Author Topic: Voltage Stabilizer & boost a pump  (Read 32326 times)
« on: February 13, 2010, 01:31:54 PM »
Are these things worth it?
Can they be made as a DIY kit?
Re: Voltage Stabilizer & boost a pump
« Reply #1 on: February 13, 2010, 02:03:25 PM »
what are u talking about  ???
« Reply #2 on: February 13, 2010, 02:14:08 PM »
Voltage stabilizer suppose to make sure all you has a constant 12 volts with little variance above or below 12 volts.
And boost a pump ups the voltage 12 to 22v to fuel pump when boost goes from 0 to 30 psig.
« Reply #3 on: February 13, 2010, 03:21:50 PM »
sounds gimicky to me. adding a few well placed grounds and running heavier wire to the pump seems like plenty to me. my walbro 255 in my eg coupe with 100% stock wiring was plenty for 500+whp. how much more do you need?
« Reply #4 on: February 13, 2010, 03:33:15 PM »
400whp or more making my Twincharge d16z6/y8 more reliable trying to complete build by April 1.
« Reply #5 on: February 13, 2010, 03:37:39 PM »
boost a pumps work.
« Reply #6 on: February 13, 2010, 04:14:44 PM »
boost a pumps work.
I was thinking of buying a non-adjustable on egay for $45 shipped but I was thinking since they are that cheap that maybe there is a way of fabbing one up.
SgtB
« Reply #7 on: February 13, 2010, 04:25:39 PM »
Voltage stabilizers are snake oil.
« Reply #8 on: February 13, 2010, 04:30:48 PM »
That is what I was wondering b/c I see tons of magazine build stories mentioning the use of this stabilizer.
But since they always in these builds and even D-sport and TPR did a comparison of these I wondered if there was really any benefit?
FreshDA9
« Reply #9 on: February 13, 2010, 07:57:26 PM »
seen alot of boosta pumps on Cobras was wandering about having 1 work with a honda but got lazy and never looked into it.
« Reply #10 on: February 13, 2010, 09:54:51 PM »
Anything critical has it's own regulated power supply circuit internally, and everything else is a decent ground system.
Boost-a-pumps do work, but when a Walbro 255HP with upgraded wiring is good for 640+ whp, and a second Walbro is super cheap, who fucking cares?
nock
  • pro... muther fuckin pro...
« Reply #11 on: February 14, 2010, 05:01:03 AM »
if you run a certain gauge wire, a certain distance it will drop the same volts if you draw the same amount of current. if you drop one or two volts on the way to the pump in back of the car thats just life. you'll still loose that one or two volts if its running at 12v or 22v and drawing the same current (which its not), but at 22v its not as big a deal.
solution: relocate battery, install relay, stop worrying about it...
« Reply #12 on: February 14, 2010, 10:27:31 AM »
That's your theory, but you've zero experience with how it works in the real world; 18 gauge wire and unibody as ground path doesn't work well.
« Reply #13 on: February 14, 2010, 04:01:21 PM »
we use the KB boost-a-pumps on lots of cars that we do.  simple and cheap fix for engines that lean out up top.
nock
« Reply #14 on: February 14, 2010, 05:50:30 PM »
« Reply #15 on: February 14, 2010, 06:13:32 PM »
When the alternator is the power source, and the engine block ground, you need to worry about it.
kgx
  • MR2fag
« Reply #16 on: February 14, 2010, 06:48:33 PM »
boost a pumps work.
look up some circuit designs for the average car laptop charger. they put out ~20V at 5A from a 12v automotive electrical system. they draw ~(5*20)/12A as input current, since they're just a small stepup xformer, but the idea is the same as the boost a pump.
here's an example: http://apexology.com/files/voltagebooster.pdf 19V/5A. change component values to get the necessary current to drive the pump. possibly run multiple output stages in parallel.
fuel pump is a positive displacement pump. flow is directly related to shaft speed, and shaft speed is directly related to voltage, and inversely related to operating pressure.
edit: fixed my retard math.
« Last Edit: February 15, 2010, 12:03:15 AM by kgx »
« Reply #17 on: February 14, 2010, 07:13:30 PM »
boost a pumps work.
look up some circuit designs for the average car laptop charger. they put out ~20V at 5A from a 12v automotive electrical system. they draw ~(5*12)/20A as input current, since they're just a small stepup xformer, but the idea is the same as the boost a pump.
Nice I'll check this out. ;D
SgtB
« Reply #18 on: February 14, 2010, 11:05:35 PM »
Heavy positive to a relay close to pump, positive from relay to pump,  heavy ground back to block. Use the stock wire to energize the relay's coil. Figure out the amp draw and voltage you want and then figure out what gauge wire  you need. Voltage drop is important. Use a fuse.
My walbro used to change pitch with my blinker.  >:(
The bigger the wire the less drop you'll see, but you'll hit diminishing returns going too big.
« Reply #19 on: February 15, 2010, 01:07:10 AM »
That, and gurgling instead of humming when you cycle the key are sure signs that your shit is stock and therefore inadequate.
« Reply #20 on: February 15, 2010, 06:39:05 AM »
10 gauge front to back.
My Trex inline came with 8, relay, etc, etc.
SgtB
« Reply #21 on: February 15, 2010, 05:45:26 PM »
Yep. It was quickly replaced.
« Reply #22 on: February 19, 2010, 02:15:20 PM »
You realize "magazine builds" get that shit for free, or just for an extra sticker to go between "Injen" and "OBX"...
« Reply #23 on: February 19, 2010, 02:37:17 PM »
Yeah I figured as much.
I remember TPR doing a comparison article about the voltage stabilizer.
They also did an article on different performance fuel pumps and comparing them to Supra and Integra stock pumps.
They should the Supra TT pump putting out more fuel the the performance pumps.
And they should that if you hooked up the Supra TT pump to 16v that it would flow more than 700hp worth of fuel.  ;D
I need to find a way to get e-copies of these articles from TPR there was some interesting reading. :yes:
« Reply #24 on: February 21, 2010, 08:21:48 PM »
I would love to see that. Either borrow a high-res camera or scanner (best), then let imageshack.us do the rest.
I recall an old test comparing a Walbro 255HP and DOHC VTEC's fuel pump, and those pumps will flow enough for ~350whp if you have good wiring. I was thinking at some point of doing two of them - more fuel than a walbro with half the noise.
BTW stealth316.com has a bunch of info on diff fuel pumps, and some tested at higher voltage. I know the 300zx will run the pump at 6 volts until it hits moderate load.
« Reply #25 on: February 21, 2010, 08:59:07 PM »
i never understood all of the talk about walbro's being loud. i dont have any carpet, i have an itr muffler and i dont hear mine
SgtB
« Reply #26 on: February 21, 2010, 11:32:58 PM »
Mine is 12" from my head. It's loud at idle, but once I get moving I can't hear it. I don't understand the gripes either.
« Reply #27 on: February 22, 2010, 12:39:43 AM »
I'll try to scan the article from my copies of TPR later this week. I have to find them first.
« Reply #28 on: February 22, 2010, 01:47:23 PM »
i have teh DSport ones... but basically just say what has been said here.
kgx
  • MR2fag
« Reply #29 on: February 22, 2010, 06:50:06 PM »
a lot of toyotas do that too. MR2 and supra have a resistor pack that drops the FP voltage until you hit boost. if it fails, it fails in full power mode, but my guess was to prevent overrunning the FPR. newer cars just have a PWM controller that drives the pump proportional to load. no fuel pressure regulator at all, just a manifold referenced fuel pressure sensor to tell the pump controller when it needs to up/down the duty cycle.
