Pages: 1 ... 4 5 [6] 7 8 ... 13   Go Down
Author Topic: 383 sTrOkEr  (Read 251643 times)
Re: 383 sTrOkEr
« Reply #150 on: April 02, 2009, 05:49:20 PM »
If I had to guess, fluid losses from turning oil go up between cubic and quarticly. That's like saying HP_loss due to moving oil = X = RPM * constant_1 ^(3 to 4) Where friction losses due to bearings, gears rubbing, etc, are mostly linear. IE- HP_loss due to friction = Y = RPM * constant_2. But in reality, as you begin increasing load, the working loads of the various pieces goes higher and higher, and they become less efficient, and your friction losses begin to increase quadratically.
Re: 383 sTrOkEr
« Reply #151 on: April 02, 2009, 05:50:05 PM »
nah its prob around 20%
Didn't you say 2 pages ago that no one who is intelligent uses driveline loss %'s???
Holy fuckin contradiction.
U truly are the coolest guy ever.
you're too stupid to understand. you can't use a blanket %  because a 300hp engine would take 60hp to spin the drive train and a 600hp engine would take 120hp to spin the drivetrain. thats idiotic if you think because the engine makes more power its going to rob twice as much to spin the same shit. that is moronic.
you can say something takes a % of crank hp to spin the drive train, but you can't use a flat percent.
lets say it takes about 60hp to spin an auto trans and the rest...
if you have a 300hp engine it'll take 20%
if you have a 600hp engine it'll take 10%
no one in their right mind would believe that the same drive train would rob 60hp from a 300hp motor and 120hp from a 600hp motor
Counter point. So if I build a 300hp, 600hp, 10,000hp, and 1,000,000hp engine and put them behind the same drivetrain, if we assume the drivetrain doesn't fail, could I approach 100% efficient drivetrain as hp -> infinity? By your logic, yes.
nope
do you think if you had a 10000hp engine it would take 2000hp to spin a corvette drive train, but a 300hp engine would take 60hp to spin it.
 :yes:
Do you understand any of what I'm saying?
Re: 383 sTrOkEr
« Reply #152 on: April 02, 2009, 05:53:01 PM »
nope
 :yes:
Why are we talking about fluid? little of the hp rob from a drivetrain is the torque converter on a automatic transmission.
we're talking about spinning metal parts with a thin film of oil on them.
i understand what you're saying and NO you can't get 100% efficiency because you have a 10000000000000000000000000000000000000000000000000000000000000hp motor. it'll still rob a little bit of it, but it'll obviously be a very little percent.
Re: 383 sTrOkEr
« Reply #153 on: April 02, 2009, 05:59:59 PM »
nope
 :yes:
Why are we talking about fluids? Because we are talking about drivetrain losses. They are relevant and you are neglecting them. The transmission is a box with gears in it, and it has oil in it. So does the differential. Wheel bearings are lubed with grease that turns to oil when up to temp. Most of the drivetrain is metal shit that's lubricated to reduce friction, increase working loads, etc when transferring power.
Re: 383 sTrOkEr
« Reply #154 on: April 02, 2009, 06:10:23 PM »
maybe you can put your book down, and talk in reality. there is no 1000000000000000000000motor that spins a car drive train. so throw that away.
flat percentages don't work if you're going to figure drive train loss. END OF STORY. you can express the drive train loss in a percent, but you can't use a percent to figure it out.
is that easy enough for you professor?
Re: 383 sTrOkEr
« Reply #155 on: April 02, 2009, 06:14:18 PM »
Dude, you just don't understand what I said. No shit it's not a flat %. Duh. But it's not constant either. I've said this 3 times now if you haven't noticed.  :?:   It's complex. There are multiple losses that must be accounted for. You can have different % power losses at the same power too. (I'll let you ponder how that's possible)  :noel:
Re: 383 sTrOkEr
« Reply #156 on: April 02, 2009, 06:16:08 PM »
its minuscule difference in the power levels we're talking. so minuscule it doesn't even fucking matter and we should not be talking about it.
thanks.
Re: 383 sTrOkEr
« Reply #157 on: April 02, 2009, 06:28:51 PM »
thanks.
Uh, wrong.
Super simplified example. (extremely dumbed down) You have a stock motor that makes 200 flywheel HP. Of that, 35HP gets eaten up from friction losses through the drivetrain, 5HP for churning oil and everything else. So you loose 40hp total and put 160hp to the wheels. 20% drivetrain loss.
Stop. Think. What's friction?
Now turbocharge this motor and it puts out 400hp. You'll loose say (35*2) = 70hp due to friction and 5 HP from churning oil and everything else, and put down 400-75 = 325 hp to the wheels, for a 18.75% efficient drivetrain.
And perhaps at 500hp you've got 18% drivetrain loss.
But eventually you'll reach a point where as you begin to increase the power going through the drivetrain, bearings begin to overheat and bind up, gears rubbing get hotter than normal and bind, causing more friction and heat, and the problem compounds. So by the time you're at say 600hp, your efficiency might fall off back to 20%.
