Author Topic: ECU Plugs?  (Read 24664 times)
Emperor
ECU Plugs?
« on: March 30, 2009, 01:45:58 PM »
Is there a shop,site where i can buy Ecu Plugs ?
I want make a jumper harness for a 2000 Lexus and need OEM Plugs for clean installation :yes:
Toyota dont sell them and used is impossibel/EXTREM Expensive to find.
would be nice if someone could tell me where i can find Male/female Toyota Ecu plugs :somb:
RHMT Boost everything
-Cars
-Bikes
Re: ECU Plugs?
« Reply #1 on: March 30, 2009, 01:55:36 PM »
Only thing i can think of is hit the Junk yard cut the harness at the ecu that would be your male plugs.
Emperor
Re: ECU Plugs?
« Reply #2 on: March 30, 2009, 02:17:06 PM »
I was thinking about that too
the i found out 2 things
they charge around 300 dollar´s for the harness :o >:(
the chance to find such car on the junkyard in a radius about 500miles is
ZERO
I cant believe that every Manufactor have his own standart or better sayd for every engine a diffrent one
-Cars
-Bikes
Re: ECU Plugs?
« Reply #3 on: March 30, 2009, 03:35:52 PM »
They are Toyo/AMP connectors, just like everyone else uses.  Toyo/AMP wants a thousand ot two part order at a time, tho.
Bro, hit up sales@mr2guru.com and tell them I sent you.  You'll need to provide pictures of YOUR ECU plugs as they might be a little different on the US side of things, but if Harry/Mindy have them it'll be less than $300 even if they ship overseas.
Re: ECU Plugs?
« Reply #4 on: March 30, 2009, 11:25:44 PM »
If the price is too much to swallow, you might just have to do a clean 'hack'. There are many ways to cut into factory wiring & make it look tasteful, it just takes some time & patience. As long as you document what you do & have the presence of mind to keep all changes reversable, it will be fine.
