Author Topic: CROME: Boost cut is pissing me off  (Read 36436 times)
Re: CROME: Boost cut is pissing me off
« Reply #30 on: February 20, 2010, 09:55:56 PM »
Not a WEEK after selling it, the new retarded owner upped the boost and blew the motor. That is what I see happening
Happens ALL THE TIME. Either when he sells the car or the owner decides that it will be fine to up the boost because his buddies told him it was ok.
lol, that's EXACTLY what happened. A DSM guy.
« Reply #31 on: February 20, 2010, 10:00:46 PM »
While datalogging, crome is telling me boost is in the upper 10's, and i'm sure its spiking maybe very little but enough to make it hit that cut. Its ok I'm not worried about it anymore.
funny ive tuned more then a few cars with extra features added for launch control only and never touched the boost cut setting, but ran a few psi past the stock map and never had it actually cut fuel. Look though your logs and stuff I don't think boost cut is your problem.
broke dick pukes can't afford my time anymore. life is good.
On the older versions of Crome that was possible, but IIRC the Gold roms have the boost cut set automatically, and there is no way to turn it off.
If you guys want to fix this issue do the following.
1) Make a BIN file with the cut set to 10psi.
2) Make a BIN file with the cut set to 10psi.
3) Download a hex editor.
4) Compare the two files using the Hex editor.
5) Change the 1 different location to 255(essentially moving the boost cut out of the sensors range)
That SHOULD work, but I won't make a complete promise.
Que, motherfucker?
bigwig
« Reply #32 on: February 20, 2010, 10:27:35 PM »
Que, motherfucker?
The sensor should THEORETICALLY not put out 5V.  If you change the boost cut value to 255, it essentially makes the boost cut only occur at ~5V.  Hopefully it will put the value out of the sensors range so it won't cut.
Again, no promises, but it's the best chance of removing this problem.
« Reply #33 on: February 21, 2010, 02:16:46 AM »
I was wanting you to edit yourself, not explain the obvious to me.
DmC
« Reply #34 on: February 21, 2010, 06:12:01 AM »
Then don't use gold just use a p30 base and be done. why even use gold anyway all the things that are in it that make it seem cool don't really work like the boost controller. Antilag is for rich rally racers or dumbshit ricers that like to tear up turbo's that they can't afford anyway.
   I do like the cell trace in the options menu while datalogging in gold but the other aggervations don't make that worth it to me.
bigwig
« Reply #35 on: February 21, 2010, 10:55:20 AM »
I don't have a clue what you are referring to.  I think you have to be more explicit with me, because the last few threads you've tried to hint that I was wrong, I didn't get.
« Reply #36 on: February 21, 2010, 11:32:46 AM »
If I were to hazard a guess...
How would one look for a difference in the BIN when the there is no difference to be seen?
I think anyone with half a brain could figure out what you were getting at though.
bigwig
« Reply #37 on: February 21, 2010, 12:52:28 PM »
Thank you.  I'll edit my post.
« Reply #38 on: February 21, 2010, 01:12:36 PM »
Thank you, Mister M :P
