Author Topic: Need math help for something: Base e bullshit  (Read 6359 times)
TTC
« on: February 16, 2010, 06:14:03 PM »
I havent done this shit for like 15 years, can someone refresh my memory?
4e^(-.10469x0.5) + 4e^(-.10536x1) + 104e^(-Rx1.5) = 96
answer is .10681
For the life of me I can't remember how to do this shit.
Bah fixed a slight typo
« Last Edit: February 17, 2010, 09:49:40 AM by TTC »
smithshaw
Re: Need math help for something: Base e bullshit
« Reply #1 on: February 16, 2010, 10:35:26 PM »
You sure those numbers are right?  I keep getting .0899 but i'm probably doing something wrong.
« Reply #2 on: February 16, 2010, 10:42:03 PM »
That shit is way over my head. Fuck that
« Reply #3 on: February 16, 2010, 10:56:26 PM »
lol, haven't done that shit in ... 7 years
Goddamn I need to get back to school.
Adam Lofton
« Reply #4 on: February 16, 2010, 11:23:39 PM »
Math is hard, let's go get icecream.
« Reply #5 on: February 16, 2010, 11:26:42 PM »
just remember that e is a constant, like 2.71 or something close to it, are you supposed to solve for R?
write the problem properly and get back.
« Reply #6 on: February 16, 2010, 11:30:08 PM »
also remember that 'x' does not mean 'multiply' use the fucking asterisk to show multiplication '*'
is this the problem?
4*e^(-.10469*0.5) + 4*e^(-1.10536*1) + 104*e^(-R*1.5) = 96
solve for R?
i get R = .0899033
« Last Edit: February 16, 2010, 11:31:48 PM by t_cel_t »
« Reply #7 on: February 16, 2010, 11:35:28 PM »
Assuming "x" is multiply, and "R" is your variable, I get 0.0277719.
TTC
« Reply #8 on: February 16, 2010, 11:39:03 PM »
FML this shit.
« Reply #9 on: February 16, 2010, 11:49:00 PM »
You mistyped the problem, it should read.
4*e^(-.10469*0.5) + 4*e^(-1.10536*0.1) + 104*e^(-R*1.5) = 96
answer is .1066694
smithshaw
« Reply #10 on: February 16, 2010, 11:51:29 PM »
That makes sense now.  I thought it was weird that he put the *1 in there.
nock
  • pro... muther fuckin pro...
« Reply #11 on: February 17, 2010, 02:34:05 AM »
0.1066694955818
GraphCalc, fuck it.
bigwig
« Reply #12 on: February 17, 2010, 03:06:16 AM »
FML this shit.
Write the fucking question correctly you dumb fuck and someone on here will help you.  Not to mention, you didn't say if you needed to show work, solve by hand, or what.  Otherwise, you punch the numbers into your damn graphic calculator and you can easily get a result.  Even on a TI83, you'd just set the problem up where X=R and Y=the equation.  Then find the 0 on the graph.  It would take 1 minute in total if you decided to jerk off for the first 50 seconds.
« Reply #13 on: February 17, 2010, 03:23:41 AM »
that shit is just level 1 algebra
TTC
« Reply #14 on: February 17, 2010, 09:50:34 AM »
Fixed a typo, its -.10536 not 1.1....
Pat can u show work?
« Reply #15 on: February 17, 2010, 10:29:42 AM »
turn on TI89
press home button
press F2, and select nSolve
Enter equation exactly as shown, using x as your variable. After entering the equation, type ,x)
Press enter
« Reply #16 on: February 17, 2010, 04:32:52 PM »
turn on TI89
press home button
Press enter
anything other is a waste of time
bigwig
« Reply #17 on: February 17, 2010, 04:36:26 PM »
He might be required to do a large portion by hand.  If he is asked to isolate the variable, he will have to change the e's into Logs.  I don't disagree it is a waste of time, but it might be what is required.
