has a dent and the tail light was damaged.  i'm in the process of fixing it and I plan to flare the fenders a bit as well to spread the rear tires a bit.
4. the exhaust has some minor dents, but I will be building a new one without a cat or a resonator.
aaron
« Reply #535 on: April 09, 2014, 11:03:29 AM »
So did the ass end come out and place itself int the ditch? That was the only problem I ever had with my crx is it felt like the wheelbase was a few inches shorter than it should have been. But I'm glad to hear that the car wasn't destroyed.
weirtech
« Reply #536 on: May 26, 2014, 09:56:43 AM »
here is the modified slave to make it fit.  I made the mistake of making the tunnel without it installed on the transmission, so I had to move access to the bleed fitting.
installed:
in the sunshine:
ok, here is the rear suspension version 2.0.  it has since been modified to 3.0 because the rocker angle on this was incorrect and did not allow the strut proper compression.  i'm glad I decided to make this bolt in so modification is not too difficult.
you can see here where the rocker connects to the strut assembly that it is too far over the mount point on the cross bar.  it was modified to sit behind it so compression begins on the outside of the cross bar mount point and finishes on the inside.
this was after the alignment was done.  only .02" of bumpsteer!
UKDM rear seat that I picked up off ebay for a good price.  it was in excellent condition with no tears or scratches.  the kids can go for rides too!
rear suspension clears the interior hatch cover for a stealth look when parked on the street:
next up I added a meziere electric water pump.  might as well make a cover for the factory pump and get rid of the pulley to clean things up:
but again, I didn't leave it like this either, I ended up going for a cleaner look by ditching the factory tensioner and idler pulleys and just making the belt shorter:
so I got thinking and realized I don't actually even need the water pump housing at all.  it is just a big heavy casting I can get rid of (along with the block off plate I had made, so I went to water pump mod 3.0 by removing the housing and cnc machining up a simple thermostat housing that bolts directly to the block:
I love cnc billet.  it seems to have much more meaning when you draw it up, set it up, program and machine it yourself.
finished with a 1/16" endmill:
what waterpump?
fresh after a wash:
aaron
« Reply #537 on: May 26, 2014, 09:42:13 PM »
This is soooooooooooo awesome luv the attention to detail.  :noel:
weirtech
« Reply #538 on: August 28, 2014, 03:11:22 PM »
so, much has happened in the past few months.  had the opportunity to do some testing last night at a local track.  the car really needs a better tune.  it does not appear to be tuned for midrange driving.  balance throttle through turns is a challenge with it being so twitchy.  anyway, it handles much better than i was expecting.  i didn't push it too hard the first time out.  my goal was to not wreck it and to get comfortable with the brakes and coming out of turns.  it works well and i look forward to pushing it to the edge of its limits in the future.
Avistar23
« Reply #539 on: August 28, 2014, 03:29:35 PM »
Looks amazing! Has come so far since i first saw it! great work youve done here.
-Mike
F250 4x4 7.3 Diesel
International 4900 DT 466E
Pages: 1 ... 16 17 [18] 19 20 21   Go Up
