Author Topic: shitty code 9 - Problem solved. dont borrow things from friends!  (Read 13517 times)
« on: February 22, 2010, 03:01:03 PM »
Crx. A6 block, y8 head, sohc non vtak distributor. Obd0-obd1 jumper, p28.
The car runs and feels fine in boost. This code 9 is pissing me off. Is there a way to bypass this bitch?  I might have to try a new dizzy. Shit.
ninja edit : I pulled off the wire loom and electrical tape from my distributor harness.  its fuckin pinned out wrong.  shit.  dont borrow shit from friends...
« Last Edit: February 25, 2010, 01:12:05 PM by ApexSilver06MR »
Re: shitty code 9
« Reply #1 on: February 22, 2010, 04:50:41 PM »
CYP is inside the dizzy. Either a fucked up dizzy jumper, or a shitty dizzy.
Try another one and see if it goes away.
Re: shitty code 9
« Reply #2 on: February 22, 2010, 04:56:51 PM »
Crap. That's what I've bEen looking for.
I do have
1 a6 dizzy
2 y8 dizzy's
Shit. Lemme look for one.
Re: shitty code 9
« Reply #3 on: February 22, 2010, 05:00:56 PM »
Throw y8 dizzy on and call it a day
Re: shitty code 9
« Reply #4 on: February 23, 2010, 12:54:44 AM »
dummy...  with an external cyp
i just realized that im using a obd2 sohc vtak dizzy....
Re: shitty code 9
« Reply #5 on: February 23, 2010, 01:55:10 AM »
you can use obd2 dizy on obd1 cars dummy
Re: shitty code 9
« Reply #6 on: February 23, 2010, 02:37:55 AM »
Just remember jays a flipnog
Re: shitty code 9
« Reply #7 on: February 23, 2010, 02:39:46 AM »
Well that's what I was thinking.  Crank position sensor is external and on the oil pump on y8's. I remember JD saying something to me about this.
Re: shitty code 9
« Reply #8 on: February 23, 2010, 02:51:47 AM »
So you think everyone who repins obd2 dist to obd1 get code 9's?
Re: shitty code 9
« Reply #9 on: February 23, 2010, 03:23:17 AM »
My original plan was to run an obd2 sohc vtec dizzy and JD said that I might be able to limp the car around but it wouldn't run right. I was just putting 2 amd 2 together and thought that y8 has an external cylinder position sensor I would throw the code.
Re: shitty code 9
« Reply #10 on: February 23, 2010, 05:39:07 AM »
If it runs fine why are you trippin then? My buddies old turbo sohc was pushing 15 pounds running a code 9 for like 3 years and mucho track times.
Re: shitty code 9
« Reply #11 on: February 23, 2010, 11:18:12 AM »
im just being anal about the cel being on.  its only low rpm sputter anyways....
Re: shitty code 9
« Reply #12 on: February 23, 2010, 03:43:26 PM »
i just love anal and it turns me on.
Re: shitty code 9
« Reply #14 on: February 25, 2010, 01:12:21 PM »
ninja edit on first post
Re: shitty code 9 - Problem solved. dont borrow things from friends!
« Reply #15 on: February 25, 2010, 02:45:02 PM »
Dont doubt chris m  ;D.
« Reply #16 on: February 25, 2010, 03:00:47 PM »
« Reply #17 on: February 25, 2010, 03:55:55 PM »
Nice, just another wiring mess. I hate those.
« Reply #18 on: February 25, 2010, 04:28:07 PM »
Bump for flip nog questioning me. Repinned d16y8 dist works on obd1 car=internet knowledgez.
