Pages: [1] 2 3 ... 13   Go Down
Author Topic: 383 sTrOkEr  (Read 251559 times)
383 sTrOkEr
« on: March 31, 2009, 03:36:08 PM »
lol...
383cid
2.00x1.55 valves
eagle crank/eagle i beam rods
hypereutectic SpeedPro pistons 11:1
(212/218`@.050" with .490" lift)
ported/polished alum LT1 heads
edelbrock air gab manifold
i figure it should make around 450-475 crank hp.
« Last Edit: March 31, 2009, 07:20:32 PM by random-strike »
BangBusMaster
Re: 383 sTrOkEr
« Reply #1 on: March 31, 2009, 04:01:39 PM »
Johnny, you forgot the estimated MPG  :)
Re: 383 sTrOkEr
« Reply #2 on: March 31, 2009, 04:02:21 PM »
35-40
Re: 383 sTrOkEr
« Reply #3 on: March 31, 2009, 04:08:36 PM »
whats it goin in
Suckah
Re: 383 sTrOkEr
« Reply #4 on: March 31, 2009, 04:10:24 PM »
goin in the bmw not that stupid corvette he bought  :P
MantisX
Re: 383 sTrOkEr
« Reply #5 on: March 31, 2009, 04:11:17 PM »
No snail?
Re: 383 sTrOkEr
« Reply #6 on: March 31, 2009, 04:41:05 PM »
We say hypereutectic not hypereutchic  lol ;)
My dad wanted to do a 383 with his 350 like yours but bought a built 454 instead... Can't wait to see this engine in one of his cars. (camaro or leman)
Look tits btw!  :yes:
TTC
Re: 383 sTrOkEr
« Reply #7 on: March 31, 2009, 04:48:05 PM »
out of curiosity, I know nothing about v8s, but is it easy to tune them for that kind of power and compression on carbs?  Isnt detonation an issue?
PS: yes i see you have no carbs lol.
Re: 383 sTrOkEr
« Reply #8 on: March 31, 2009, 04:53:48 PM »
alcohol.
Re: 383 sTrOkEr
« Reply #9 on: March 31, 2009, 04:56:41 PM »
my bad, misspelling. hypereutectic is the correct spelling. :P
are you talking with a turbo or just naturally aspired?
it can get tricky with a turbo, or boost with a carb. but for na... its very easy and takes literally 5 mins at the most to change jets in a holly carb.
some elendbrock carbs & quadrajet can tune themselves to a certain degree because they have air valves that meter how much gas
Re: 383 sTrOkEr
« Reply #10 on: March 31, 2009, 05:58:28 PM »
Old as dirt and they work
Re: 383 sTrOkEr
« Reply #11 on: March 31, 2009, 06:21:15 PM »
I already probably make about 450-470 engine HP NA. I'd expect more out of a 383.
Re: 383 sTrOkEr
« Reply #12 on: March 31, 2009, 06:50:41 PM »
your motor makes more power than any other in the world
QikEnuF
Re: 383 sTrOkEr
« Reply #13 on: March 31, 2009, 07:38:32 PM »
Gen II's don't like a lot of duration?  Looks like a fun toy
hotrex
Re: 383 sTrOkEr
« Reply #14 on: March 31, 2009, 08:18:02 PM »
and......  no one cares
Re: 383 sTrOkEr
« Reply #15 on: March 31, 2009, 08:25:12 PM »
383's are better for torque, HP really dosen't increase.
1.5 or 1.6 rockers?, Roller cam and rockers I assume.
« Last Edit: March 31, 2009, 08:27:12 PM by Conceptz-X »
Re: 383 sTrOkEr
« Reply #16 on: March 31, 2009, 08:31:51 PM »
Where's the boost?  Just looks like you bought some shit and threw it together.
really? how else would you build a motor? do you machine your own pistons? :P
Re: 383 sTrOkEr
« Reply #17 on: March 31, 2009, 08:32:37 PM »
Yeah, but yours will get the best gas milage in the world, even up a hill with a slipping transmission and a blown headgasket.
Re: 383 sTrOkEr
« Reply #18 on: March 31, 2009, 08:32:51 PM »
yeap
Re: 383 sTrOkEr
« Reply #19 on: March 31, 2009, 08:41:13 PM »
this going in the vette with the stock vette tranny? or are you gonna use a different trans?
stock trans
why would i use a different trans?
Re: 383 sTrOkEr
« Reply #20 on: March 31, 2009, 08:47:37 PM »
and more headaches fitting them
Re: 383 sTrOkEr
« Reply #21 on: March 31, 2009, 08:49:13 PM »
stock trans
lots of different reasons. different gear ratios, different amount of gears.
it has a 4l60e
it has different rear end gears already
Re: 383 sTrOkEr
« Reply #22 on: March 31, 2009, 08:56:26 PM »
this is rHMT there are no headaches fitting shit.
i don't know what his plans are for the vette. for all i know he's gonna drop a powerglide tranny in so he only had 2 speeds for drag racing. or maybe he wants to go with a manual tranny setup.
how the fuck do i know
its a 4l60e and i'm going to cruise it around, and drag race it sometimes
Re: 383 sTrOkEr
« Reply #23 on: March 31, 2009, 08:59:00 PM »
havent seen a build out of your ass lately.  :?:
QikEnuF
Re: 383 sTrOkEr
« Reply #24 on: March 31, 2009, 09:01:02 PM »
I did, but it burned...
Re: 383 sTrOkEr
« Reply #25 on: March 31, 2009, 09:09:57 PM »
i would've just kept it how it was if it wouldn't have spun that bearing
Re: 383 sTrOkEr
« Reply #26 on: March 31, 2009, 09:10:42 PM »
I know this is RHMT, but to shorten a driveshaft can be a bitch getting finding someone to get it balanced
any shift kit or anything?  Manual Valve Body?
Re: 383 sTrOkEr
« Reply #27 on: March 31, 2009, 09:26:13 PM »
i heard of this one company, drive shaft shop, not sure if you have or not...
Re: 383 sTrOkEr
« Reply #28 on: March 31, 2009, 09:28:28 PM »
Many places can do it, just depends if there is a local business or if you have to ship it out
Re: 383 sTrOkEr
« Reply #29 on: March 31, 2009, 09:28:53 PM »
i know.
Pages: [1] 2 3 ... 13   Go Up
