Author Topic: were can i find sensor voltages?  (Read 29034 times)
lilpooh21186
« on: April 01, 2009, 05:15:26 PM »
i dont currently have a volt meter. in log works i need to set the min voltage and the value as well as the Max voltage and the value for my map,tps and iat so were can i find this info?
Ecu chipping
basmaps
Re: were can i find sensor voltages?
« Reply #1 on: April 01, 2009, 07:13:12 PM »
Jeez man get an HF multimeter for $3 at least, better than nothing
« Reply #2 on: April 01, 2009, 09:14:34 PM »
TPS is:
0%= 0.43
100% = 4.49
i'll look for the rest
« Reply #3 on: April 01, 2009, 09:18:19 PM »
MAP:
minimum at 0 volts is -59 mbar
maximum at 5 volts is 1782 mbar
voltage at 1 atm is 2.91
lilpooh21186
« Reply #4 on: April 01, 2009, 09:45:52 PM »
thanks marcj
Ecu chipping
basmaps
« Reply #5 on: April 02, 2009, 03:49:34 PM »
You'll have to test the resistance of the IAT and build a little circuit around it. The ecu reads it as a variable resistor (thermistor), and the Innovate forum has methods to set it up. Am I to assume you have an SSI-4?
lilpooh21186
« Reply #6 on: April 03, 2009, 03:41:23 PM »
nope dont have the ssi-4 i just bought the lm-2 i saw something about a tuner-t but it seems like more of a lm-1 based product
Ecu chipping
basmaps
« Reply #7 on: April 03, 2009, 10:12:39 PM »
icelord.net has Helms manuals with IAT curves.  I suspect the Innovate gear wants a linear temp sender, though.
lilpooh21186
« Reply #8 on: April 07, 2009, 02:04:56 AM »
yep everything is linear its PITA
Ecu chipping
basmaps
« Reply #9 on: April 07, 2009, 11:51:47 AM »
does IAT use y=mx+b slope formula?
lilpooh21186
« Reply #10 on: April 07, 2009, 09:57:48 PM »
i belive so but im done messing with it im just gunna log the important data i need like afr rpm map and others ill use crome for the other logging.
Ecu chipping
basmaps
« Reply #11 on: April 08, 2009, 01:41:55 PM »
No, it is not linear.
