Author Topic: B16a Dyno??? 12psi? 211hp!?  (Read 101461 times)
b20beast
« on: March 14, 2010, 05:43:47 PM »
So heres the setup!
B16a
SRP 8:1 Cr Forged Pistons
Type R cams.
12psi T3 T4 60Trim .63
2.5" Exhaust
Ebay Cast Manifold
I went on the dyno, baseline was 211whp =( at 12psi  ???!?  :?:
i dont know what happened?!
I ended up adding 6Degrees of timing from 5500-Redline [from 1* per psi retard]
Ended up with 246Whp 178Wtq.
Power falls off hard after 7700rpm!
and peaks about 7500rpm.
This was tuned on 91OCT.
From my research i should be close to 300whp give or take a few.
Any ideas of what is happening here?
How is it possible to baseline at 211whp on 12psi with 1* per psi boost retard.
Also to be noted, i was racing the night after and after a couple pulls, i lost a wastegate bolt!
Im not 100% sure if i had any wastegate / manifold leaks on the dyno, but i didnt hear any leak and the bolt was in.
Thanks guys!
Re: B16a Dyno??? 12psi? 211hp!?
« Reply #1 on: March 14, 2010, 06:15:26 PM »
who cares. The end result was 246 @12psi. Run it at the track or against some other cars to see how its really doing.
The type of dyno and correction factor has a big role on what your numbers could have been/are.
You're peaking early because you have a restrictive exhaust on a high revving motor.
Plus its a b16. you were set to fail from the start.
b20beast
« Reply #2 on: March 14, 2010, 06:20:21 PM »
i ran against a 2JZ [LAUREL] Big turbo 500+ horses and won!
« Reply #3 on: March 14, 2010, 06:21:09 PM »
No you didnt... Or he wasnt trying.
b20beast
« Reply #4 on: March 14, 2010, 06:21:53 PM »
weather u win by a mile or an inch, winnings winning
« Reply #5 on: March 14, 2010, 06:25:02 PM »
ditch the cat
« Reply #6 on: March 14, 2010, 06:26:41 PM »
Either youre lying or he was
b20beast
« Reply #7 on: March 14, 2010, 06:29:37 PM »
i ran against a 2JZ [LAUREL] Big turbo 500+ horses and he won!
fixed
true, but if they are not racing then it doesn't count.
we went from a dig.
mind you, he is automatic... and had some shitty excuse about his 'alarm'
b20beast
« Reply #8 on: March 14, 2010, 06:30:24 PM »
ditch the cat
no cat, straight 2.5" exhaust
plugs are couple months old, what do you guys think?
« Reply #9 on: March 14, 2010, 06:36:36 PM »
b20beast
« Reply #10 on: March 14, 2010, 06:38:05 PM »
« Reply #11 on: March 14, 2010, 06:49:21 PM »
Because Im not a fucking moron....
You live in WA right?
« Reply #12 on: March 14, 2010, 07:04:15 PM »
« Reply #13 on: March 14, 2010, 07:20:59 PM »
No it won't.  If you'd kept stock CR, sure, but not an 8:1 CR B16.  You're dealing with a lazy port, over cammed, no displacement, over square piece of shit - of COURSE it's sensitive to CR and is now slower than a 225 whp Z6 or Y8 on 12 psi because the 246 it does have only occurs the last 23 rpms before the power falls completely off.
« Last Edit: March 14, 2010, 07:23:45 PM by Joseph Davis »
« Reply #14 on: March 14, 2010, 07:52:28 PM »
wtf was the point of 8:1 on a 1.6L.  What kind of dog ass shit is that?  MAYBE if it had some torque to back its complete lack of balls the 8:1 would be ok (SOHC vitara's).
kill yourself.  Go back to HT.
« Last Edit: March 14, 2010, 07:54:25 PM by 98vtec »
flat_black
« Reply #15 on: March 14, 2010, 08:34:25 PM »
This thread fails... OP post porn or ban
« Reply #16 on: March 14, 2010, 10:41:23 PM »
unhook the vac line from the wastegate, then get back to us.
« Reply #17 on: March 14, 2010, 11:34:41 PM »
that cpr is a fail
« Reply #18 on: March 15, 2010, 04:28:28 AM »
If you'd have done research, you'd have seen 10:1 can pull 300+ whp from cast pistons.
If you'd have done research, you'd know JD hates b16's.
If you'd have done research, you'd know Jeff Evans tested a full LS vs full b16 swap with the same kit and the LS spanked it.
If you'd have done research, you'd know you need to start with less than 1*/psi with an 8:1 motor. Much less.
Finally,
If you'd have done research, you'd know to use hemp ROPE when you hang yourself.
« Last Edit: March 15, 2010, 08:08:05 AM by crxvtec91 »
b20beast
« Reply #19 on: March 15, 2010, 09:04:47 AM »
Finally,
hahah i got my good morning laugh!
this is RHMT, pistons i scored for 75bucks, so wtf right, as long as the car spanks some ass!
« Reply #20 on: March 15, 2010, 09:16:50 AM »
You're dumb, and that block will split a sleeve before you max out a stock piston.
b20beast
« Reply #21 on: March 15, 2010, 09:21:55 AM »
so the power falls off early because of the CR?
you said the last 23rpms, u mean 2300 right?
b20beast
« Reply #22 on: March 15, 2010, 09:22:44 AM »
the stock block was damaged already, so thats why i rebuilt it with forged pistons.
bigwig
« Reply #23 on: March 15, 2010, 09:43:27 AM »
Post the dyno sheet.  Post more specs.  Post pictures of the engine bay.
Basically what Joseph said is the truth.  You dropped the compression 2 full points.  You're running some pretty decent sized cams with a log manifold which can be problematic (although I don't think it's the issue in your case).  I'm also guessing the turbo is in less than awesome condition, but that's just my guess.
b20beast
« Reply #24 on: March 15, 2010, 09:47:16 AM »
spot on
the turbo when i got it, shaft wouldnt of even spin, so i cleaned it out and changed bearings and seals.
idk but wont i have the advantage of running more boost on pump gas with this low CR?
like 20-24psi?
« Last Edit: March 15, 2010, 10:00:55 AM by b20beast »
« Reply #25 on: March 15, 2010, 10:23:57 AM »
« Reply #26 on: March 15, 2010, 10:26:37 AM »
like 20-24psi?
not when you could have made the same power on half the boost and be that much less of a pile of dog shit when not in boost.
bigwig
« Reply #27 on: March 15, 2010, 11:42:21 AM »
I'd vote on the turbo being the biggest issue.
« Reply #28 on: March 15, 2010, 11:45:23 AM »
like 20-24psi?
Can i get some proof that lower cr makes your car dog shit slow out of boost? I just can't imagine a honda feeling that slow out of boost. Have you driven a dpfi d15 lately nothing is slower then that pile of aids, and somehow i don't see a b16 being that slow.
I had a friend with a b16 9.7:1 spooled a 60/63 57 trim at 4500-4800 (vtec point) so i find it hard to beleave that 1 more point will destroyed it's driveability.
b20beast
« Reply #29 on: March 15, 2010, 11:55:35 AM »
like 20-24psi?
yeah bullshit on the lower compression driveability
i hardly notice.
who cares about out of boost, thats the reason i put on a turbo, to drive in BOOST.
i get full spool at 5000rpm
the 246whp is pretty fast once you can put the power to the ground.
Pages: [1] 2 3 ... 5   Go Up
