Author Topic: Who has some emblem adhesive?  (Read 12410 times)
« on: March 30, 2010, 02:39:10 PM »
So I got the ricer emblems off my car which were held on by double sided tape. Now I just have to get all the residue off. Someone told me WD-40 will work and not harm the paint, anyone ever tried this? Any other quick solutions?
Worked like a charm, now does anyone have any spare emblem adhesive laying around?
« Last Edit: March 31, 2010, 07:20:13 PM by Doug »
Re: Removing sticker residue from paint? WD-40?
« Reply #1 on: March 30, 2010, 02:40:06 PM »
lighter fluid. true story.
Hotrodlincoln
« Reply #2 on: March 30, 2010, 02:41:28 PM »
Lighter fluid or 3M adhesive remover
kill yourself piss face
« Reply #3 on: March 30, 2010, 02:42:36 PM »
Don't have any lighter fluid, only grill lighter fluid lol
« Reply #4 on: March 30, 2010, 02:45:11 PM »
Krud Kutter
« Reply #5 on: March 30, 2010, 02:49:13 PM »
Any friggin solvent (that's not too powerful)
WD40?  Nosir.
Rubbing alcohol will work if that's the least you have.  Surely you have some.
dooderek
« Reply #6 on: March 30, 2010, 02:51:18 PM »
goo gone nigger
« Reply #7 on: March 30, 2010, 02:57:53 PM »
WD40?  Nosir.
Yeah I tried rubbing alcohol, but doesn't do jack.
goo gone nigger
Yeah I'm just being lazy and don't want to go to the store. Might pick some up later
« Reply #8 on: March 30, 2010, 03:43:20 PM »
3M adhesive remover
I had to remove ~15 bumper stickers from my one car, this shit worked great
« Reply #9 on: March 30, 2010, 03:55:37 PM »
Any kind of petroleum based lube will work. I've used wd-40 (and knock off's) to get tint crud off, sticker residue off of paint, and lots of other shit. If it's kinda sun baked on, you may have to soak it for a while. I had that shit happen with a emblem on my trunklid, and I had to keep spraying it. It came off a day later, just sprayed it down anytime I walked outside, rubbed a little, spray, rub, spray, etc...
« Reply #10 on: March 30, 2010, 03:56:54 PM »
Also, if you read the WD-40 can, it says that its safe for such.
« Reply #11 on: March 30, 2010, 04:10:25 PM »
I use WD40 or PB.  Works like butta 8)
« Reply #12 on: March 30, 2010, 04:22:25 PM »
Fortunately I found a bottle of actual paint remover in the garage, have been using that, and before I was using 90% isopropyl alcohol.  Also have used some spray meant for prepping for paint work that's supposed to remove all oils and such.
shogun
« Reply #13 on: March 30, 2010, 06:05:15 PM »
mineral spirits
« Reply #14 on: March 30, 2010, 06:29:19 PM »
wd40  O0  I use way too much for everything but it fucking works.
RotaryGeek
« Reply #15 on: March 30, 2010, 06:37:26 PM »
Wd40 is the duct tape of aerosol cans.
arsenio
« Reply #16 on: March 30, 2010, 06:38:19 PM »
If it has a factory/ decent paint job, you can use acetone. If its a rattle can job, I wouldn't try it.
I do this on a daily basis to remove tree sap and sticker adhesive. Just give it a light coat of wax when your done.
Will you miss me?
potatodude
« Reply #17 on: March 30, 2010, 07:59:36 PM »
Heat gun or blow dryer.
arsenio
« Reply #18 on: March 30, 2010, 08:02:31 PM »
That's a waste of time. Acetone will have it off in less than 30 seconds.
Will you miss me?
« Reply #19 on: March 30, 2010, 08:07:34 PM »
That's what my "paint prep" spray has.  Works.
« Reply #20 on: March 30, 2010, 08:13:49 PM »
good way to scorch the paint
potatodude
« Reply #21 on: March 30, 2010, 09:46:36 PM »
Maybe if you fail at life.
« Reply #22 on: March 30, 2010, 10:07:03 PM »
Don't get me wrong, I'm no body expert, but I think that heat would make it pliable and gooey to come off, but might kinda also get the paint too hot. Why go through that hassle when WD-40 does it just as well, and quicker.
« Reply #23 on: March 30, 2010, 10:07:59 PM »
Wd40 is the JB WELD of aerosol cans.
fixed
Cray91
« Reply #24 on: March 31, 2010, 02:43:32 AM »
« Reply #25 on: March 31, 2010, 12:28:37 PM »
« Reply #26 on: March 31, 2010, 07:19:36 PM »
WD-40 worked out pretty well. Just kept spraying it on every little bit, about 5 coats in each spot and it came off fairly easy.
So now I just need to get some emblem adhesive for the replacement ones. Anyone have any laying around? Don't really want to buy $10 3M emblem adhesive that I only need a few drops of.
Re: Who has some emblem adhesive?
« Reply #27 on: March 31, 2010, 07:23:15 PM »
Shipping to you would cost a few bucks.
I have some JB Weld.
« Reply #28 on: March 31, 2010, 07:38:00 PM »
Can throw it in one of the free USPS envelopes for about $.75. I got a pack of chewing gum just waiting to be used, don't think I won't go ghetto on it
Eggylshatch
  • Pen15 Club President
« Reply #29 on: March 31, 2010, 08:12:31 PM »
jb weld, or better yet, some other type of epoxy.  I just don't see jb weld sticking to plastic and/or paint very well
