Author Topic: How do you think it'll end?  (Read 7564 times)
Impact240sx
« on: April 04, 2010, 12:28:11 AM »
Ok so we're about to finally tune my cousins car. 90 CRX with a high compression D build (p29's, bisi header/cam/portwork/stock rods with arp's) that we decided to boost. Sold the bisi header and picked up a greddy kit with a 15g for 300 bucks. This is how it use to look
Made over 150whp out of this setup and about 125ft lbs
And now it looks like this :
I know the piping is missing, it was getting the flange welded on.
Our goal is just 180-200whp on 93 octane to just have a damn fun lil car. What do you guys think? Go for more? lol This is strictly his fun car, not a daily.
Re: How do you think it'll end?
« Reply #1 on: April 04, 2010, 01:02:54 AM »
I'd go for 700hp cause it's a D.
« Reply #2 on: April 04, 2010, 01:12:25 AM »
have fun tuning it, i had a high cr turbo d and it blew headgaskets left and right, now that i look back i should have been pulling timing
« Reply #3 on: April 04, 2010, 01:13:32 AM »
If it's not a DD and just for fun then you need at least 280 whp in that chassis  :noel:
« Reply #4 on: April 04, 2010, 03:06:59 AM »
Post pics of the carnage  :yes:
« Reply #5 on: April 04, 2010, 09:45:35 AM »
Put super cold plugs in it, like 9's or 10's...
Did you clay it during the build?  If so what kind of quench clearance did you come up with?
I wish you luck, but I don't see this one lasting...
You might want to back off the timing a bit too...
« Reply #6 on: April 04, 2010, 10:10:30 AM »
i was hoping this thread was about twilight
hatchboy
  • Bombs Over Baghdad
« Reply #7 on: April 04, 2010, 10:55:40 AM »
Homo HT swinger.
/thread
« Reply #8 on: April 04, 2010, 12:07:45 PM »
hmmm..   10.79:1 compression.  do it
im rocking 10.35:1 in the crx right now holslut powered.
« Reply #9 on: April 04, 2010, 10:21:36 PM »
It depends on how "greddy" you get with power gains. If you use enough timing retard and relatively low boost, it will be peppy off boost although less so on boost. But...not shit the bed. A comp calc tells me that's ~11.1:1 CR, assuming it's an A6 with z6 HG. You'll make decent amount more power per PSI than a stock A6 just from compression, let alone the headwork. I honestly don't think it would need super-cold plugs like that with low boost. An 8:1 motor running 20psi will have 276psi worth of compression before ignition, if it get's 100% VE. An 11:1 motor with 5psi will get 211psi of compression with 100% VE, but realisticly will be less with the greater overlap in the cams.
I'd highly recommend at least pulling the rods and getting them shot-peened. No need for new bearings/rings/hone. Another option is getting some b18b rods in that bitch, but that'd require new bearings if you aren't the most lucky man alive to get an exact match for rod journals.
« Reply #10 on: April 04, 2010, 10:47:31 PM »
P29s pistons...
Yeah, I want to see the carnage.
 :P
« Reply #11 on: April 04, 2010, 10:49:36 PM »
ls rods modified
vitara's
Result enjoy blowing up transmissions and having a rocket ship.
SOHCKLR657
« Reply #12 on: April 05, 2010, 07:26:20 PM »
ls rods modified
vitara's
 :yes:
Minor Threat
« Reply #13 on: April 05, 2010, 10:20:08 PM »
chinese eagles
vitara's
Fixed.
Way better than Hiproflies shotpeening idea lmao
Eggylshatch
  • Pen15 Club President
« Reply #14 on: April 05, 2010, 10:55:45 PM »
go with it and see what happens.  If you're feeling ballur, run meth/water injection too
« Reply #15 on: April 05, 2010, 11:33:33 PM »
Impact240sx
« Reply #16 on: April 05, 2010, 11:34:07 PM »
Yea we'll see what happens. Our tuner is kinda booked anyone on here around the ky/wv/oh area that tunes?
« Reply #17 on: April 05, 2010, 11:35:18 PM »
« Reply #18 on: April 05, 2010, 11:44:07 PM »
