Author Topic: Dirty turd or dimond in the rough? (HX35W)  (Read 12879 times)
« on: March 12, 2010, 01:40:09 AM »
Should I buy this thing? It's around 2 bones shipped.
Supposedly this turbo has very little shaftplay, spins freely, other pics show just soot not oil. Looks like it sat outside compressor-up for a year. I'd probably just douche it out and only need it for a few hundred miles. There is another one for a bit cheaper, but it's the 8-blade version - and it's much cleaner. I'd almost want that for a cunt-hair better spool.
Basicly I want to know how much abuse/neglect a Hoeslut can take before it's really just scrap.
Re: Dirty turd or dimond in the rough? (HX35W)
« Reply #1 on: March 12, 2010, 02:11:59 PM »
They can take a lot. That one is probably off a marine engine. That said buy the 8 blade since it's better and cheaper.
« Reply #2 on: March 12, 2010, 02:14:12 PM »
a bone is 1 dollar
« Reply #3 on: March 12, 2010, 02:30:14 PM »
...That said buy the 8 blade since it's better and cheaper.
I disagree, about the 8 blade being better. However if it is cleaner and cheaper, then buy it, it is not a significant difference.
rprznt
« Reply #4 on: March 12, 2010, 04:36:02 PM »
fair bit of oxidisation and corrosion there........    therefore.........
id say that thing slid out of julio's ass in the last shart thread.....
 :mexi:
French faggots like Teg2Boo would pour out straight likker because they  don'#39#39t deserve it.
I'#39#39m out rockclimbing / snowboarding / hiking / mtb racing. Be back soon...
« Reply #5 on: March 12, 2010, 09:24:13 PM »
 :mexi:
Thanks, dude.  I was just taking - trying to take - a bite of guacamole when I read that jewel bead.
« Reply #6 on: March 12, 2010, 10:35:50 PM »
I'm not too concerned about overall flow, 50+ lb/min is much more than I'll need. However the 8-blade's larger exducer (83mm vs 76mm) would help in spoolup, as would just the extra blade itself.
I'm also planning on grinding the divider down and putting a flapper in there, to make it an integrated quick spool valve. 6cm for spoolup, 12cm for topend. Depending on how that goes, I may drop $125 or $175 for a 18cm or 16cm housing. It would spool like an hy35 but would pull like crazy to redline.
http://www.gillettdiesel.com/18cm2non-wastegatedturbinehousing-1-1.aspx
Atticus
« Reply #7 on: March 12, 2010, 11:16:00 PM »
That one looks pretty haggered. Mine was about the same when I bought it. (if i find the thread or pics ill post them)
I thought it will be good, not too much shat play and cleaned up pretty easy..... but a buddy said he'll take it to work and check it out. Long story short it needed a full rebuild.
« Reply #8 on: March 13, 2010, 03:06:35 AM »
I've got an 18cm on my built ls/vtec its not too bad.
Aero
    • Turbotalk.org
« Reply #9 on: March 14, 2010, 01:58:18 PM »
That thing should clean up just fine.  I saw a guy with one much dirtier that cleaned up perfectly. I wish I could find it, it was just recently too.
