Author Topic: soldering dizzy wires  (Read 28498 times)
ctr99ek
« on: March 28, 2010, 07:42:52 PM »
I want to convert my crx OBD0 to OBD-1. I heard that you shouldn't cut and solder the new dizzy plugs on the original harness since it messes with the polarity or some crap. I don't want to buy an adapter harness sine it is pretty much doing the same thing with the connectors. what does everyone recommend?
since this is rhmt i'm pretty sure we all solder our crap right?
Re: soldering dizzy wires
« Reply #1 on: March 28, 2010, 07:56:21 PM »
uhhhh yea
« Reply #2 on: March 28, 2010, 08:11:28 PM »
everything is color coded and soldering the connectors are fine...
« Reply #3 on: March 28, 2010, 08:30:03 PM »
Whoever told you that stop hanging out with them. Who are these people :(
« Reply #4 on: March 28, 2010, 08:33:31 PM »
lemme guess, joker4096 on crxcommunity :P
Solder won't fuck with polarity...lol.  People suggest it since you get a better connection than just twisting wires together, but I'm lazy and haven't had a problem with it.
« Reply #5 on: March 28, 2010, 08:57:35 PM »
So you cant solder wiring anymore, damn.
« Reply #6 on: March 28, 2010, 09:06:02 PM »
Heh.  I guess the OBD0 plugs that I soldered onto the OBD1 distributor in my blue hatch should keep it from running properly...
As Chris said, stop hanging around or listening to whoever told you this.
rsmith2786
« Reply #7 on: March 28, 2010, 11:47:50 PM »
No it certainly does flip the polarity.  Basically you can't just solder some but not the others.  If you solder them all the polarity is flipped on each one and they cancel out.
« Reply #8 on: March 28, 2010, 11:53:39 PM »
Unless I have completely missed the boat on electrical theory, how in the fuck do you figure?
ctr99ek
« Reply #9 on: March 28, 2010, 11:57:59 PM »
i guess i meant voltage, not polarity, wtf was i thinking hahaha
« Reply #10 on: March 29, 2010, 12:02:48 AM »
I think you missed his sarcasm, sir.
« Reply #11 on: March 29, 2010, 12:04:37 AM »
its going to flip the voltage now?
positives become grounds.  yes, that happens, when a retard starts connecting the wrong wires.
bigwig
« Reply #12 on: March 29, 2010, 12:07:26 AM »
Even if soldering the dizzy wires was an issue, have you not heard of solderless connections?
« Reply #13 on: March 29, 2010, 12:18:52 AM »
Soldering the wires doesn't cause any adverse effects.  I soldered OBD0 connectors onto my OBD1 distributor.
Somebody is full of shit.
bigwig
« Reply #14 on: March 29, 2010, 12:28:58 AM »
I'm well aware of that.  I'm saying, even if somehow, magically, you couldn't solder the wires, you could buy some solderless connectors and that would work perfectly.  The OP clearly is just flat out retarded.  He deserves to hang out with his retarded friends.  They compliment each other nicely.
« Reply #15 on: March 29, 2010, 01:06:02 AM »
Fuck all this talk soldering guns cost to much. use garbage bag twists to hold you connections together.
bigwig
« Reply #16 on: March 29, 2010, 01:08:38 AM »
I just hire Buk to do all my electrical work.  He is an expert!
« Reply #17 on: March 29, 2010, 03:27:04 AM »
The only real problem is that the crank angle sensor wires are shielded and VERY picky. First I did a clean install with a fully wrapped obd0-1 dpfi-mpfi harness, which failed after a week. Can't rev over 3k. Then I did a dirty direct wire with speaker wire. Worked sometimes, others same bullshit.
Then I got some shielded 22ga wire intended for phones. It worked flawlessly afterward, and I don't think I even had to ground the wires. FYI I can't recall the exact sensor name, but it's whatever you ADD to an obd0/dpfi setup to make it obd1/mpfi.
ctr99ek
« Reply #18 on: March 29, 2010, 04:00:37 AM »
see there was something to worry about.  geez you guys can go suck one, the negative contributors
« Reply #19 on: March 29, 2010, 08:38:30 AM »
Because using shielded wire on a VRS signal is rocket science.
Totally the same as soldering the wires and reversing the polarity.
« Reply #20 on: March 29, 2010, 09:05:44 PM »
get bent.
bouncinofftherevlimiter
« Reply #21 on: March 29, 2010, 10:16:31 PM »
on my brother in laws (ex B-I-N now??) ricetastc CRX, we just popped the pins out of the connector for the obd1 dizzy and put the obd0 connector on it, there was no soldering and it looks original...
is that maybe and option for you to look into??
No longer own a turbo car...
HX35 18lb 486hp/391tq
« Reply #22 on: March 29, 2010, 11:12:05 PM »
I just repinned my stock obd-0 wires, to a obd-1 plug. And the one pug that had 2 wires I just cut and solder with the obd-1 plug. Its Eazy, just goolge it.
rsmith2786
« Reply #23 on: March 30, 2010, 01:01:13 AM »
Just fucking solder them.  It's fine.  It's not like every wire has a flawless path from the engine to the ecu.  There are connectors, interference, and on top of it all Honda uses the thinnest possible wire to save every penny then can.  What do you think happens to that wire when it enters the ecu?  It's immediately faced with a soldered connector from the header and every other connection on that board is soldered.
« Reply #24 on: March 30, 2010, 01:35:58 AM »
DANGER TO POLARITY
Solder is the devil
Use zip ties and lots of loops in the wire to save polarity
michigan_soler
« Reply #25 on: April 06, 2010, 04:04:59 AM »
Come on now. Just cut each wire twice and hage two solder stops on each wire... it fixes everything....
Fuck it. Just run solder in place of the wires.
« Reply #26 on: April 06, 2010, 11:30:54 AM »
jb weld
kgx
  • MR2fag
« Reply #27 on: April 06, 2010, 10:51:21 PM »
jb weld
TIG weld. only way to get a solid connection.
narfdanarf
« Reply #28 on: April 08, 2010, 12:33:36 AM »
jb weld
buk may disagree.
theidealone
« Reply #29 on: April 12, 2010, 03:50:17 PM »
God damn it. I have no spark. I made a jumper harness at one point to convert my DOHC ZC from OBD0 to OBD1 (harness side, not the dizzy side). Then i cut that off, and converted to OBD1 plugs (engine harness, not dizzy). Now as Im going through wiring diagrams to find why I have no spark, Im reading that some of the distributor wires are "shielded". WTF does that mean? Any chance that would keep me from getting any voltage to the coil (black/yellow wire)?
It ran fine all last year. Went to fire it up this year after doing a bunch of other shit, and it wont run. I didnt touch that part of the harness though.
