Author Topic: Just another RHMT SANDBLASTER cabinet...  (Read 15797 times)
« on: March 30, 2010, 10:42:50 PM »
So I got a HF sandblaster on sale for $55 (pressurized 20lb), some "rough" soda media, then wasn't happy with the hastle & ineffectiveness of baking soda.
Then I decided to build a rough cabinet. Went to Homeboy Depot and got ~$25 in wood/parts, had them cut everything for free. Went back to HF, got some 80grit Glass Bead media, random guy gave me a 20% off coupon and n00b cashier keyed it as $20 off the media instead. :) I also added a 18" flourecent light I've had for random lighting situations, inside right above the arm holes.
So I'm at:
$55 for the blaster
$17 for the deadman nozzle/gun
$25 for wood/parts
$8 for real glass
$20 for beads
$40 for soda media
=$165 including "soda mistake".
The local speed shop charges $65 to clean ONE Honda block, and I have a bunch of blocks, turbos, heads, t-bodies, and misc shit I want to clean - all aluminum. Basicly I'll be saving money after I do my 2 gsr blocks and 1 gsr head. My friend will probably give me >$100 to blast his rims, which will be a cakewalk for this thing. It eats paint like Chris M does n00bs. I put more time into it than I thought and made the cabinet a bit too big, but the results make up for all the bullshit. It almost looks like I just sprayed silver paint on everything:
Dirty-ass free 42/48 turbo I got (need black beauty or sand for turbine):
The most crusty TB I had (56-to-60mm test mule), 2nd pic shows uncorroded/unblasted factory finish (and TPS spot I missed):
Free B18B1, the ribbing on either side of the dipstick was solid crusty oxide (obviously I only did the left):
Then the cabinet itself. 48"W x 24"H x 36"D, 24"x20" glass window (not acrylic), V-angled bottom to collect the leftovers (chair is to load stuff into it).
I could probably jump up and down inside the thing the way I braced it. I tend to overbuild shit. I was surprised that beads don't create any dust.
The only downside is I have to spray media for 20-30 seconds into a bottle before it comes out decent (if I let it sit). Basicly it loads up in the hose when I don't use it for several mins. It doesn't bother me since my compressor is big enough & the blaster is fairly efficient. I'm going to get black beauty and plastic stuff since I've heard & read that it those 2 will do rust/aluminum better and cheaper than glass beads. Edit: now that I think about it, I think it's because the compressor's regulator is busted and is stuck at 100psi. I'll probably just put one right on the sandblaster and go from there.
« Last Edit: March 30, 2010, 11:40:42 PM by HiProfile »
Re: Just another RHMT SANDBLASTER cabinet...
« Reply #1 on: March 31, 2010, 12:34:46 AM »
Fucking sweet!
What air compressor are you using to power this bitch?
bigwig
« Reply #2 on: March 31, 2010, 01:08:41 AM »
I bought the 20lbs unit & the cabinet.  The decent HF cabinet is $176+tax with a 20% off coupon.  I just assembled one today.  Overall, not terrible except the damn plexiglas/glass is all scuffed/cloudy.  I got lazy at the end of the day and didn't take it off to take a look to see what exactly was the issue but I'm sure it's a $10 fix.
My foot pedal came in today and I hope my pinch valve comes in Thursday.  I'm hoping to have the whole setup operational on Saturday.  I bought the plugs and outlet for the 220line.  I just have to find a reasonable priced electrician to do the work because it's rented commercial space.  One guy wanted $300 for a run of roughly 4' from the breaker to a box and another 4' to make a cord from the damn compressor to the box.  Sounded about $75 too high to me.
Ryan, for blasting 60 gal is a minimum.  You really want 80 gal 2 stage.  I just got a 60 gal 3hp that will be okay for low pressure blasting(what I do) but for this stuff would cause the machine to cycle A LOT.
« Last Edit: March 31, 2010, 01:11:10 AM by bigwig »
« Reply #3 on: March 31, 2010, 01:17:39 AM »
It's actually not that much, I honestly never looked at it too closely. It's a bit buried, but looks like a 3/4hp Baldor powering a dual-piston pump with only a 50gal tank (if I'm guessing right). My dad gave it to me because he got a smaller vertical to save garage space. In the far future I'm going to use a modded d16 longblock or harely block as a multi-piston compressor running a pair of baldor motors, hooked up to some big old LP tank. I'm getting a house before next fall, will upgrade past 200amp service if availible, and my dad's an electrician. :evil:
I looked at the HF cabinet, but I need something I can just trash at a moments notice if needed. It's basicly sitting on borrowed space. Plus I'm super cheap, saving for the house DP.
« Reply #4 on: March 31, 2010, 12:36:22 PM »
Ya I think mine is a 60gal 3hp as well. I figured it would be pretty much running non-stop. Not much different than when I'm using my die grinder for porting...the compressor never shuts off
ktown powder coating
  • Noob of the month Oct 09
« Reply #5 on: March 31, 2010, 02:13:07 PM »
it's easier on the compressor to run all the time then to start and stop all the time.
bigwig
« Reply #6 on: March 31, 2010, 02:16:49 PM »
Good compressors, maybe.  Average stuff, not at all.  They get HOT and then they fail.  Oil & air is not typically enough to keep a compressor cool.
« Reply #7 on: March 31, 2010, 07:55:25 PM »
It's easier on the motors, since they rarely have starting caps worth a damn. The compressor still heatsoaks like a turbo setup. The motors tend to outlast the pump anyways.
One place I worked at had a fucking gigantic compressor. The actual pumping unit was the size of a full pallet, 3' tall, and had a truck-sized radiator, which I assume was some sort of air-water setup. The fan produced a gust you could feel 100' away. Then there was the tank..9' tall & 4' wide. They kinda needed it with some older cnc retrofits that still needed tons of air instead of electric motors.
SgtB
« Reply #8 on: April 01, 2010, 07:37:37 PM »
It all depends on how close to the service factor the motor is. If you run it at 1.15 all day, it's better to give it a break. Anything over 1.0 shortens the life of the windings, and the bearings as well.
rsmith2786
« Reply #9 on: April 02, 2010, 12:10:43 PM »
I'm pretty sure all electric motors have a service factor of over 1 and isn't 1.15 the standard for all small electric motors?
SgtB
« Reply #10 on: April 02, 2010, 06:40:08 PM »
It's standard for most motors, even 200hp. My point was that if a 10hp motor is ran at 11.5 hp all the time, it will die faster. If you run it nice and cool at say 8hp, it will live a long life. As long as it runs cool, without too much side loading, you'll be good to run it continuous.
« Reply #11 on: April 02, 2010, 10:40:33 PM »
Got home late, put a regulator on the blaster, tried it at lower settings on some parts.
I have 2 sets of gsr rods/pistons, tested one from each. I spent an hour SCRUBBING four of them and 2 days soaking to get them looking like the bottom half of the left-side piston. Tonight I spent 30 seconds with "medium" glass beads at 30psi:
You can see the different parts of each rod I blasted:
Media blasting is soooooo much better!