Or just believe whatever you want.  8)
Re: 383 sTrOkEr
« Reply #158 on: April 02, 2009, 06:38:28 PM »
to sum up this arguement, the drivetrain loss in an automatic is between 30 to 70hp; numbers i threw in here but are close to real life figures depending on variables, rwd/fwd, transmission size (car or diesel truck), etc.
whether it's a 300hp motor, or a 600hp motor, it's going to take roughly the same amount of effort to make it work.
That's about it
Haven't seen a tranny to take 70HP, 50HP max, but yea
Re: 383 sTrOkEr
« Reply #159 on: April 02, 2009, 06:41:49 PM »
That would be nice if that were true. Your argument is larger, more powerful engines (with respect to relative drivetrain size) have much lower drivetrain losses. You are neglecting too many things/ making too many assumptions.
Re: 383 sTrOkEr
« Reply #160 on: April 02, 2009, 06:46:51 PM »
zzzzzzzzzzzzzZZZZZZZZZZZZZZZzzzzzzzzzzzzzzzzzzzzzZZZZZZZZZZZZZZZZZ
Re: 383 sTrOkEr
« Reply #161 on: April 02, 2009, 06:47:38 PM »
what part of "to sum up this arguement" didn't you read?
i KNOW it is not a linear scale of parasitic loss.  i know it is not a fixed amount of loss.  if you make xhp and you lose 40hp, if you make 3x hp you may only lose 80 hp but its not an equal ratio
Ah. I misunderstood your last post.
Re: 383 sTrOkEr
« Reply #162 on: April 02, 2009, 07:06:04 PM »
i went snorkeling in a cum dumpster for money today
Re: 383 sTrOkEr
« Reply #163 on: April 02, 2009, 08:20:32 PM »
I was thinking GAS up to LIGHT DUTY TRUCK
I'd hate to see what it takes to turn the trans in one of those super-sized earthmovers.
Re: 383 sTrOkEr
« Reply #164 on: April 02, 2009, 08:23:43 PM »
zzzzzzz
Re: 383 sTrOkEr
« Reply #165 on: April 02, 2009, 08:29:54 PM »
Sleeping Johnny?
1Fast68
Re: 383 sTrOkEr
« Reply #166 on: April 02, 2009, 08:55:12 PM »
This thread was doomed from the beginning, just let it die.
BlackDragon
  • HMT Bootieologist
Re: 383 sTrOkEr
« Reply #167 on: April 03, 2009, 08:08:10 AM »
No point in arguing with RS he always right and the opposite always wrong  :P
BD
Re: 383 sTrOkEr
« Reply #168 on: April 07, 2009, 02:19:08 AM »
r&r a 96 corvette... what a pain in the ass
Re: 383 sTrOkEr
« Reply #169 on: April 07, 2009, 09:21:34 PM »
yea they are
Re: 383 sTrOkEr
« Reply #170 on: April 08, 2009, 02:40:16 PM »
Perfek360
Re: 383 sTrOkEr
« Reply #171 on: April 08, 2009, 10:38:11 PM »
johny, when did you get the vette?  i know you were talkin bout getting one not too long ago. i might have to make a trip to take a looky at it
Re: 383 sTrOkEr
« Reply #172 on: April 08, 2009, 11:11:32 PM »
i got it a few months ago and had it two days and a rod started knocking. what a joke!
Re: 383 sTrOkEr
« Reply #173 on: April 08, 2009, 11:27:13 PM »
Cylinder 7 started knocking.
Perfek360
Re: 383 sTrOkEr
« Reply #174 on: April 09, 2009, 01:45:37 AM »
nice...gotta love that
Re: 383 sTrOkEr
« Reply #175 on: April 09, 2009, 03:11:22 PM »
Re: 383 sTrOkEr
« Reply #176 on: April 09, 2009, 03:16:31 PM »
Nice those headers need the flanges cut off and a turbo flange welded on each for some twin turbo action. :evil:
Re: 383 sTrOkEr
« Reply #177 on: April 09, 2009, 03:18:40 PM »
maybe someday
Re: 383 sTrOkEr
« Reply #178 on: April 09, 2009, 03:19:34 PM »
Block huggers on an LT1 Vette..
The first sign you know sweet fuck all.. Ported stockers flow more.
before you go on the typical BS Rampage take a look at what the rest of the Vette world (Who has been in it longer then 6 mos) Thinks of SUPER SWEET BLOCK HUGGERS.
http://www.corvetteactioncenter.com/forums/c4-technical-performance/30586-who-makes-headers-92-96-lt-1-a.html
Re: 383 sTrOkEr
« Reply #179 on: April 09, 2009, 03:24:29 PM »
those guys aren't seeing butt dyno gains on their stock engine
i'm sure these will have an effect on my motor. i've already talked to guys smarter than you and they said with my engine it'll help.
stick it up your pussy and go look at your dads engines poser.
Pages: 1 ... 4 5 [6] 7 8 ... 13   Go Up
