Author Topic: head gasket an torgue spec  (Read 12785 times)
hatchdemon89
« on: February 24, 2010, 01:35:58 PM »
Hey guys new guy here with a 96 ek couple d16a block with all forged internals,sleeved, je pistons eagle h-beams rods block notch'd for clearance d16a crank.fully port'd an polish'd z6 head with all the good stuff.
Im curious to know what headgasket should i run an since i got studs what torgue specs should i set the heads at?
Re: head gasket an torgue spec
« Reply #1 on: February 24, 2010, 01:42:54 PM »
Run a stock d16z6 HG, and ARP head studs. They will come with the TQ specs
hatchdemon89
« Reply #2 on: February 24, 2010, 01:46:51 PM »
thanks thought they would have came with specs but didnt maybe ill just call arp an get the specs from them just figured i would ask someone here since im sure someone has the same studs
« Reply #3 on: February 24, 2010, 01:52:48 PM »
Have the same studs but going from memory I think 65ft-lbs w/ ARP fastener lube.
But I still search ARP website.
Or a link from D-series that worked for me: http://www.d-series.org/forums/engine-building/111485-how-really-torque-arp-head-studs-straight-arp.html
« Reply #4 on: February 24, 2010, 01:55:55 PM »
Most the time I set them to 80ft/lbs. Other go higher.
hatchdemon89
« Reply #5 on: February 24, 2010, 01:58:22 PM »
thanx guys
« Reply #6 on: February 24, 2010, 02:08:54 PM »
According to the d-series link I posted the ARP guy said "Alot of the people torquing them down in steps to 75-80 ft lbs he said your asking for trouble..and not sealing any more or putting any more clamping force that way."
« Reply #7 on: February 24, 2010, 02:33:59 PM »
Torque specs on the ARP head studs I got for the ls-vtec said 85 ft-lbs :o
IIRC the D16 ones I had were around 65 ft-lbs.
My ARP studs came with a half size piece of paper with the torque specs, yours didn't?
« Reply #8 on: February 24, 2010, 02:52:37 PM »
i used to go 70ftlb, till one day on about the 8th time i used the studs one snapped.  fail.
i now use 65ftlb.  tested to 30psi without issues.
« Reply #9 on: February 24, 2010, 07:59:47 PM »
Yup...  If some is good more is better...   :?:  'till you rip some aluminum threads out of a block with some steel studs...
« Reply #10 on: February 24, 2010, 08:05:34 PM »
I chuckle every time this subject is brought up.
I would say that ARP is your best source of information on this topic.
80 lb-ft on D16 head studs...
LOL
Make sure you torque them down in 5 lb-ft increments as well.
ROFL
« Reply #11 on: February 24, 2010, 10:14:03 PM »
LOL
ROFL
lol.  also a 1/4 turn after its torqued down.
« Reply #12 on: February 25, 2010, 10:32:46 AM »
LOL
ROFL
Wow torque to yield studs,                       LOL     ;D
« Reply #13 on: February 27, 2010, 02:43:59 AM »
Hey if people think it's okay to go crazy with used stockers...then must be required on ARP's. ;)
I've had bearings go, rods snap, pumps shatter, clutches explode - but never had ARP's toast a HG if I used a 3 step sequence to recommended torque.
BTW Where the fuck is this guy's n00b post? I see you nogs forgot as well. OP, rules are n00bs must make an intro post that includes good porn. And do not listen to N/A Mike, it can't be gay porn.
« Last Edit: February 27, 2010, 02:45:34 AM by HiProfile »
schim187
« Reply #14 on: February 27, 2010, 12:42:59 PM »
+1
