Author Topic: 1/2" thick flanges? would you pay a little extra?  (Read 37587 times)
weirtech
    • Weir Technologies Inc.
« on: March 30, 2009, 10:44:09 AM »
i'm going to be getting some 1/2" flanges soon and was just curious if anyone would be interested in them or be more inclined to buy 1/2" over my standard 3/8" thick flanges.  obviously the price would be a bit more since they would be thicker, but also because they will most likely be waterjet cut instead of laser.  i know a lot of people want the 1/2" so i'm stepping up to meet the demand, just want to gauge interest.  they are probalby going to be around 50% more expensive than the 3/8".
Re: 1/2" thick flanges? would you pay a little extra?
« Reply #1 on: March 30, 2009, 10:53:56 AM »
I have an upcoming cummins project, and 1/2" would be my only choice.
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #2 on: March 30, 2009, 10:55:35 AM »
I only use 1/2 for head flanges.
« Reply #3 on: March 30, 2009, 11:01:06 AM »
1/2", hell yeah! Might need a new intake flange from you if you're ready now.  ;)
slappynuts
« Reply #4 on: March 30, 2009, 11:08:26 AM »
I dont understand why people think they need 1/2" thick flanges. Unless you warp the shit out them when welding and need the extra meat to grind off.
« Reply #5 on: March 30, 2009, 11:25:14 AM »
Well in the case of the cummins manifold I am building, @ 3/8" it will warp just under the 1800+ degrees F of egt. After all it is like a 4 ft long head.
slappynuts
« Reply #6 on: March 30, 2009, 11:43:48 AM »
Is there a large space between the bolts? Another thing that would be a plus in your case would be to leave more material between the ports.
mandrel-bends
« Reply #7 on: March 30, 2009, 11:51:06 AM »
Aaron - Most common 1/2" flanges we sell are turbo inlet/outlet flanges. We do some head flanges in 3/8 and some in 1/2 but people don't seem to care either way most of the time for those.
http://www.mandrelbends.com
monty007
« Reply #8 on: March 30, 2009, 12:35:57 PM »
I just did 2 manifolds using Weir's 3/8 head and turbo flanges - no problems for me.  Is there anyway you can offer both?  I think the reduced cost helps us DIY guys a lot more.
my $0.02
weirtech
« Reply #9 on: March 30, 2009, 01:04:12 PM »
oh, i'm not going to stop making the 3/8" flanges.  just want to see if it will be worth while to do 1/2".
thanks for the input adam.
« Reply #10 on: March 30, 2009, 01:08:43 PM »
All the 3/8" flanges I have used have been just fine.  I would probably continue to just order the 3/8 as I dont see a need for the thicker flanges for what I am doing and dont think I could justify paying 50% more for them.  my .02
BoostForLife
« Reply #11 on: March 30, 2009, 01:09:12 PM »
I would rather buy 1/2" flanges for my first try at migging up a manifold, would have less of a chance of warping shit.
« Reply #12 on: March 30, 2009, 02:21:24 PM »
1/2" CnC here. Love it.
« Last Edit: March 30, 2009, 04:55:56 PM by bigdaddyvtec »
BoostForLife
« Reply #13 on: March 30, 2009, 02:37:08 PM »
« Reply #14 on: March 30, 2009, 03:26:58 PM »
Well it's a 4ft head with 6 ports, so yeah there is a fair bit of space, it will be a solid flange, just cut for ports and holes. It will be milled after it is welded. Oh and this isn't my first dance.  ;)
« Reply #15 on: March 30, 2009, 04:55:39 PM »
12" CnC here. Love it.
12" or 1/2"?
Figure it out...  Youcanhazcontext???
AND MY FINGERS ARE FAT
SirDragsAlot
« Reply #16 on: March 30, 2009, 09:10:20 PM »
half inch flanges seem kinda overkill, three eights look pretty beefy.  i suppose if you can use half without any problems, why not?  bigger is better.
« Reply #17 on: March 31, 2009, 12:00:32 AM »
Well I know the grass is always greener, but worst case you sit on them for a while. Its not like they take up space like a manifold. I'm guess you're just hoping to get a better quantity discount on the steel (not that I blame you)?
I've used 1/4" flanges for shit before :yes:, and managed no warpage, so 1/2" is overkill at least for Hondas IMO.
Random Hero
« Reply #18 on: March 31, 2009, 10:28:41 AM »
I need a set of LB7 Flanges and 1 6BT Flange  :-*
« Reply #19 on: April 04, 2009, 11:43:50 AM »
Keep in mind you might start to get some warpage with laser cutting on 1/2" flanges, there is going to be much more heat input on the material.
And a cummins head flange is like 26.5" IIRC, I still use 1/2" flanges for them though.
TTC
« Reply #20 on: April 04, 2009, 01:14:50 PM »
My 3/8ths head flange warped on me fawk. Ground it down, warped again ...
« Reply #21 on: April 04, 2009, 02:41:31 PM »
if you build it, they will come.
we are all cheap fucks.
« Reply #22 on: April 04, 2009, 04:36:57 PM »
Nothing wrong trying to offer some other options
« Reply #23 on: April 04, 2009, 04:37:31 PM »
Maybe do a group buy here
walter
« Reply #24 on: April 05, 2009, 09:03:55 PM »
Aaron you have a pm.  :-\
« Reply #25 on: April 06, 2009, 04:26:38 AM »
It isn't that they warp so much as looks for me. i like the looks of 1/2"  and so do my customers.
aaron i talked to you about these before, nice your getting around to making the 1/2" flanges.
TTC
« Reply #26 on: April 12, 2009, 04:46:42 PM »
Could you make iintake  adaptor flanges to go from lets say a toyota head to a honda manifold?
« Reply #27 on: April 15, 2009, 03:58:00 AM »
the only retards who think 1/2 is necessary for manifolds are honda-techers.
by the way all those sweet CNC'd 1/2" flanges are really only .450 thick because they loose .050 getting milled flat because they are made from crap hot rolled. ill stick with the 3/8 joints for 50% less  :noel:
aaron just make sure they use the same steel on the 1/2". look how baller your 3/8" flanges welded tonight  8)
« Reply #28 on: April 15, 2009, 06:30:18 AM »
Wow, that is some hot action Corey. Ill be down this weekend to pick up those flanges!
« Reply #29 on: April 15, 2009, 11:30:55 AM »
Depends who you get them from, I mill mine from crs. I prefer milled flanges not only for aesthetics but the fact you can pocket the flange as well to help get rid of some heat. Really though, 3/8" laser cut flanges are fine.
