Author Topic: HX35W on crack...  (Read 9041 times)
HX35W on crack...
« on: April 04, 2010, 12:08:12 AM »
So I somehow found this link, seems like a great deal if you want a new/remfg'd Hoeslut. I'm not sure if it's a HX40 wheel, but it says it has a slightly bigger comp wheel that also spools up faster.
http://www.pdrdiesel.com/products/PDR_HX35_Turbo_Dodge_Cummins_1991_98_12V-521-26.html
I'm thinking about combining this with a cheap non-wg'd 12cm or 18cm housing, since it doesn't come with one. I'd also put a flapper valve in it for an integrated "quick spool valve".
http://www.gillettdiesel.com/18cm2non-wastegatedturbinehousing-1-1.aspx
The problem is I'm really caught between this and a 50trim Garrett that comes with an ATP divided housing. It's the same price as that "bare" hx35. It would end up on a summer daily driver with a built LS/vtec.  ???
Re: HX35W on crack...
« Reply #1 on: April 04, 2010, 12:20:38 AM »
That PDR "Hybrid" HX-35 is just a stock HX-35 with the stock wastgate ported and a compressor upgrade similar to this: http://www.gillettdiesel.com/HXUpgradeCompressorHousingandWheel60mm6blade.aspx
« Reply #2 on: April 04, 2010, 12:26:03 AM »
Well the fact it's basicly rebuilt and not $1000 is the main selling point for me.
I'm curious if anyone's seen any cheaper rebuilt/new HX35's...
« Reply #3 on: April 04, 2010, 01:35:10 AM »
http://www.adpdistributors.com/facilities.html builds pdr turbo's, and actually owns pdr as well. Might be cheaper from the source.
